0 Ignition advice
8 Inexplicable miss
0 Chinese S&S carbs
0 normal shifter shaft wobble
0 Bandanas
0 Top end failure
Last Post: Mission1
0 XR mutt race bike progress
Last Post: Scott
5 Eye Protection When Riding?
0 1992 XL ignition explained
Last Post: Bwf347
0 New guy from IL
0 Front Brake Upgrade
Last Post: keithnh
0 Info needed on mini sumps.
Last Post: Randy_rots
0 Coil readings
Last Post: Billy1200
0 3/4” Axle Drum Brake ??
0 Inherited Ironhead
Last Post: Akdawg
0 Noise and rod play
Last Post: Vic8028
Old 17th April 2012
Stocker's Avatar
Stocker Stocker is offline
Sportster/Buell Model: 883L (Well not really)
Other Motorcycle Model: A barn full of bikes
Stocker has a reputation beyond reputeStocker has a reputation beyond reputeStocker has a reputation beyond reputeStocker has a reputation beyond reputeStocker has a reputation beyond reputeStocker has a reputation beyond reputeStocker has a reputation beyond reputeStocker has a reputation beyond reputeStocker has a reputation beyond reputeStocker has a reputation beyond reputeStocker has a reputation beyond repute
Default "72" bars? Part #?
Are the bars that are on the new "72" the standard 10 "inch" mini apes are do they have a different part number? "Preciate the help.
Old 20th April 2012
dave76's Avatar
dave76 dave76 is offline
Sportster/Buell Model: Sportster XLH 1200
Sportster/Buell Year: 1990
Sportster/Buell Model #2: Sportster XLH 1000
Sportster/Buell Year #2: 1976
dave76 is a splendid one to beholddave76 is a splendid one to beholddave76 is a splendid one to beholddave76 is a splendid one to beholddave76 is a splendid one to beholddave76 is a splendid one to beholddave76 is a splendid one to beholddave76 is a splendid one to beholddave76 is a splendid one to beholddave76 is a splendid one to beholddave76 is a splendid one to behold
Probably either wideglide bars PN 56079-93T this bar is 10" high and 32" wide, or Sportster narrowglide bar PN 56563-95, which is 9.75" high and 31.50" wide. Not sure exactly which one though.
1990 1200 Sportster, Cycle Shack drag pipes, XLC forward controls, Zippers Billet 4 speed trap door.Update, 86 1100 heads, NRHS 1250 cylinders, Andrews V4 cams, and Compufire Elite 1 ignition. 07 Buell oil pump, Complete Andrews 4 Speed gears and shafts, Barnett Scorpion clutch. HHI 3' mid glide trees. HHI 6 piston front caliper, H-D floating rotor.
Old 20th April 2012
Stocker's Avatar
Thanks Dave: Either or should work and look decent. I'm tired of leaning forward with the stock buckhorns and forward controls. And don't want to go the pullback riser route.
