0 1979 oil routing diagram
Last Post: Jorgem79
0 Mid's or rear sets
0 Hello from Toronto, Canada!
Last Post: Veeflys
0 Show your tank decals
Last Post: geoff
0 Lowboy frame conversion
0 Primary Oil INSANITY!
Last Post: cotton1
0 Cartridge Conversion?
Last Post: XLXR
Last Post: MXHD55U
0 Turn Signal Relocate issue
Last Post: Tucsonmax1
Old 24th April 2017
PaddyD PaddyD is offline
Sportster/Buell Model: XL 1200L
PaddyD is a splendid one to beholdPaddyD is a splendid one to beholdPaddyD is a splendid one to beholdPaddyD is a splendid one to beholdPaddyD is a splendid one to beholdPaddyD is a splendid one to beholdPaddyD is a splendid one to beholdPaddyD is a splendid one to beholdPaddyD is a splendid one to beholdPaddyD is a splendid one to beholdPaddyD is a splendid one to behold
Today I tried what is basically the same product by Rustoleum. Personally, I like the Rustoleum stuff better than Pastidip. Seems like it might be a tougher rubber compound. Duplicolor has a peelable rubber spray that I want to try. I just love the fact that I can grab it and rip it off if I get tired of it. All with no damage to existing paint or chrome.
Old 4th August 2017
fada fada is offline
Sportster/Buell Model: forty-eight
Sportster/Buell Year: 2016
fada is an unknown quantity at this point
the trick with plastidip is to let the can sit in hot water for 15 minutes or so before painting. I saw that on several videos from diyourcar guys on youtube.
2016 Forty-Eight Olive Gold
Old 4th August 2017
I've used the Plastidip and never liked it. It just doesn't hold up. I found the Rustoleum brand equivalent is twice as good. Looks better and is twice as durable. For me the key to either is getting any wax or oils off the surface prior to spraying. Then like it says a light first coat. Let it sit for a few minutes then top coat. It needs a day or two to cure up too.
Old 4th August 2017
Jheitt's Avatar
Jheitt Jheitt is online now
Sportster/Buell Model: XL883c
Other Motorcycle Model: Honda rebel 300
Other Motorcycle Year: 2018
Jheitt is a splendid one to beholdJheitt is a splendid one to beholdJheitt is a splendid one to beholdJheitt is a splendid one to beholdJheitt is a splendid one to beholdJheitt is a splendid one to beholdJheitt is a splendid one to beholdJheitt is a splendid one to beholdJheitt is a splendid one to beholdJheitt is a splendid one to beholdJheitt is a splendid one to behold
I use it on my truck wheels. Once a year it needs a respray. You have to spray it on thick! As said above, if you treat it like spray paint it's going to suck. Plastidip self levels but it needs to be wet to do so.
Sent from my SM-G930W8 using Tapatalk
