0 Screamin Eagle? (Cams)
Last Post: koalaracing
0 71 Iron
Last Post: mickey t
0 AOL Blows
Last Post: xElvis
0 Electrical Gremlin and weird Speedo Behavior
Last Post: xElvis
0 If you could only have one bike, would it be a Sporster?
Last Post: xElvis
Last Post: toe
0 What Years Actually Fit the 1990 XLH?
Last Post: Rollbar
6 73 Sportster Starts, Runs Fine, Dies
0 THE Trainspotting Thread
0 ‘15 Iron Chopped Fender/struts
Last Post: jjcsr74
0 The chicken or the egg (bent pushrod)
0 Dynojet Power Vision 2
Last Post: whittlebeast
0 2020 Sportsters
Last Post: jjcsr74
0 New Lithium Battery, Lights Go Out
Last Post: LLOYD883
0 Rear hub lock nut
Last Post: randy3934
0 One jug under the line...
0 New member
0 Could this be an overheating issue?
14 1974 Ironhead sportster xlch
Last Post: Kennyv
0 Lake Erie Ride Alums?
Last Post: XL Ed
Last Post: XL Ed
Last Post: Yakcm2
0 New LED headlight bulb. Highbeam aim wrong.
Last Post: Bikeaholic
0 started her in gear
Last Post: ezmerf
Last Post: Moon Wolf
dtw757 (65), XLH75Rider (64), JRLang13 (57), Shaerona (55), christophe (52), collectovince (51), buckethead (41), Hang_Em_High (39)
Old 28th June 2018
MatHormell's Avatar
MatHormell MatHormell is offline
Sportster/Buell Model: XL883R
Sportster/Buell Model #2: Buell XB12R
Other Motorcycle Model: Yamaha
MatHormell has a reputation beyond reputeMatHormell has a reputation beyond reputeMatHormell has a reputation beyond reputeMatHormell has a reputation beyond reputeMatHormell has a reputation beyond reputeMatHormell has a reputation beyond reputeMatHormell has a reputation beyond reputeMatHormell has a reputation beyond reputeMatHormell has a reputation beyond reputeMatHormell has a reputation beyond reputeMatHormell has a reputation beyond repute
Default Any 88/90inch using 30T crank sprocket?
Considering going to a 30T crank sprocket on my 90", curious is anyone else is using one on a 88/90 and what final drive sprockets are you finding to work best with it?
I am currently running 19Tf 45Tr and would like to get into 5th a little bit sooner and would prefer to cut weight than add it with more chain and sprocket.
Also reason I mention 88/90", I was told once it wouldn't be as beneficial on a 90" because I would loose out on the TQ, so curious how its working for you.
HAMMER PERFORMANCE 90 Ci
CP .500 Dome Pistons
Axtel Cast Iron Cylinders
HAMMER PERFORMANCE .600 Cams
1.725 Ratio S&S Rocker Arms
HAMMER PERFORMANCE Intake Manifold
HSR 48 Miunki
XR1200 Crank Conversion W/ Case Mod 34T
HAMMER PERFORMANCE Sledge+ Head Work
2.020" Intake and 1.630" Exhaust Valves
Conical Valve Springs
S&S Premium Lifters
HAMMER PERFORMANCE Billet Push Rod Bases
Barnett Clutch Hub With Scorpion Clutch
Dynatek 2000i
R&D MOTORSPORTS- TRANSMISSION WORK-REM ISF
WorldWideBearings
Patriot Defender Exhaust
Old 28th June 2018
mac93 mac93 is offline
Sportster/Buell Model: 1200
Sportster/Buell Year: 95
IMO, gearing is whatever the dyno sheet says it should be, the 30t makes a bigger difference on the smaller engine, you need more clutch spring rate on both, I’ve run 30t on a 76 in. and 90in. They both liked it. Don’t think I’d like to hand clutch the spring rate needed in the 90. I’m guessing it would be harder to get a consistent 60, Never did it so don’t know for sure. Sometimes I wonder what would happen if I went the other way on the bigger engine, but then you speed up the transmission and I’m not sure if that’s a good thing. I’m running 360#’s static now and it’s killing my hand by the end of the day. Not sure what you mean by lose out on the torque?
Old 28th June 2018
MatHormell's Avatar
I run the barnett with the 6 gold springs, its stiff for sure but with the CRF perch and its throw Its not as bad as with a stock perch. What do you mean by what ever the dyno says? As far as missing out on torque, I don't recall exactly what was said but it was something to do with the motor turning up quicker, I think he was under the assumption I do not rev as high as the 1250/75's which I could see his point but I'm turning 7500 right now and bumping up to 8k for the next round.
I do prefer a hand actuated clutch, probably isn't nearly as consistent, maybe one day I'll come around to the variables lol.
Sent from my SAMSUNG-SM-G890A using Tapatalk
Old 28th June 2018
The dyno sheet shows where the power is, shift/gear to spend as much time at as much horsepower you can. Need consistent 60’s for bracket racing, within .02 for the day, I’m sure my tune up is different from heads up racers, just my take on what works for us.
