8 Inexplicable miss
0 normal shifter shaft wobble
0 New guy from IL
0 Coil readings
0 Front Brake Upgrade
0 1992 XL ignition explained
0 3/4” Axle Drum Brake ??
Last Post: LLTattoo
5 Eye Protection When Riding?
0 Ignition advice
0 Chinese S&S carbs
0 Bandanas
0 Top end failure
Last Post: Mission1
0 XR mutt race bike progress
Last Post: Scott
0 Info needed on mini sumps.
Last Post: Randy_rots
0 Inherited Ironhead
Last Post: Akdawg
0 Noise and rod play
Last Post: Vic8028
Old 23rd December 2015
dencor dencor is offline
Sportster/Buell Model: xl883
dencor is a splendid one to beholddencor is a splendid one to beholddencor is a splendid one to beholddencor is a splendid one to beholddencor is a splendid one to beholddencor is a splendid one to beholddencor is a splendid one to beholddencor is a splendid one to beholddencor is a splendid one to beholddencor is a splendid one to beholddencor is a splendid one to behold
Default "Burping" the oil drain tube
How important is "burping" the oil drain tube after doing an oil change? I've heard various opinions.
mikeLI_77's Avatar
The manual says to do it to prevent cavitating the oil pump which I don't see how that can happen since the oil pump is not a diaphragm pump. I do it. Whether or not it actually helps or prevents anything from happening I doubt it. I have heard people who don't even fill there oil filters up and have had no problems.
2002 XL1200C (originally)
Dyno Sheet
96.21 HP/88.70 TQ
States I Have rode through
schwede's Avatar
schwede schwede is offline
Sportster/Buell Model: 1200 low
Sportster/Buell Year: 08
Other Motorcycle Model: fatboy
Other Motorcycle Year: 2010
schwede has a reputation beyond reputeschwede has a reputation beyond reputeschwede has a reputation beyond reputeschwede has a reputation beyond reputeschwede has a reputation beyond reputeschwede has a reputation beyond reputeschwede has a reputation beyond reputeschwede has a reputation beyond reputeschwede has a reputation beyond reputeschwede has a reputation beyond reputeschwede has a reputation beyond repute
Only takes a few minutes, don't lose but a tad of oil. ..my manual calls for it, so I've always done it. ..and I've always put some oil in the filter...maybe I'm a blind sheep...
Schwede
Biker Roots... some are born, some are grown, others will never know...
Old 24th December 2015
XLXR's Avatar
XLXR XLXR is offline
Try this the next time you change your oil. Drain oil and change filter. Replace drain plug and re-fill oil tank with oil. Let it sit over night to see if air in the line floats up to the top. Then remove drain plug. If air comes out, you should burp it. If oil comes out, no need to burp it. Let us know what happens.
I have never burped my 2006. I have added oil without putting the drain plug back, but that is a different issue.
ParrotHead's Avatar
I am the great Cornholio!
Other Motorcycle Year: 1974
I never have done it and have 168,000 miles on my Sporty.
John Wayne - "The Shootist"
Click here
to listen to my interview on the Chasing the Horizon Podcast
racerwill's Avatar
Sportster/Buell Model: XLRR
Sportster/Buell Year: 91
Sportster/Buell Year #2: 80
Cool
you've never burped the oil drain in 168000 miles but last month you broke a shock mount......coincidence?? I don't think so....Homey don't play that
in the last ten years I've put 100,000 on my '91 and haven't burped it yet but before then, I never did
Ww
master wizard
RIP Mr Jimi
"All The Way"
ParrotHead's Avatar
Ww
I'll bet that was it! And maybe the cause of my swing arm bearings going after only 35,000 miles
toe's Avatar
toe toe is offline
Sportster/Buell Model: 883C
toe has a reputation beyond reputetoe has a reputation beyond reputetoe has a reputation beyond reputetoe has a reputation beyond reputetoe has a reputation beyond reputetoe has a reputation beyond reputetoe has a reputation beyond reputetoe has a reputation beyond reputetoe has a reputation beyond reputetoe has a reputation beyond reputetoe has a reputation beyond repute
The oil is expensive.
I want every last drop out of the quarts of oil, so each quart drains for 10 minutes.
I figure that by the time the oil is in the tank, any air bubble would be long gone............
Ed
The Only Y2K dual-set 883C
So Cal
gusotto's Avatar
gusotto gusotto is offline
Sportster/Buell Model: XL1200
Other Motorcycle Model: Harley Ultra Classic
Other Motorcycle Year: 2007
gusotto has a brilliant futuregusotto has a brilliant futuregusotto has a brilliant futuregusotto has a brilliant futuregusotto has a brilliant futuregusotto has a brilliant futuregusotto has a brilliant futuregusotto has a brilliant futuregusotto has a brilliant futuregusotto has a brilliant futuregusotto has a brilliant future
Schwede
I do the same.
I follow the service manual (everyone should own one) and figure the engineers should know what they are talking about.
Adding oil to the filter also helps.
Do it before you start and you'll see that oil sucked into the filter before you get ready to install the filter.
I baby my bike.
Per Service manual.....
Remove Corbin clamp and drain hose from rear muffler mount lug. Allow a small amount of oil to flow from hose before reconnection. This action removes air from the drain hose and prevents the possibility of oil pump cavitation.
They didn't add that info because they had room in the SM. Must be a reason.
It doesn't take much added time.
My hose doesn't have the clamp tightened after I add the oil. Just pushed into place. Just takes a second to pull the hose off and watch the small amount of oil flow. It doesn't need anymore than a dribble.
Then I tighten the clamp.
"Beer has food value but food has no beer value."
2002 XL 1200 SE A/C & SE mufflers Mustang seat, Harley Hard Bags, Detachable Backrest w/Luggage Rack Kuryakyn Stop/Turn Signal Controller w/pulse brake, Pegs and Stirrups, Forward Controls, Memphis Fats Windshield
Sportster/Buell Year: 1991
I think the 1991 does not have the same drain line design as others have on newer bikes. My FSM mentions loosening the outlet line from the pump to filter in case of loss of prime, but I've never had an issue in 25 years.
John
