Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > SPORTSTER MOTORCYCLE FORUM > Sportster Motorcycle Styles > Sport-Glide / Sportster Motorcycle Touring
0 Help identify these parts
Last Post: maltesefalcon
0 A early 84 motor in a 84 later frame
Last Post: 84bobber
0 2002 883 Fuel Valve repair kit
Last Post: grmeyers
0 1981 XLH Getting Recranked
0 Clutch Spring plate poll
0 New Top Fuel record
0 Q&a
0 primary chain adjustment
0 Allegheny National Park III
0 Gas Cap problem?
0 Something different: 1948 Willys Truck
0 Rubbermount Poll
0 New from Brighton UK - XLCR Race bike owner
Last Post: sootysweep
0 Regulator contacts welding shut
0 Bike issue after swapping handlebar. :(
Last Post: slonez
0 Clutch biting point
0 Pinging and a white plug
Last Post: denguy
0 Hi from New Jersey 1985 XLS
Last Post: Tyler45
WJB2, Hap (69), XL1200Sport (67), mike/xlch (65), buster (52), sappi (52), Big Daddy Chop (49), Billy1904 (43)
Old 13th August 2018
VaFish VaFish is offline
Sportster/Buell Model #2: 883 Blue
Sportster/Buell Year #2: 1997
Other Motorcycle Model: A pile of Ninja 250's
Other Motorcycle Year: 1988
VaFish has a reputation beyond reputeVaFish has a reputation beyond reputeVaFish has a reputation beyond reputeVaFish has a reputation beyond reputeVaFish has a reputation beyond reputeVaFish has a reputation beyond reputeVaFish has a reputation beyond reputeVaFish has a reputation beyond reputeVaFish has a reputation beyond reputeVaFish has a reputation beyond reputeVaFish has a reputation beyond repute
Default Nescessary Tool Kit
I'm heading off on a 3,500 mile ride in a few days.
I was trying to think of what tools I need to pack. I did some searching and found this thread: http://xlforum.net/forums/showthread...highlight=Tool
That's not how I want to pack tools.
I'm thinking just enough to take care of the stuff that tends to shake loose
Vice Grips
1/2" and 9/16" wrenches, maybe a crescent wrench
There are about 3 or 4 Allen and Torx wrenches I use fairly often. ( I think it's 1/4", 3/16", T25 and one of the larger Torx)
Phillips and Straight Screw Driver
Wire Cutters/Pliers
Extra Engine Oil
I'm just thinking of stuff I've had shake loose in the past like mirrors, sissy bar mounts, highway pegs.....
Anything important I am missing?
(I don't consider the credit card, roadside assistance or Glock part of my tool kit, but they will be packed too)
mikeLI_77's Avatar
Roll of electrical tape, zip ties, a piece of wire maybe 8" long. 10mm socket for the battery unless you bring an adjustable wrench, blue locktite.
2002 XL1200C (originally)
Dyno (96.21 HP / 88.70 TQ)
https://ibb.co/V34RNfc
States I Have rode through
Thanks for mentioning the battery. I don't think I have room for a 10MM socket, but I'm pretty sure I need a 10mm wrench, even the crescent wrench is a bit of a pain to use up on the hot lead.
jammantoo's Avatar
jammantoo jammantoo is offline
foot in mouth member
Sportster/Buell Model: 48
Sportster/Buell Year: 2016
Other Motorcycle Model: Dou-glide
Other Motorcycle Year: 63
jammantoo has a reputation beyond reputejammantoo has a reputation beyond reputejammantoo has a reputation beyond reputejammantoo has a reputation beyond reputejammantoo has a reputation beyond reputejammantoo has a reputation beyond reputejammantoo has a reputation beyond reputejammantoo has a reputation beyond reputejammantoo has a reputation beyond reputejammantoo has a reputation beyond reputejammantoo has a reputation beyond repute
keeping it light is the most important. I carry enough stuff to do emergency repairs. Besides what has been mentioned a pair of needle nose pliers and some bailing wire, duct tape can be helpful. but do not pack too much, I carry allen wrenches and a few torx besides a very basic socket set. then refer back to the other post and you should be covered. Remember a Sig beats a Glock anyday.
Join the PEANUT CLUB, it gives you an excuse to stop and smell the roses
There are several T27 Torx fasteners on the Sportsters. Easy to strip them out if you use a T25. Have both bits and always test fit the 27 fits and use it if you can get it engaged.
Joe
Joe
Thanks for reminding me of that one. And many torx sets don't have a T27 they go T25 then T30.
I was thinking about carrying the S&W Model 28, .357 Mag and it won't leave any empty shell cases behind, but it's pretty big and heavy.
60Gunner's Avatar
60Gunner 60Gunner is offline
A Beretta beats both but yes, just say no to glocks.
Always locked and cocked ready to throw down 12 .40cal hollow points in seconds with another 11 rnd mag at the ready. They're usually all down or running at that point. Never leave home without it.
I usually carry tools as well. A small torx bit set with 6 bits and the 1/4" socket to drive them either with a 1/4" drive ratchet or driver. A 3/8" drive rachet and 5/8 spark plug socket, straight and phillips screwdriver, really small straight screwdriver for pilot jets and a couple allens and a couple small wrenches and there isn't much I can't do on the road.
Goes in my fork bag with plenty of room to spare.
Old 14th August 2018
There is a little 10mm/12mm open end wrench that used to come with the Honda tool kits. It is small, light weight, and just right for the battery bolts. You might find one in a pawn shop. I always have one with me.
The one in the picture is on ebay. You can usually find one in flea market or pawn shop if you look out for them.
Graywolf
Old 27th August 2018
Well I finished the ride. Didn't use the tools on my bike, The problems were so bad I didn't have enough tools to replace a cylinder or install a 1200 kit. Ended up buying another bike along the way. I did loan my allen wrenches to a fellow rider who's shift linkage came loose on his 2013 Ultra.
Old 28th August 2018
SonWon SonWon is offline
Sportster/Buell Model: Superlow 1200T
SonWon has a reputation beyond reputeSonWon has a reputation beyond reputeSonWon has a reputation beyond reputeSonWon has a reputation beyond reputeSonWon has a reputation beyond reputeSonWon has a reputation beyond reputeSonWon has a reputation beyond reputeSonWon has a reputation beyond reputeSonWon has a reputation beyond reputeSonWon has a reputation beyond reputeSonWon has a reputation beyond repute
Welcome back! Sorry to hear about the bike problems.
