0 Cancelling auto renew
0 Down on oil
Last Post: Billy1200
0 Koso hd-01-04 2014+
Last Post: groovemeisterus
0 CV carb running way rich!
Last Post: Mission1
Last Post: Tipofthelake
0 Front Master Cyl rebuild question
Last Post: canoli
5 Harley T-Shirts
0 I was at the gym yesterday
0 Ok, talk slowly and use small words LED tail lights
0 Swingarm Bearing Preload Question
Last Post: rocketnorton
0 Ignition advice
0 900cc Cylinders
Last Post: Staffords
0 What’s your fuel injected 1275 idle speed?
0 Easy Brackets on 93 Sporty
0 Coil Resistance Question
0 Rear sets?
Last Post: bordens
0 Rear wheel alignment
Last Post: v3ko123
0 Sprortster Softail 1200 with Edelbrock NOS
Last Post: Randy_rots
high speed, leak, overflow, super b
Old 19th May 2019
rickmodee rickmodee is offline
Other Motorcycle Model: fx
Other Motorcycle Year: 77
rickmodee is a glorious beacon of lightrickmodee is a glorious beacon of lightrickmodee is a glorious beacon of lightrickmodee is a glorious beacon of lightrickmodee is a glorious beacon of lightrickmodee is a glorious beacon of lightrickmodee is a glorious beacon of lightrickmodee is a glorious beacon of lightrickmodee is a glorious beacon of lightrickmodee is a glorious beacon of lightrickmodee is a glorious beacon of light
Default super b overflow
Im having a situation with my super b.
first off i have a velocity stack on it.
While riding the bike
as soon as i get into 4th gear and start traveling at higher speeds, I notice im losing gas through the overflow.
(this only happens in 4th gear)
while riding around in stop and go traffic around town... 1st, 2nd, 3rd gear. no sign of gas coming from the overflow. nor does it happen while at a light or idling on its kickstand
i checked to see that the float is properly positioned.
as well as it is not hanging up on the pin the float hangs from. (i originally believed it was the pin hanging up the float cause i had bought an aftermarket rebuild kit that need some massaging to properly function.
not sure why wind would make it do that unless it had something to do with negative pressure or forming some sort of a vacuum.
2000 xl,1975 xlch
Old 20th May 2019
Does the Velocity stack block the bowl vent passage?
Old 20th May 2019
cazz1000 cazz1000 is offline
Sportster/Buell Model: xlx
good call rick 3 holes with screws velo maybe blocking something ,,if his float is right,,, don,t know,,,, u gotta clean the side air passage,,, not with drill bit don,t make it no larger ,,, think bread tye and clean it,,, get the crud out ,, that side passage run,s deeper than u know
Old 22nd May 2019
It does not block the vent bowl passage
Old 22nd May 2019
SHAKY DAVE's Avatar
SHAKY DAVE SHAKY DAVE is offline
Sportster/Buell Model: XLX
Sportster/Buell Year: 83
Sportster/Buell Year #2: xlh
SHAKY DAVE is a name known to allSHAKY DAVE is a name known to allSHAKY DAVE is a name known to allSHAKY DAVE is a name known to allSHAKY DAVE is a name known to allSHAKY DAVE is a name known to allSHAKY DAVE is a name known to allSHAKY DAVE is a name known to allSHAKY DAVE is a name known to allSHAKY DAVE is a name known to allSHAKY DAVE is a name known to all
does the enrichener seal good when its off?i've had that problem with the super b on my race bike,same symptoms.havent figured out why yet and that's with a new and the old enrichener
Old 22nd May 2019
rokytnji's Avatar
rokytnji rokytnji is offline
Sportster/Buell Year #2: 1983
Other Motorcycle Year: 1990
Angle of Super B to engine? Not pointing down?
Traveled to
Old 22nd May 2019
Toejam503's Avatar
Sportster/Buell Year #2: 1981
Maybe it's wind velocity, sucking the gas out of the throat of the carb, because of the shape of the Velocity stack. In 4th your going at higher speeds and the wind travels over the velocity stack, causing sort of a turbulence over it, sucking the gas out.
Take some tape and block/cover 1/2 the Velocity stack opening and see if it still does it, you may have to block it at different points on the stack.
Old 22nd May 2019
It’s nice to know I’m not alone! yes, I believe it to be seating properly.
Old 22nd May 2019
Yes. I’m running support bracket on bottom bolt of manifold and carb is perpendicular with the ground
I have a 7” filter just need to pick up a new element for it. Do a quick swap, At least that way I could rule out the vstack.
Old 22nd May 2019
Bike Builder
Sportster/Buell Year: 1964
Sportster/Buell Year #2: 1971
Originally Posted by toejam503 View Post
maybe it's wind velocity, sucking the gas out of the throat of the carb, because of the shape of the velocity stack. In 4th your going at higher speeds and the wind travels over the velocity stack, causing sort of a turbulence over it, sucking the gas out.
Take some tape and block/cover 1/2 the velocity stack opening and see if it still does it, you may have to block it at different points on the stack.
+1
