6 ironhead turn signals
10 DEEP DIVER's JOKE
0 KR style bolt on hard tail for 78 XLCH
Last Post: 45Brit
Last Post: webman94
0 2015 883 with S&S 1200 conversion kit
Last Post: sportyone
Last Post: rocketnorton
0 93 883 Key switch and lighting
Last Post: bklyngeezer
0 Riding music
Last Post: XL1275
0 Significant exhaust pop at idle.
Last Post: firevf06
0 Cobra NH slipons
Last Post: Skeezix
0 clean spark plug
0 21 vs 22 vs 23 teeth sprocket
0 Carb fastening screw size?
0 05 carb rebuild no start
0 Accelerator nozzle and idle not right
0 The salty debate thread.
0 Hello New in the Forum
Old 12th August 2011
007XLC 007XLC is offline
007XLC is an unknown quantity at this point
I checked the diag on the speedo. All say none when i go into each category. From what i've seen online, I believe that I have a SE stage I intake. Will verify after work and let yall know. Thanks for the info so far.
Old 13th August 2011
UPDATE!!! Ok I ran the speedo codes a second and 3rd time. No codes at all. As I explained before, the backside of the intake box is not there and I can see a filter (looks like K&N but white). So I pulled the OEM oval cover off and I see a round filter. Def doesn't look stock, especially sine there is a symbol/company emblem imprinted into the steel. I didn't find a company name, but I did find a patent number. Hoped on the net and searched the patent number. A smile grew on my face at this point, the patent belongs to Arlen Ness. Therefore, I have an Arlen Ness Big Sucker intake. I believe it's just a stage I, due to the description I read that this particular intake accepts the stock OEM oval cover. OK... now that mystery is solved. The next question is, I have an aftermarket intake & exhuast. But I have no codes. To my knowledge there is not a piggyback fuel management attached to the ECM. Is it possible that the computer was flashed to work with the mods installed? Or should I tear more into the bike to find a FM module? (I looked under the battery cover and under the seat. I did not pull the battery.)
Cosmo Kramer's Avatar
Sportster/Buell Model: 1200N
Originally Posted by Nivuahc View Post
Okay, this is the second (maybe third) time I've seen something mentioned about getting codes from the speedo...
Someone care to clue this newb in? How does one go about getting codes from the speedo?
http://xlforum.net/forums/s...ad.php?t=18260
There will not be "codes" because you have a stage 1. When you go through the different sections "P" is for the ECM. When it reads "none" it means you have no diagnostic trouble codes. Press the odometer reset button and it will display the ECM part number. I thought someone on here mentioned that if you have a stage 1 reflash it will flash that instead. I could be wrong....as my memory is worst than useless!
Cosmo
I understand that the codes are trouble codes. My questions is why don't I have any? Here are all my P/N's:
P- pn 32152-07
S- pn 68924-07
SP- pn 67436-04a
I just pulled the seat and battery cover. The cable plugged into the ECM is a stock cable (has HD label on it).
Bob F's Avatar
Bob F Bob F is offline
XLF LIFEMEMBER Im retired
Is it ok to run like this without worrying about anything?
Spend $50 for a baseline Dyno pull. This should answer your questions.
I might give the dyno a shot.
I guess I jus wanna make sure I thinking right. If I have a 1200, bone stock, and I throw on an aftermarket high flow intake and exhaust. I should be getting trouble codes for a lean motor, right?
philidor1958's Avatar
philidor1958 philidor1958 is offline
philidor1958 is just really nicephilidor1958 is just really nicephilidor1958 is just really nicephilidor1958 is just really nicephilidor1958 is just really nicephilidor1958 is just really nicephilidor1958 is just really nicephilidor1958 is just really nicephilidor1958 is just really nicephilidor1958 is just really nicephilidor1958 is just really nice
P- pn 32152-07
S- pn 68924-07
SP- pn 67436-04a
Mine says:
P- pn 22718-07A
I bought mine from the dealer and they told me it was stage 1. I am about to check it out online if I can
Edit: I just did a check and got this:
HARLEY-DAVIDSON
PARTS & ACCESSORIES 22718-07A/DT XL 1200 STAGE 1 DIGITAL TECH
Ol' Monkey of Spider Skulls MC
You have to be smarter than the material object that you are dealing with.
dfarris's Avatar
dfarris dfarris is offline
Sportster/Buell Model: XL200L
dfarris will become famous soon enoughdfarris will become famous soon enoughdfarris will become famous soon enoughdfarris will become famous soon enoughdfarris will become famous soon enoughdfarris will become famous soon enoughdfarris will become famous soon enoughdfarris will become famous soon enough
you won't get any diagnostic codes, but you still may be running very lean. I would get a dyno pull to see what the air/fuel ratio is. The O2 sensors try to maintain a 14.7 AFR and that is pretty lean. If you get a fuel management system check out one that eliminates the O2 sensors.
2007 1200L Vivid Black, Mustang Wide Vintage Solo, V&H Q Series Double Barrels, SEPST, Whittlebeast hybrid shocks
Originally Posted by philidor1958 View Post
Mine says:
P- pn 22718-07A
HARLEY-DAVIDSON
My memory isn't so bad afterall!!
Cosmo, you are one of the best here with knowledge. It is a pleasure to have you on this board.
