0 1979 oil routing diagram
Last Post: Jorgem79
0 Mid's or rear sets
0 Hello from Toronto, Canada!
Last Post: Veeflys
0 Show your tank decals
Last Post: geoff
0 Lowboy frame conversion
0 Primary Oil INSANITY!
Last Post: cotton1
0 Cartridge Conversion?
Last Post: XLXR
Last Post: MXHD55U
0 Turn Signal Relocate issue
Last Post: Tucsonmax1
Old 12th October 2016
jimbond's Avatar
jimbond jimbond is offline
jimbond is a splendid one to beholdjimbond is a splendid one to beholdjimbond is a splendid one to beholdjimbond is a splendid one to beholdjimbond is a splendid one to beholdjimbond is a splendid one to beholdjimbond is a splendid one to beholdjimbond is a splendid one to beholdjimbond is a splendid one to beholdjimbond is a splendid one to beholdjimbond is a splendid one to behold
Harbor Freight sells a hobbyist quality lathe, also your local votech often will help.
Old 13th October 2016
NHPS NHPS is offline
Sportster/Buell Model: Sportster 1200xl
Sportster/Buell Year #2: 1977
NHPS is a splendid one to beholdNHPS is a splendid one to beholdNHPS is a splendid one to beholdNHPS is a splendid one to beholdNHPS is a splendid one to beholdNHPS is a splendid one to beholdNHPS is a splendid one to beholdNHPS is a splendid one to beholdNHPS is a splendid one to beholdNHPS is a splendid one to beholdNHPS is a splendid one to behold
I did a little looking and researching on this. Dont get me wrong i love harbor freight but i get real scared making purchases on tools like this from there.
Folkie's Avatar
Folkie Folkie is offline
Brass Nut
Sportster/Buell Year: 2015
If I was going to get a lathe I'd look at secondhand 'proper' lathes, like a Myford.
Folkie
South East England Riders
K1rodeoboater's Avatar
K1rodeoboater K1rodeoboater is offline
Sportster/Buell Model: 883 Deluxe
K1rodeoboater is a splendid one to beholdK1rodeoboater is a splendid one to beholdK1rodeoboater is a splendid one to beholdK1rodeoboater is a splendid one to beholdK1rodeoboater is a splendid one to beholdK1rodeoboater is a splendid one to beholdK1rodeoboater is a splendid one to beholdK1rodeoboater is a splendid one to beholdK1rodeoboater is a splendid one to beholdK1rodeoboater is a splendid one to beholdK1rodeoboater is a splendid one to behold
FWIW little machine shop sells the EXACT SAME lathe. They're all Sieg machines which come from the same factory (grizzly sells them too at a higher cost with a different color paint job). There are some disadvantages to the Sieg lathes but they're not bad if you work within their capabilities
Old 10th November 2016
1904Sportster 1904Sportster is online now
Sportster/Buell Model: xl1200
1904Sportster has much to be proud of1904Sportster has much to be proud of1904Sportster has much to be proud of1904Sportster has much to be proud of1904Sportster has much to be proud of1904Sportster has much to be proud of1904Sportster has much to be proud of1904Sportster has much to be proud of1904Sportster has much to be proud of1904Sportster has much to be proud of1904Sportster has much to be proud of
I have done some sandcasting but I've never worked with brass. My father in law has a modest backyard foundry set up that works great for casting stuff out of aluminum. The furnace is heated with propane and gets hot enough to melt aluminum but I'm not sure if it would melt brass. There's about a 500 degree difference, 1200 compared 1700 (in round numbers). Maybe if a blower were added, but I've never looked into it.
What I can tell you is that sandcasting is awesome and I highly recommend it. People have been doing it for thousands of years so how hard can it be?
I've posted some pictures of parts I've made in another thread. Here's a link...
http://http://xlforum.net/forums/showthread.php?t=1237326&page=10
Old 30th August 2017
jcn59 jcn59 is offline
Sportster/Buell Model: 1200
jcn59 is a name known to alljcn59 is a name known to alljcn59 is a name known to alljcn59 is a name known to alljcn59 is a name known to alljcn59 is a name known to alljcn59 is a name known to alljcn59 is a name known to alljcn59 is a name known to alljcn59 is a name known to alljcn59 is a name known to all
Static casting of brass or bronze will give you fits. Get ready to make lots of little wax patterns. Porosity is your enemy. Safety is a big issue. Jimbond can tell you about it.
jimbond's Avatar
Another idea is find someone who has a 3D printer make the part, send it to me and I'll have it cast in SiBrz. we cast parts for steam cars thru jet engines. look at
http://hillbillyvintageclassics.com/ all of marks stuff came from our shop.
Ireeman's Avatar
Ireeman Ireeman is offline
Asgardian
Sportster/Buell Model: 883r
Other Motorcycle Year: abov
Plus 1 on the 3D printing and sand cast.
Very easy and cheap these days.
Even the 3d machines that print in metal have come way down is price....that way, you can skip the cast itself.
philvet's Avatar
philvet philvet is offline
Sportster/Buell Model: XLC
Sportster/Buell Year: 09
philvet is an unknown quantity at this point
Default 3 D printed metal
3D printed metal parts are a mixture of powdered metal and plastic after the part is made it has to be sintered in a furnace, not a cheap. You would be better off having the part machined.
Ireeman's Avatar
Asgardian
Machining simple parts sure. However when you get into complex geometrical shapes, the tooling and fixturing gets really expensive.
