0 Need help with S&S GB carb
Last Post: RKN
0 7” Headlight conversion on solid mount
Last Post: Moon Wolf
Last Post: Traxx
14 98 just upgraded to 1250 from 1200
0 ,09 Iron883N idling weird, sputters on accelerating from idle or low revs.
Last Post: tussuck
0 Show us your Bike next to a Bridge
Last Post: Lone Rider
14 Post your Bike in a Cemetary Pic
0 New from Washington
Last Post: DBH
8 Never Forget
Last Post: sglock45
0 Carb flooding
0 question about XLCH manuals
0 2019 York Bike Week (9/18-21)
0 Chain kit
Last Post: wrkdWS6
0 dual carb heads on ebay
0 Shoei GT-Air II FF Helmet Review
0 2011 Nightster--First Impressions
0 Bad Primary Oil Leak
  #51
Crash7557's Avatar
Crash7557 Crash7557 is offline
Other Motorcycle Model: HD Sprint SS-250
Other Motorcycle Year: 1967
Crash7557 has a reputation beyond reputeCrash7557 has a reputation beyond reputeCrash7557 has a reputation beyond reputeCrash7557 has a reputation beyond reputeCrash7557 has a reputation beyond reputeCrash7557 has a reputation beyond reputeCrash7557 has a reputation beyond reputeCrash7557 has a reputation beyond reputeCrash7557 has a reputation beyond reputeCrash7557 has a reputation beyond reputeCrash7557 has a reputation beyond repute
168 miles later and can anyone tell me what's wrong in this picture?
Sent from my SM-G960U using Tapatalk
"I love the mechanicalness of it"-Indian Larry
harley506d's Avatar
Sportster/Buell Model: 1200c
I see a broken ring and maybe valve collets missing?
XL Ed's Avatar
XL Ed XL Ed is offline
Any cylinder damage?
Crash7557's Avatar
Survey says "broken ring" is the number 1 answer. No missing collets. It's all there.
Cylinder is scuffed up pretty good. Piston scuffed pretty good from the steel shavings. The oil I drained (HD 20-50) was pewter gray with speckles. If it were paint it would be a nice color to spray on.
Crash7557's Avatar
So the bike had a dead spot 3/4 to full throttle that would improve when I rolled off the throttle slightly. Symptom of rich. Bogged with the 200 main jet. Bought the three smaller consecutive jets (195,190,185) for tuning. On the ride from a few weeks ago where I was pictured parked with a red 883 was done with 200 jet. Installed the 190 jet and the power up in the range was improved as in it did not bog but instead the acceleration was flat from 3/4 to full and I did a highway pull for miles at 65mph and around town for approximately 40 miles total.
I believe I got greedy and ran too lean. I changed to the 185 jet to see any improvement. Rode 7 miles home on a cooled down motor. No issues seen. Next day started to ride the same route I did the first time. 15 miles in the bike bogged, came back, bogged, then wouldn't stay running. Stopped it and the kicker wouldn't move the crank to start it. The valved breather blew apart and on top of the bike and the insides were blown out (I found them on the road and wedged in the frame) oil was on top the motor.
When I got it home I let it cool down over night expecting a full seizure. Disassembled and found the piston not seized but the connecting rod WAS seized in position with the crank assembly. I got it moving barely but it it quite apparent that the iron shavings have done their damage to the bearings. Tons of play both side to side and back and forth with the connecting rod and who knows where else. Not a simple fix and I'm not an engine builder so I'm going to leave it to a professional. I'll let you all know what happens for those still interested in this funny little italian one lung's story.
yea, it's all apart
i know if you can tear it down to that level, the rest is a snap for you. if it is a pressed crank, easy-peasy.
