0 electrical
Last Post: rwilson8
0 Knocking noise in front cylinder!!!!
0 No start no click, helppp plz
Last Post: gotamotor
0 Need some help
0 '06 Sporster Oil Tank drain
0 Operation Live Wire
Last Post: Kbetts
0 Age limit where belts should be replaced?
Last Post: oupa
0 Old Parts
0 o-ring versus band intakes
0 Nothing much
Last Post: oupa
Last Post: Kbetts
0 Dual disks and caliper upgrade
Last Post: gwcrim
0 Hello from Germany
6 Hello from Central Vermont
5 Harley T-Shirts
0 Forum problems???
0 Piston size id?
Last Post: nychopper
0 Fuel Pump Problems
3 Ironhead Pictures Thread
Last Post: Island Dude
0 1979 XLH Carb
0 Hello from Murcia-SPAIN
0 Gibt es hier keine Deutschen?
Last Post: Clementine
stroker ace (79), beunme (59)
Old 24th June 2016
MatHormell's Avatar
MatHormell MatHormell is offline
Sportster/Buell Model: XL883R
Sportster/Buell Model #2: Buell XB12R
Other Motorcycle Model: Yamaha
MatHormell has a reputation beyond reputeMatHormell has a reputation beyond reputeMatHormell has a reputation beyond reputeMatHormell has a reputation beyond reputeMatHormell has a reputation beyond reputeMatHormell has a reputation beyond reputeMatHormell has a reputation beyond reputeMatHormell has a reputation beyond reputeMatHormell has a reputation beyond reputeMatHormell has a reputation beyond reputeMatHormell has a reputation beyond repute
I also was fighting a reversion with my super trapp.. I ended up scraping the baffle and diffuser plate and made an adjustable reversion plate (lollipop) here's some dyno pull to show how a little angle change to the plate made a huge difference..
This graph was super trapp with baffle, open end cap and 25 diffuser plates.. (red)
The other line is no baffle and just a lollipop.. (blue)
This is 3 pulls with different angles on the plate
Simple and easy but loud! Lol
Sent from my SAMSUNG-SM-G935A using Tapatalk
HAMMER PERFORMANCE 90 Ci
CP .500 Dome Pistons
Axtel Cast Iron Cylinders
HAMMER PERFORMANCE .600 Cams
1.725 Ratio S&S Rocker Arms
HAMMER PERFORMANCE Intake Manifold
HSR 48 Miunki
XR1200 Crank Conversion W/ Case Mod 34T
HAMMER PERFORMANCE Sledge+ Head Work
2.020" Intake and 1.630" Exhaust Valves
Conical Valve Springs
S&S Premium Lifters
HAMMER PERFORMANCE Billet Push Rod Bases
Barnett Clutch Hub With Scorpion Clutch
Dynatek 2000i
R&D MOTORSPORTS- TRANSMISSION WORK-REM ISF
WorldWideBearings
Patriot Defender Exhaust
Old 27th June 2016
mac93 mac93 is offline
Sportster/Buell Model: 1200
Sportster/Buell Year: 95
Did a little clutch work this week. Last race the bike would start to spin around 15 ft. out so we took 10g off the clutch. The first pass was 9.235@141.5, track went away after that but we feel the clutch is good for now. The next issue is at 141.5 mph it's on the rev limiter, rather than take out gear we're going to reprogram rev limiter in the ignition. This thing makes power, it's a challenge to get it to hook up early.
Old 19th July 2016
TX Dreamer TX Dreamer is offline
TX Dreamer is a name known to allTX Dreamer is a name known to allTX Dreamer is a name known to allTX Dreamer is a name known to allTX Dreamer is a name known to allTX Dreamer is a name known to allTX Dreamer is a name known to allTX Dreamer is a name known to allTX Dreamer is a name known to allTX Dreamer is a name known to allTX Dreamer is a name known to all
Mac, how's the bike doing?
Sent from my Nexus 6P using Tapatalk
Old 20th July 2016
Bikes running great, Two runner ups and out in the third round due to a broken wheelie bar mount, no wheel speed and killed the 60 foot, was holding .02+ at the tree but couldn't carry it to the stripe with the bad 60. We feel it's a really good bracket racing combo. We followed xldukes with his build and decided to make the switch and couldn't be happier with the Hammer 90. We feel there's more but taking baby steps. It's hard to find more and race at the same time. Going to try the patriot this week, got other idea's at the machinist but going to need a T&T to see if we can get the feel he want's. This thing makes power like we've never had so we need to learn how to get it to the track. I don't care about track points but he does and he won't let me play! LOL!
Old 20th July 2016
Just keep playing with it, you'll get it.
Old 20th July 2016
Oh, there's always more that's why this hobby is so cool. We'll figure it out, Thanks.
Old 21st July 2016
cycowrencher's Avatar
cycowrencher cycowrencher is offline
Other Motorcycle Model: 1984 KX 125
cycowrencher has much to be proud ofcycowrencher has much to be proud ofcycowrencher has much to be proud ofcycowrencher has much to be proud ofcycowrencher has much to be proud ofcycowrencher has much to be proud ofcycowrencher has much to be proud ofcycowrencher has much to be proud ofcycowrencher has much to be proud ofcycowrencher has much to be proud ofcycowrencher has much to be proud of
You have a package on the way.
USN 1991-1995 VFA-81/ USS Saratoga, Iraq 1, Kosovo/ Bosnia Conflict
Old 24th July 2016
Got it today, ignition and Patriot installed, just finished loading up, race tomorrow. Thanks again for taking the time to do that.
Old 24th July 2016
No worries. I am tempted to come there next weekend for t and t time... I wont get any until first qualifying pass on 6th...
SuiCyco Racing
47L
In Honor of Charlie Roach RIP
Old 24th July 2016
Whats the word bird?
Was the patriot what you needed?
SuiCyco Racing
47L
