0 Mikuni carb
Last Post: 1Scooter
0 900cc Cylinders
Last Post: Staffords
0 Coil Resistance Question
0 Buell Blast headlight compatibility
Last Post: apotheon
0 Remember these?
Last Post: oldboy
0 1968 xlch
Last Post: vferdman
0 wavers
Last Post: bill smith
0 Cv carb jetting
Last Post: redironhead
0 Member "Wedge" Heads for 1275 Conversion
0 Nothing to See/Hear
Last Post: Tater66
0 Basket case
Last Post: Tipofthelake
0 tachometer on 2012 Custom
0 Help identifying brakes
Last Post: jharback
0 Boring intro
Last Post: jharback
0 New from Michigan
Last Post: jharback
0 Fuel Sputter & Much More
0 Rear lights
0 ultima install without VOES
Last Post: supermotolew
0 Rear wheel alignment
0 is a buell a harley
Last Post: MDT
0 Anyone using the V&H FUELPAK FP3 currently?
Last Post: SwissXL
MAJBJD (77), Jt1200r (67), 3sporty53, 69camfrk (55), nooz (46), rixta (45), saltman241 (42), Jhard206 (34), Screamin' 07 XL (34)
  #51
Old 24th July 2019
Jollly Rogers Jollly Rogers is offline
Jollly Rogers has a reputation beyond reputeJollly Rogers has a reputation beyond reputeJollly Rogers has a reputation beyond reputeJollly Rogers has a reputation beyond reputeJollly Rogers has a reputation beyond reputeJollly Rogers has a reputation beyond reputeJollly Rogers has a reputation beyond reputeJollly Rogers has a reputation beyond reputeJollly Rogers has a reputation beyond reputeJollly Rogers has a reputation beyond reputeJollly Rogers has a reputation beyond repute
My ignore list has place for you.
The ignore list is not a one way street...
Joe
Old 24th July 2019
Joe
Correct. I applaud your ability to point that out in less then 500 words.
Old 24th July 2019
rocketmangb's Avatar
Hey Admin
My post
Please lock it or delete it
Thy Sportster Come
It Shall Be Done
On Earth as it is on Salt
2006 Sportster XL1250C
Hammer 600 Cams
Big Ass CP/Hammer Pistons
Jetted 27.5 slow,182.5 Main
97 Needle,Clip posistion 3
Patriot Defender Pipe
Napa 7148 oil filter
Max Power, 111.47
Max Torque, 84.39
Best 1/4 Speed to date 115.14
Old 24th July 2019
Seems like I supplied that ramp assembly with 2 sets of balls and instructions to try both sets ?
I was also under the impression that the ramp was tested first and THEN the broken dampener plate was discovered when the clutch would not adjust
Either way I dont care !
Stop the pissing match !!
Old 24th July 2019
wedge's Avatar
wedge wedge is online now
Your delicate your ego is showing and it's obvious you like to hear yourself talk. You use sooo many words yet have nothing of merit to say. My ignore list has place for you.
Please use it.
Old 24th July 2019
wedge's Avatar
Since you were not there, maybe you could ask Richard, he and I were the ones working on the bike.
That aside, balls sliding around on the edges of the ramps would be a fail under any circumstances. Keep in mind, depending on how they slide, they would not necessarily keep their equal distance from each other.
I do not remember if there was a set of stock balls, however; we had the stock ramp, so we did have a set of stock balls available.
I didn't pursue it further at the time, because; since it was obvious that the plan had not been thought out thoroughly, and there was not enough care taken upon assembling balls that couldn't work, I was more of the mind to get known good parts in there and put the bike back on the road.
Why is the quest for knowledge a pissing match? I always follow the scientific method wherever it leads. I have proven myself wrong at times, and in my mind that is more important than any concern for my feelings. If our space program was afraid of asking the important questions, Neil Armstrong would be floating in deep space today after having missing the target by inches.
