Last Post: Racepres
0 Cycle Electric 5000 initial charge time?
0 Kick starter resistance
0 tapped adjust
Last Post: ericfreeman
0 Question for Jorgen, Aaron, ???
0 The salty debate thread.
0 Kicker shaft question
Last Post: Captain Johnny
0 1200S race bike miss at 3500-400
Last Post: Proteus
0 Fuel Pump Problems
Last Post: Lowe175
0 Which cams ?
0 truing spokes question about centering
Last Post: ThrottleBody
0 New Jagg oil cooler adapter for 2004+ Sportsters
Last Post: Randy_rots
0 Matrix brakes
Last Post: tonystylec
6 ironhead turn signals
Last Post: 19ironhead75
0 Mustang Seat FS
0 Static timing
Last Post: ftwflh
0 how to check cam postion sensor
Last Post: ftwflh
0 Hello New in the Forum
Last Post: Dosmie72
yeller1200, IronMick (78), painter (71), motobob883 (68), rickxx (66), MRCLEEN (48), Wetcheez (47), hello_shoes (40)
air cleaner, dyno, exhaust, installation, tuner
Old 11th October 2013
11bakerra 11bakerra is offline
Sportster/Buell Model: Forty-eight
Sportster/Buell Year: 2014
11bakerra is an unknown quantity at this point
Default Best Tune for my setup
Hey Guys, new to the forum and about to buy my first bike. I'll be purchasing a 2014 Forty-Eight and I have a few parts I would like installed. I've decided to go with the Vance and Hines Big Radius 2 in 2 Exhaust, and Roland Sands design contrast clarity Air Cleaner. I was going to have the dealership install and tune/dyno the bike, but they are asking an un-Godly amount. Which after-market tuner should I go with? And should I still have a shop dyno the bike? I was considering the "Vance and Hines FuelPak"...Any idea? Thanks
awilson40's Avatar
awilson40 awilson40 is offline
Sportster/Buell Model: Forty Eight
awilson40 has a brilliant futureawilson40 has a brilliant futureawilson40 has a brilliant futureawilson40 has a brilliant futureawilson40 has a brilliant futureawilson40 has a brilliant futureawilson40 has a brilliant futureawilson40 has a brilliant futureawilson40 has a brilliant futureawilson40 has a brilliant futureawilson40 has a brilliant future
NO to the fuel pak, I bought a used 2011 48 with 600 miles, V&H ShortShots and the SE aircleaner. Lots of surging at light throttle, V&H wont let you know what each cell does so you are at their mercy. I tried several changes from them with no luck. I ended up pulling the FuelPak and putting the stock exhaust back on then adding a set of X14IED's to richen it up a bit. Its better, but still surges.
I am waiting on a set of Radii SlipOns and will probably be adding a FuelMoto Micro for a tuner due to their customer service and reviews. Plus, I like the idea of their fine adjustment pots so you can make small adjustments without downloading a new map.
IMHO, you really need a tuner that you or your shop can adjust, not something that you are at the mercy of the manufacture for adjustments.
2011 Sportster 48; SE Slip-ons, OutLaw 587 AC, FuelMoto Micro EFI w/ custom Map.
CT XR rider CT XR rider is offline
Sportster/Buell Model #2: XR 1000
Sportster/Buell Year #2: 1983
CT XR rider is a glorious beacon of lightCT XR rider is a glorious beacon of lightCT XR rider is a glorious beacon of lightCT XR rider is a glorious beacon of lightCT XR rider is a glorious beacon of lightCT XR rider is a glorious beacon of lightCT XR rider is a glorious beacon of lightCT XR rider is a glorious beacon of lightCT XR rider is a glorious beacon of lightCT XR rider is a glorious beacon of lightCT XR rider is a glorious beacon of light
Get a Dynojet Power Vision from FuelMoto and you won't be sorry.
About $450 bucks
hairy hairy is offline
hairy is just really nicehairy is just really nicehairy is just really nicehairy is just really nicehairy is just really nicehairy is just really nicehairy is just really nicehairy is just really nicehairy is just really nicehairy is just really nicehairy is just really nice
Another vote here for powervision.
2007xl883l: hammer1250, crush1200 heads, 600 cams, patriot defender, powervision.
AustinXL's Avatar
AustinXL AustinXL is offline
Other Motorcycle Model: FXDL
AustinXL has much to be proud ofAustinXL has much to be proud ofAustinXL has much to be proud ofAustinXL has much to be proud ofAustinXL has much to be proud ofAustinXL has much to be proud ofAustinXL has much to be proud ofAustinXL has much to be proud ofAustinXL has much to be proud ofAustinXL has much to be proud ofAustinXL has much to be proud of
About $450 bucks
+1. You wont need a dyno ever and you'll end up with a better tune than you would get from the dealer.
Any EFI bike should always have a flash tuner purchased for it - thats the most important upgrade you'll ever buy.
Old 17th October 2013
awilson40's Avatar
I ended up going with my first choice of the Fuel Moto Micro. Its cost is in my range for right now. I might kick myself for not going with the Powervision right off the bat but I'm not planning on doing future mods and think all I need is to loose the O2 sensors and adjust fuel. Fingers Crossed. This surging around town is a pain and thats the most driving that I do.
