0 Opinions
Last Post: Racepres
0 Static timing
0 Which cams ?
0 Fuel Pump Problems
Last Post: Lowe175
0 Front end restoration
Last Post: Dosmie72
0 Hello New in the Forum
0 Accelerator nozzle and idle not right
Last Post: hexnut
0 Kicker shaft question
Last Post: Captain Johnny
0 Spitfire motorcycle 2 into 1 Blaster
Last Post: Bmyers
0 The salty debate thread.
Last Post: Uberstorm
Last Post: XL1275
14 How To: View HD Part #'s 1991-2010 - All Models - With Part #'s and Exploded Views!!
Last Post: Eddie65
Last Post: MikeBel
0 Kick starter resistance
Last Post: metal88
Last Post: Proteus
0 19" Tire w/23" Overall Diameter???
0 Smacked a deer last night
hot, ignition, timing, voes
Old 16th August 2019
groovemeisterus's Avatar
groovemeisterus groovemeisterus is offline
Sportster/Buell Model: XL883-1200 Branch Build
groovemeisterus is a splendid one to beholdgroovemeisterus is a splendid one to beholdgroovemeisterus is a splendid one to beholdgroovemeisterus is a splendid one to beholdgroovemeisterus is a splendid one to beholdgroovemeisterus is a splendid one to beholdgroovemeisterus is a splendid one to beholdgroovemeisterus is a splendid one to beholdgroovemeisterus is a splendid one to beholdgroovemeisterus is a splendid one to beholdgroovemeisterus is a splendid one to behold
Question Replaced bad VOES... Engine sounds weird when hot and idle
Long time no post. I noticed my VOES went bad last year after replacing piston rings.
Long story short, bought a new VOES, and when running hard and fast the engine runs great... but when slow down, or come to a stop light or stop sign, or basically engine is idling after a long hard fast run and engine is hot, it sounds like is over heating and exhaust signature sounds wrong kinda like pinging maybe?
Once I get going on long road and on throttle and up to speed, is like engine is back to normal.
I may have bought the wrong Vacuum setting VOES, or got the wrong setting.
I know there are other threads on VOES, and what it does, but how do I know I have the right Vacuum setting on the VOES?
I think I have the wrong setting. With symptoms described above... would I need a higher setting Vacuum VOES, or a lower Setting VOES?
I could adjust it, and or add a switch to the wiring to manually activate or deactivate it during the weird sound of pinging or engine just getting to hot and ignition timing not greatest to try something, but would rather ask question first before I try.
My engine is highly modified, heads ported, etc, and should state in signature.
With higher altitude in Sturgis, doesn't do it as much... but in lower altitude in Indiana, does it way more. But only thing changed was the VOES.
Would I need a higher Vacuum setting VOES, or a lower Vacuum setting VOES from symptoms, or does the symptoms not imply the VOES is at wrong Vacuum setting?
I am running the Daytona Twin Etc 1005s-EX cone ignition module that has changed from my signature. With Setting 0 - Dual fire multi spark disabled, and next set to slope of 7.
Maybe my ignition cone slope is not the right slope also?
Thanks for the feedback
883 XL Y2K - BLACK,Ported Manifold,HSR 42mm Carb,Branch #5 Ported 883 Heads,Bob Woods W8S 0.590" Cams, SE -0.050" Perfect Fit Pushrods,SE 1200 Ignition Module ,Vance & Hines Straight Shot Exhaust,07 SE Air Cleaner,SE 40,000V Red Perf Coil,883 Jugs Precision Bored for Branch 30º Domed Pistons,& One Big Smile ;o), ~83TQ, ~83HP for now.
Last edited by groovemeisterus; 16th August 2019 at 04:00.. Reason: Added possibly setting to different slope on Ignition module
Here's a thorough section in the Sportsterpedia on the VOES:
http://sportsterpedia.com/doku.php/t...lectric_switch
When replacing the VOES, Did you change the timing curves in the ICM? Did you adjust the base timing when the VOES was failing?
Awesome. Thanks for those links. First on VOES really help explain things. Need to print out and add to my manual for future reference.
Sportster/Buell Year: 1988
You need to connect a vacuum gauge and test how much negative pressure before it switches compared to the book spec. It can have a big effect on running.
Old 20th August 2019
Question
I already did with a vacuum gauge and an multi meter. VOES switches on at 6" vacuum.
I put a Y connector and hooked up the vacuum gauge with the VOES to see while engine is warmed up and running at idle where my bike vacuum readings are at on the scale.
With the below video of gauge and bike running, looks like vacuum goes below 6" to 5". Which makes be think I need to adjust VOES to about 4.5" or so to stop pinging since it seems to be right on the border swithing curves back and forth just during idle.
The sportsterpedia says if set to low, then remain on more advanced curve for too long under mid-load acceleration and pinging will occur.
When going fast engine seems good, but when have to slow and cruise after long distances, like at a stop sign or light, or just slowing down cause of speed limit lower, i believe my bike is pinging or engine is sounding like it is over heating, the exhaust note changes.
So i believe my VOES needs to be set from 6" set point to a 4.5" set point.
Video of slo mo vacuum gauge when engine was warmed up and at idle.
https://youtu.be/dntWQvw3SUU
6" sounds high, more like Big twin. 4.5' sound more likely but set the VOEs to what your HD destruction manual says is correct.
You will need to carefully dig out the sealant plug and reset it. Don't forget to let the new sealant cure before you run the engine again.
Old 21st August 2019
Set to 3.5" last night and resealed.
Also read that set points should be 3.5"-4.5" also.
Last one went bad and this is new one. Maybe got the wrong one shipped.
Tomcatt Tomcatt is offline
Dazed & Confused
Other Motorcycle Year: 2015
You want stability. By that I mean a setting that's always on or always off at the vacuum you pull idling. Then tune accordingly.
You might also use your gauge and try optimizing your idle. Adjusting the mixture to get the highest (vacuum) reading you can at idle. Might also add some restriction to the hose to your gauge to damp its' fluctuations some. Aside from being easier to read it will help keep your gauge from self destructing. Those needle swings are hard on them.
If you have an analog VOM (one with a needle) you can hook it to the VOES and see if it's switching at idle. That can make tuning a nightmare. I don't know how much damping they have built in.
If you already knew this just ignore me.
Thanks
