0 Track Bike Build
0 Pushrod hitting tube
Last Post: DR DICK
0 need help with 68 XLH
Last Post: DR DICK
Last Post: lehel
Last Post: handa700
0 Gear and brake linkage
Last Post: Andy56
0 Oil pressure switch
0 Valve Stem Seal ID
Last Post: BruceM
0 What oil temp do you run
0 Clutch Spring plate poll
0 why you can't be seen
Last Post: Les59
0 HSR idle mixture screw
  #741
Old 14th August 2019
Hellbent_4 Hellbent_4 is offline
Sportster/Buell Model: XLH883 Hugger
Hellbent_4 has a brilliant futureHellbent_4 has a brilliant futureHellbent_4 has a brilliant futureHellbent_4 has a brilliant futureHellbent_4 has a brilliant futureHellbent_4 has a brilliant futureHellbent_4 has a brilliant futureHellbent_4 has a brilliant futureHellbent_4 has a brilliant futureHellbent_4 has a brilliant futureHellbent_4 has a brilliant future
I'm averaging 5k miles for the last four years.
Other than tires, bulbs, oil and adjustments it's been pretty straight up.
I just rebuild the carb but the bike is 17 years old and probably hasn't had much done prior.
Old 8th September 2019
Amend that last post: shifter return spring broke at 27,700 miles.
I'm grounded for a while.
xlerate's Avatar
xlerate xlerate is offline
Other Motorcycle Model: Yamaha FZR1000
Other Motorcycle Year: 1988
xlerate has a reputation beyond reputexlerate has a reputation beyond reputexlerate has a reputation beyond reputexlerate has a reputation beyond reputexlerate has a reputation beyond reputexlerate has a reputation beyond reputexlerate has a reputation beyond reputexlerate has a reputation beyond reputexlerate has a reputation beyond reputexlerate has a reputation beyond reputexlerate has a reputation beyond repute
I've had no problems in 35k k's, as of Aug'18, on my Sportster (bought used in Jan'16 at 8k k's)...apart from an addiction to changing things out! But I don't really see that as a problem. Even my clutch is still going fine!
I'm grounded for a long time!
2006 XL1200R in Yellow Pearl with wire wheel option; 30t trans sprocket; SE Heavy Breather a/c; SE II slip-ons; S&S IST ignition; 48 pilot, 185 main, CVP EZ-just mixture screw; HEL braided brake lines; Race Tech Gold Valves, Ohlins S36E shocks, Superbrace; Dart screen, Mustang Vintage Solo; JH570 cams installation underway.
Old 17th December 2019
doc martin doc martin is offline
doc martin is a splendid one to beholddoc martin is a splendid one to beholddoc martin is a splendid one to beholddoc martin is a splendid one to beholddoc martin is a splendid one to beholddoc martin is a splendid one to beholddoc martin is a splendid one to beholddoc martin is a splendid one to beholddoc martin is a splendid one to beholddoc martin is a splendid one to beholddoc martin is a splendid one to behold
55,000 miles on a 2005 883 low. Regular matinence. One leaky rear rocker cover gasket. Replaced the clutch with the screaming eagle one because of people warning me about it on this forum. Turned out the rivets were still just as tight as new. had a leaky diagram in the carb probably from the new ethanol gas. Other wise a perfect bike. Bought a 2015 super low to convert to a trike but keeping the 2005 till I'm in the ground then my grandson gets it
Highly-Dangerous's Avatar
Looks like you haven't ridden at all in the last year and a ½?
hahahahhahha.... nothing escapes from your watch!!!
[B][COLOR="Red"]CLICK->>[/COLOR][URL="http://sportsterpedia.com/doku.php/start"]"Maintenance is as much art as it is science"[/URL][COLOR="red"]<<-CLICK[/COLOR][/B]
[IMG]http://xlforum.net/forums/attachment.php?attachmentid=20617&d=1576580635[/IMG]
Old 6th February 2020
Firehawk's Avatar
Firehawk Firehawk is offline
Sportster/Buell Model: SuperLow
Firehawk is an unknown quantity at this point
Getting close to 17,000 miles on my '17 SuperLow, only 'problem' I've had was a check engine light coming on. Cleared the code and it hasn't come back so I guess it was a fluke thing. The bike has been as reliable as an anvil.
2017 883 SuperLow
Old 7th February 2020
duffy duffy is offline
Sportster/Buell Model: Anniversary 883 Hugger
Sportster/Buell Model #2: 03' Sportster 883 Hugger
duffy has a brilliant futureduffy has a brilliant futureduffy has a brilliant futureduffy has a brilliant futureduffy has a brilliant futureduffy has a brilliant futureduffy has a brilliant futureduffy has a brilliant futureduffy has a brilliant futureduffy has a brilliant futureduffy has a brilliant future
I haven't had any real problems yet but then I've only had the bike a few months (5). It was a bit hard to start at first (I re-jetted the carb and all is good). I ride about 3-5K miles a year.
Originally Posted by roadsterboy View Post
O.K. Folkie, I went out to the shop and punched-up the mileage -78,667.
I ride every day, except when it's raining. The mileage was not the point-
the question was about reliability/problems. Thanks for the reply and keep
enjoying your Sportster!
Wow 1,667 miles in a year and a half. Your butt must be made of steel to endure that kind of mileage
I bought my 2005 XL883 with less than 10K on it, after it had been sitting in a garage for several years and was coated in dust. All the fluids were dark and the seller wasn't sure how many miles were on the motor and primary oils (both black when changed). The battery was the only thing non-stock. I replaced all the fluids, air filter, oil filter and ran new non-ethanol gas with cleaner after draining the tank. After putting the battery on the battery tender overnight, it fired right up and ran perfectly. Since then I've added 7K miles (still riding every time the temp goes above 50 degrees F) and it continues to run perfectly.
I've done no repairs but I've been pro-active in preventing future problems/repairs by replacing the vacuum petcock with a Golan manual one, replacing the spring plate aka "grenade plate" with stock plates, replacing the stock clutch throw-out bearing with a FAG 7200B bearing and modifying the stock crankcase vent system to vent-to-atmosphere instead of venting the hot, oily bad breath back into the air intake. I haven't had to adjust anything at all to improve the running quality. Love it!!!!
Old 20th March 2020
Daveinhutto Daveinhutto is offline
Sportster/Buell Model: xl 883
Other Motorcycle Model: V strom DL 1000
Daveinhutto is an unknown quantity at this point
Default The Battery cover has to be zip tied on
I went through the effort of replacing the tab on the frame to hold the cover in place. I took off from a light and it fell off and was run over by something bigger than me. The PO had zip tied it on and I thought he was just cluging it together. Nope it is by design. so there is that. you would think HD would have used zuss fasteners to retain it. Have a seeping seal at the shifter but I don't think its a real issue, yet. May be from the crash the PO had on it. so battery cover retention system.
