0 Halloween 1250 Conversion
0 Do you Run a Fuel Filter?
Last Post: ZCarFan
0 Hello from LA area
0 Hello everyone
0 Hi everyone
5 Which backrest gives more space for passenger?
0 Hello from Holland
0 Ran out of gas.
Last Post: Marsikus
0 One More Ohio Meet & Eat?
0 Round Air Cleaner Poll
Last Post: maltesefalcon
0 1969 Shifter shaft bushing
Last Post: Doc308
0 add oil and ride
0 Brakes?
Last Post: Dariusz
5 about the 1999 Sportster Right Fork converting to dual brakes
3 Ironhead Pictures Thread
0 Gear Spacing Question
0 WTS: Forward Controls 2004-13
Last Post: XL1275
Last Post: Marsikus
Last Post: Samedward
Old 19th April 2019
Toms99tj's Avatar
Toms99tj Toms99tj is online now
Toms99tj is a splendid one to beholdToms99tj is a splendid one to beholdToms99tj is a splendid one to beholdToms99tj is a splendid one to beholdToms99tj is a splendid one to beholdToms99tj is a splendid one to beholdToms99tj is a splendid one to beholdToms99tj is a splendid one to beholdToms99tj is a splendid one to beholdToms99tj is a splendid one to beholdToms99tj is a splendid one to behold
Default Turn signal mirrors
I got a set of mirrors with turn signals in them and finally hooked them up. Well the left side works perfect but the right side wont work. I thought it was bad so I ordered another set. They came in today and i went to install it and the same thing, nothing. Its a one wire hook up. I spliced right into the turn signal wire. Any have an idea of why just the right side wont work?
Old 19th April 2019
The circuit needs to be a complete circle back to the battery - You need to check the grounding of your mirror to see if it is making a circuit back to the battery negative post...
Got a meter? Put it on OHMS scale and put one meter lead on the mirror stem & the other on the battery negative - should read 0-ohms - meaning it is connecting with the battery negative...
Alternatively, you can get a piece of wire long enough and place one end on the battery negative & the other end on the mirror mount or mirror stem... Does the TS work then?
Perhaps a manufacturing defect on the right side mirrors - Did you precheck them to see if they work off the bike? Connect the wire to the positive battery post, touch the mirror stem to negative battery post... Light should be on steady... (DON'T SHORT THE BATTERY TERMINALS TOGETHER WITH THE MIRROR!)
1995 models did not have a ground strap from the frame to the handlebars because the Turn Signals & other lights had dedicated ground wires to them from the main harness... Your bars or control housings may not be grounding...
Old 19th April 2019
Sportster/Buell Year: 1991
There are two wires that go to the stock front signals. One for a running light, the other for the signal. Did you perhaps connect to the wrong one?
John
Old 19th April 2019
XL Ed's Avatar
XL Ed XL Ed is offline
Try the right mirror o the known good left wire.
Old 19th April 2019
Toms99tj's Avatar
It was a ground. The left side lever must be grounded and the right side isnt. I hooked up a wire with any eye ring to the mirror stud and it works perfect now. Thanks yall
