0 Bearing questions
Last Post: Scott
Last Post: broknluck
0 I guess I'm back
Last Post: gravydog
0 Compensator nut.
0 turn key on, no power at battery. key off battery good. help
0 Clutch issues
Last Post: Gibson90kb
0 Cold?
0 Basic Welding Equipment
0 Massachusetts rides 2019
Last Post: joes95bobber
Last Post: Kennyv
4 The no-debate OIL POLL
0 Front end swap
0 Torquing Rubber
0 Been cheated on?
Last Post: Joe_jeep
14 HD ad for Dirt?
0 Cold Start. Then stall
Last Post: Tucsonmax1
Last Post: kopbilly1
0 Looking For parts 86 XLH
Last Post: cajun1957a
0 Trade: 91-03 Forward Controls for Mid Controls
Last Post: tmessenger
0 Brake Line Part Number ?
billib (65), Scar (60), koolblue, Spor-T-1 (56), Choppershed (55), Nemo DeNovo (53), harman35 (51), Wannabee (51), crackermank (49), WORM (43)
aft
Old 5 Days Ago
tedg's Avatar
tedg tedg is offline
Sportster/Buell Model: 883
Sportster/Buell Model #2: 80 xlh / 79 xlch
tedg is a name known to alltedg is a name known to alltedg is a name known to alltedg is a name known to alltedg is a name known to alltedg is a name known to alltedg is a name known to alltedg is a name known to alltedg is a name known to alltedg is a name known to alltedg is a name known to all
The satotor us a CE-9100A the regulator is a CE-210. If u need more info message me and we can go from there. Thanks
Duane Allman Rules.
Old 4 Days Ago
dieselvette's Avatar
dieselvette dieselvette is online now
Sportster/Buell Model: Roadster-Glide
dieselvette is a splendid one to beholddieselvette is a splendid one to beholddieselvette is a splendid one to beholddieselvette is a splendid one to beholddieselvette is a splendid one to beholddieselvette is a splendid one to beholddieselvette is a splendid one to beholddieselvette is a splendid one to beholddieselvette is a splendid one to beholddieselvette is a splendid one to beholddieselvette is a splendid one to behold
Thanks for reply.
9100/210 is the 20-amp model (same as stock, but way better quality)
"Life is never made unbearable by circumstances but only by lack of meaning and purpose" - Viktor Frankle
FIND HELP WITH YOUR SPORTSTER HERE: http://sportsterpedia.com/doku.php
2004 1200 Roadster Custom-Electra-Glide-Sport-Touring-Edition
SE air cleaner w/venting routed outside a/c
Supertrapp 2:1 pipe - usually 20 discs w/closed endcap
Stock CV carb w/ Yost tube + DS idle mixture screw
Cycle Electric 38A charging system
Corbin 2-up seat (plus AirHawk for LDR)
Metzler 880 front & rear (usually)
QD windshield - sometimes with SlipStreamer glass + driving lights
Custom hwy pegs - sometimes with lowers mounted
Trailer hitch, when needed
Currently working on improving MPG:
TC88A ignition
Valve job & rings - 0.030 squish, bump up compression?
Bronze oil pump gear
Update oil pump to '07-up
30-tooth HDI belt sprocket (137-tooth belt)
