0 Hello from the Northeast US.
0 Rico Lutsey aka Rico 05R
Last Post: ed_in_az
0 crank case breather
Last Post: trucker2800
Last Post: RDHenley
0 Tank Dent Repair Western NC
Last Post: BlackBikeDave
0 cleaning your sporty
Last Post: RDHenley
Last Post: norski
Last Post: groovemeisterus
0 DK Custom '19 Summer Adv. Riding to where Titanic Sank -Newfoundland Island & More
Last Post: 72 Ironhead XLH
0 Rear sets?
Last Post: Scott
Last Post: motorend
Last Post: 83XLX
0 Fatster Project
Last Post: t.c. Johnson
0 Bobtailing a sportster
Last Post: 45Brit
0 Flame's New 1989
Last Post: SLW210
0 Talking dog
0 Harley Davidson Sportster: 60 years by Allan Girdler
doughboy (66), tinman (64), mofo (57), JAFI (56), Topgun (54), Hogwylde (54), Pay Toilet (53), grwhite038 (51), JWG883 (50), sorryifitburns (46), Leibniz (44), higgins14 (42)
79 has no transfer valve so blow by should not be getting into the primary.
"Hey, I said SHOULD!"
GA_Ironhead has a brilliant futureGA_Ironhead has a brilliant futureGA_Ironhead has a brilliant futureGA_Ironhead has a brilliant futureGA_Ironhead has a brilliant futureGA_Ironhead has a brilliant futureGA_Ironhead has a brilliant futureGA_Ironhead has a brilliant futureGA_Ironhead has a brilliant futureGA_Ironhead has a brilliant futureGA_Ironhead has a brilliant future
What about via a bad sprocket seal?
Merely dying will not get your name removed from the enemies list!
Generally a bad sprocket seal will provide more clues. The trans would be making oil and the motor loosing oil.
But the owner may not be paying attention because the motor is smoking(using oil).
A motor that is smoking may likely have problems that cause other issues especially leaks, obvious mechanical issues like smoke would normally be addressed first.
ezmerf's Avatar
ezmerf ezmerf is offline
Sportster/Buell Year: 1974
Sportster/Buell Model #2: XLS
Sportster/Buell Year #2: 1980
ezmerf has much to be proud ofezmerf has much to be proud ofezmerf has much to be proud ofezmerf has much to be proud ofezmerf has much to be proud ofezmerf has much to be proud ofezmerf has much to be proud ofezmerf has much to be proud ofezmerf has much to be proud ofezmerf has much to be proud ofezmerf has much to be proud of
I would recheck the valve adjustment. I'm thinking it's your rear cylinder doing the oil in the tail pipe and I think it is leaking down when bike is sitting not running and when you start riding and muffler gets hot it starts puffing smoke.If it was leaking enough oil to be in tail pipe it would be fouling the plug bad.Just some ideas.
Murphy's Law :vvet:
