0 Need help with S&S GB carb
Last Post: RKN
0 7” Headlight conversion on solid mount
Last Post: Moon Wolf
Last Post: Traxx
14 98 just upgraded to 1250 from 1200
0 ,09 Iron883N idling weird, sputters on accelerating from idle or low revs.
Last Post: tussuck
0 Show us your Bike next to a Bridge
Last Post: Lone Rider
14 Post your Bike in a Cemetary Pic
0 New from Washington
Last Post: DBH
8 Never Forget
Last Post: sglock45
0 Carb flooding
0 question about XLCH manuals
0 2019 York Bike Week (9/18-21)
0 Chain kit
Last Post: wrkdWS6
0 dual carb heads on ebay
0 Shoei GT-Air II FF Helmet Review
0 2011 Nightster--First Impressions
0 Bad Primary Oil Leak
Old 6 Days Ago
sportymike02's Avatar
Sportster/Buell Model: 1200c
Sportster/Buell Year #2: 1979
sportymike02 has a reputation beyond reputesportymike02 has a reputation beyond reputesportymike02 has a reputation beyond reputesportymike02 has a reputation beyond reputesportymike02 has a reputation beyond reputesportymike02 has a reputation beyond reputesportymike02 has a reputation beyond reputesportymike02 has a reputation beyond reputesportymike02 has a reputation beyond reputesportymike02 has a reputation beyond reputesportymike02 has a reputation beyond repute
Default Removing Front Blinkers
I don't care about doing it the "right" way. Can I just cut & tape the wires?
Old 6 Days Ago
NGOT8R NGOT8R is offline
Sportster/Buell Year: 2019
NGOT8R is a splendid one to beholdNGOT8R is a splendid one to beholdNGOT8R is a splendid one to beholdNGOT8R is a splendid one to beholdNGOT8R is a splendid one to beholdNGOT8R is a splendid one to beholdNGOT8R is a splendid one to beholdNGOT8R is a splendid one to beholdNGOT8R is a splendid one to beholdNGOT8R is a splendid one to beholdNGOT8R is a splendid one to behold
You can do that, but you might get turn signal open codes tho. If you're set on doing it, I suggest using heat shrink over the ends of the wires instead of tape.
Old 6 Days Ago
NLXL's Avatar
NLXL NLXL is offline
Sportster/Buell Model: XL883DLX
I'm not sure if a 2002 model was already that smart in giving that codes(?). Well, if in doubt, just remove the bulbs first and see what happens.
https://www.itchyboots.com/
Old 6 Days Ago
Here's the Sportsterpedia section on Turn Signals:
If you do that, you'll likely get no flash - to address the current expectation of the TSM, you'll need to add load resistors so the TSM flashes correctly...
Remove the bulbs and see what you get...
Old 5 Days Ago
seajay's Avatar
seajay seajay is offline
Sportster/Buell Year: 04
I removed mine years ago, taped and stuck wires under the tank. No problems with the rear blinkers or flashers.
04/07 1275 BFH heads .590 cams S&S 1.725 rockers S&S premium lifters BDL+15% clutch TC88A HSR-45 S&S 3" ac LSR 2-1
Old 5 Days Ago
BKB's Avatar
BKB BKB is offline
In some states, if the bike came from the factory with turn signals, it may be illegal to not have them. Might want to check before you remove them.
Brian '09 1200C (black of course), 19" front wheel, det. windshield, Sundowner, mini apes, Big Sucker, x14IEDs, 12.5" Progressive 412's, Intiminators, Gronk mod
Old 5 Days Ago
I removed the bulbs & hit the switch - rear lights lit & stayed lit.
I guess load resistors & heat shrink tube are in my future.
no mc inspection in NJ so I don't think anyone's gonna notice or care that they are gone
thanks guys
Old 5 Days Ago
Air-Cooled Forever
Here in ND, we don't have MC or Automobile safety inspections. If you get pulled over for anything, speeding, noise, etc. the cops will give you an equipment or safety ticket on top of your speeding ticket and require you to get a state inspection from the Highway Patrol. If you don't pass the inspection, they'll take your license plate and return it once you pass.
A lot of times they'll just give a verbal warning so they don't have too much paper work.
Do you feel Lucky?
