0 Kick starter resistance
0 tapped adjust
Last Post: ericfreeman
Last Post: XL1275
0 Question for Jorgen, Aaron, ???
0 The salty debate thread.
0 Kicker shaft question
Last Post: Captain Johnny
0 1200S race bike miss at 3500-400
Last Post: Proteus
0 Fuel Pump Problems
Last Post: Lowe175
0 Which cams ?
0 Cycle Electric 5000 initial charge time?
Last Post: USAFpj
0 truing spokes question about centering
Last Post: ThrottleBody
0 New Jagg oil cooler adapter for 2004+ Sportsters
Last Post: Randy_rots
0 Matrix brakes
Last Post: tonystylec
6 ironhead turn signals
Last Post: 19ironhead75
0 Mustang Seat FS
0 Static timing
Last Post: ftwflh
0 how to check cam postion sensor
Last Post: ftwflh
0 Hello New in the Forum
Last Post: Dosmie72
yeller1200, IronMick (78), painter (71), motobob883 (68), rickxx (66), MRCLEEN (48), Wetcheez (47), hello_shoes (40)
  #101
Old 26th April 2018
mikeLI_77's Avatar
This is directly from hammers install instructions:.
Thoroughly oil the valve springs and rocker arms after you've torqued the rocker box down. Pour engine oil all over them, and also over the pushrod end of the rocker arm, allowing oil to flow down the pushrod tube. It takes awhile for oil to get to the top end, and you do not want it running dry while the oil is making it's way up there. If you didn't do at least that I would open them up and do so.
I can tell you from personal experience that even when I filled the tubes up to the top it still took time to get to the valves and things were getting hot.
2002 XL1200C (originally)
Dyno Sheet
96.21 HP/88.70 TQ
States I Have rode through
Old 26th April 2018
jordan1200's Avatar
Well the vacume line was off on my petcock. Reconnected it and started right up. It Didn't sound bad at all. Ran only 10 seconds. I did crank it over a few times last night when the vacume line was off. Dunno if that would have helped circulate the oil some...
Jordan1200
SE XL bolt-in cams .497's
Dynatek 2000i Ignition
SE 1340 air cleaner
Old 26th April 2018
conv90's Avatar
conv90 conv90 is offline
Sportster/Buell Year: 1990
Sportster/Buell Model #2: Sportster
Sportster/Buell Year #2: 1975
conv90 has a brilliant futureconv90 has a brilliant futureconv90 has a brilliant futureconv90 has a brilliant futureconv90 has a brilliant futureconv90 has a brilliant futureconv90 has a brilliant futureconv90 has a brilliant futureconv90 has a brilliant futureconv90 has a brilliant futureconv90 has a brilliant future
Originally Posted by jordan1200 View Post
Hey I will be starting the bike tonight or tomorrow hopefully for the first time. Since the top end overhaul.
Hammer Performance has a recommended startup procedure that involves very short initial starts ie 10 seconds, cool down, 20 seconds, cool down, 30 seconds,cool down etc..
So my question is what can I do to help with the first start to circulate oil so that when I run it the first few times oil gets to the top end fast?
Dunno if in 10 seconds it will get up there?
My same experience:
Here my solution
http://xlforum.net/forums/showthread...1984838&page=2
from post #39 to 43
1990 Sportster Axtell 90 ci, CP Carrillo 3.875 30° deg pistons,STD Heads, 615V2 RedShift cams, HSR48,
Carrillo 9.638 rods
Hammer Billet Sledge air filter
Hammer Billet Manifold.
160/60ZR17 rear on Akront 4.25" Alu rim
100/90-19 front on Akront 2.50" new Alu rim
YSS 13.75 rear shocks
1975 XLH almost stock
