Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > VENDORS > CV Performance
0 Hydrostatic fuel gauge
Last Post: Andy Hog
Last Post: Desertfox
Last Post: exexpat93
Last Post: 83XLX
0 Installing jugs finally but another Q
0 1968 ex barn dweller thread
0 Sifton cams on stock 74 XLCH
0 Opinions on Mallory unilite ignition
Last Post: Heff
0 my sunday driver...
Last Post: 84rzv500r
0 Microsquirt?
Last Post: Curbside
0 S&s
0 Better Brakes
7 Ironhead yes or no
Last Post: iBloke
0 fork oil change with Ricor intiminators
0 Li/Ion battery in '03
0 Tools
Last Post: denguy
0 18” rear wheel mag
Last Post: Yourstrulythom
wlm (57), Greg81XLH (55), saylor01 (54), Alicia (52), latnyte (51), antonini (43)
Old 11th July 2014
sickboy13xx sickboy13xx is offline
Sportster/Buell Year: 81
sickboy13xx is on a distinguished roadsickboy13xx is on a distinguished roadsickboy13xx is on a distinguished road
Default cv carbs
i have an 81 iron head have had carb issues since i got it so i figure ill get a new one well looking on ebayi find one says its from an 81 so i bid on it well i notice no one else is so i really start looking at it and realize its a cv well question is will it work on my iron head or will it be too much for it i have drag pipes so right there i would have had to jet the old one.i know ill have to get a manifold adapter but otherwise will it be ok??
Old 11th July 2014
sportsterdoc's Avatar
Be best to post this in the Ironhead section.
I only know a small bit of Ironhead carb history
1966 Tillotson diaphragm carb
1972 Bendix/Zenith carb
1981 AMF buyback...what carb was used?
The EVO history is
1986 34 mm Keihin
1988 40 mm Keihn CV, no accelerator pump
1988 40 mm Keihn CV, with accelerator pump
So, what carb was on your bike?
I would not be concerned about too much carb, but will it fit the intake manifold or will a new manifold or adapter be needed, etc.
Old 11th July 2014
CVPerformance CVPerformance is offline
Sportster/Buell Model: XLH 883>1200
Sportster/Buell Year: 1988
Other Motorcycle Model: FXE
Other Motorcycle Year: 1976
CVPerformance is a splendid one to beholdCVPerformance is a splendid one to beholdCVPerformance is a splendid one to beholdCVPerformance is a splendid one to beholdCVPerformance is a splendid one to beholdCVPerformance is a splendid one to beholdCVPerformance is a splendid one to beholdCVPerformance is a splendid one to beholdCVPerformance is a splendid one to beholdCVPerformance is a splendid one to beholdCVPerformance is a splendid one to behold
If it truly is a CV carburetor from a Harley then it is plenty suitable for your Ironhead. You will need to adapt the slip/spigot style carb to your flange style manifold using an adapter, plus you need to make or find a bracket to hold the carb in place. Beware of some carburetors referred to as "CV" on ebay. You could inadvertently end up with a carburetor made for another model (Kawasaki or similar). Also avoid any CV carburetor that does not have the accelerator pump which was only made in 1988. Later model Harley CV's are the best candidates.
Old 11th July 2014
its a harley keihn cv typeoriginally it has the keihn butterfly and i know i have to buy the adapter was just unsure if it would be ok but sounds like im good thank you!!wwill post pics and hoew i make out
