0 05 883xl question re: jet size
Last Post: r100steve
0 Powerraythor conversion
Last Post: class of 82
0 testing wiring harness connections
Last Post: Roane
0 Mild 1250 build thoughts?
Last Post: Ghostdog
0 1200 conversion
0 Timing
0 Benelli tank on 79’ sportster
Last Post: Fatylonghous
0 speedometer
0 blonde, brunette, red?
Last Post: Lincoln
0 Not an ironhead, but....
0 Riding in the rain
0 P0505 code on my '09 XL883C driving me insane!!
0 gas cap
0 What weight oil?
Last Post: SLW210
Last Post: Edwinblake
0 TMC Dumont motorcycle concept
0 xr1200 thottlebody on xb heads (does it fit?!)
  #31
Medyo Bastos Medyo Bastos is offline
Sportster/Buell Year: 1966
Medyo Bastos is an unknown quantity at this point
Originally Posted by Seeny View Post
the ground is wired to the 'L' terminal on the generator and the positive is connected to the same terminal on the ignition switch as my headlight.
Thinking out loud:
Can you separate things on your switch logically?
Generator, and coils to ignition post on switch;
lights and other things to acc post?
doodah man's Avatar
Just to confirm this is whats happening with the generator light as well. Its flickering very low on idle but then goes out under load...
This to me makes me think that the generator/reg are doing their job?? I'm probably wrong.
that sounds like normal operation for the gen light, but definitely not for the tail light. it should stay on solid.
The Doctor71 The Doctor71 is online now
Sportster/Buell Year: 1971
Sportster/Buell Model #2: xlh
Other Motorcycle Year: 2011
Your headlight / taillight should not function the way you’ve described.
I would (temporarily) remove the headlight / taillight circuit from play. aka disconnect the lighting wire(s) from the switch.
Re-test your gen & see if that changes anything.
Seeny Seeny is offline
Seeny is an unknown quantity at this point
With the ignition and generator hooked up (no acc) the reading is still the same when the motor is on
The problem seems linked to the taillight, which is strange as it shares the same circuit and fuse as the headlight. You can see in my diagram that the headlight and taillight are joined before the fuse. The headlight doesn’t seem to show any of the same symptoms yet when the temporary generator light is connected the taillight and generator light both flicker the exact same way.
Any chance the age and condition of the switch could be a factor?
You really need to separate the devices to see what works & what does not...
I looked at your schematic - I would pull both the headlight fuse & the generator fuse...
Then run the bike (not riding) with just the battery (don't use the brake)...
Check the voltage readings across the battery terminals...
If you still have those jumping numbers, I would suspect your battery and/or your meter...
Some interesting observation today. Where I thought I had blown my recent taillight bulb on the ride last weekend, it turns out that it hasent actually blown (yet) but in fact its actually reacting to the voltage much like the generator light that I have just hooked up. On idle the taillight is flickering (very unstable and dim) but under load its going out completely.
Just to support the observation above as well as my previous post.
https://youtu.be/CNnjRLDQx5s
Is this different to disconnecting the acc from the switch all together? I did this and the readings were the same.
Is this (removing both fuses) different to disconnecting the acc from the switch all together? I did this and the readings were the same.
Yes - because if you disconnect the Acc wire from the keyswitch, the generator is still connected to the battery...
Try removing both fuses and then run the engine & see what the meter reads across the battery...
Have you tried a different meter?
