0 05 883xl question re: jet size
Last Post: r100steve
0 Powerraythor conversion
Last Post: class of 82
0 testing wiring harness connections
Last Post: Roane
0 Mild 1250 build thoughts?
Last Post: Ghostdog
0 1200 conversion
0 Timing
0 Benelli tank on 79’ sportster
Last Post: Fatylonghous
0 speedometer
0 blonde, brunette, red?
Last Post: Lincoln
0 Not an ironhead, but....
0 Riding in the rain
0 P0505 code on my '09 XL883C driving me insane!!
0 gas cap
0 What weight oil?
Last Post: SLW210
Last Post: Edwinblake
0 TMC Dumont motorcycle concept
0 xr1200 thottlebody on xb heads (does it fit?!)
  #31
Old 28th September 2019
Drop a note to Chris, our “Parrothead”, as he has a Softail in his stable.
Tonyb65's Avatar
Tonyb65 Tonyb65 is offline
Sportster/Buell Model: XL 883 DLX Sportster
Tonyb65 is a name known to allTonyb65 is a name known to allTonyb65 is a name known to allTonyb65 is a name known to allTonyb65 is a name known to allTonyb65 is a name known to allTonyb65 is a name known to allTonyb65 is a name known to allTonyb65 is a name known to allTonyb65 is a name known to allTonyb65 is a name known to all
Thanks Paul will do
Old 29th September 2019
Tonyb65's Avatar
Faster project moving right along. Received the dash, speedometer, ignition switch dash mount plate kit and hardware. This is a test fit of the base mount plate, speedometer and ignition switch. Without installation instructions thought I would do my best to figure out the basic stuff. So did a test fit of the components unfortunately the dash did not fit so I have to return it to J&P cycles
Die cast dash plate mount
Die cast dash plate mount, FL style speedometer and ignition switch
side view of assembly
Pulled back for an oblique angle
Last edited by Tonyb65; 29th September 2019 at 03:04.. Reason: add another angle photo
I think Flame_ also has a Softail and might be of some help.
Old 9th October 2019
Tonyb65's Avatar
Right tank set to where it needs to be for final assembly. Need to Fab the mount brackets and then onto fuel lines and wiring.
Old 13th October 2019
Tonyb65's Avatar
Got the final fabrication of the tank mounts finished and installed. Needs some touch up paint, then final tank assembly, ignition and light wiring, then fuel lines.
Old 14th October 2019
Tonyb65's Avatar
Got the mock up and fabrication completed. I mounted the tanks in place Today. I think this is going to look great when finished.
rokytnji's Avatar
rokytnji rokytnji is offline
Sportster/Buell Year #2: 1983
Other Motorcycle Year: 1990
Nice to see mock up helped out before final assembly .
Next will looking for cracks if any stress is applied on mounting tabs on tanks. Hopefully. Static drop in was easy peasy and loosey goosey. Instead of shoe hoe horned in.
ose rank tabs crack easy from vibration sometimes if mounted under tension on mounting point.
Things got a lot easier when I gave up the illusion I exist.
Traveled to
Old 15th October 2019
Tonyb65's Avatar
Everything went on nice and easy during mock up and pre final assembly didn't have to put any stress on any of the tabs. However I intend to include looking at the tabs and mounts during every pre trip inspection.
