0 Restoring stainless exhaust back to new?
Last Post: beard.tailor
0 My 08' Nightster
0 S&S Super E Carb
0 Nup 1009 (Bearing)
0 Generator conversion kit question
Last Post: 77IRHD
Last Post: retread08
0 front brake caliper interchange question
Last Post: JacksBrother
0 New to me 55kh
Last Post: jp2code
0 so it's officially ended
0 AGM battery for 76' XLH
Last Post: forqueue
Last Post: Clevspeed
Last Post: ReddTigger
Last Post: Nitro57xl
Last Post: Cablejudge
0 Sportster book
Last Post: LLOYD883
Last Post: LLOYD883
Last Post: Nicktater
moe (76), demgdaj (70), Playtoe (65), shanneba, Charlie Allen (61), the cowboy way (61), P-Diddly (58), Utahsporty (57), evo-pete (56), stf420 (55), NevadaRob (53), Punisher (51), Razor_Reznor (46), Paycheck (43), jfs92579 (41)
dual fire, hot, oil, single fire, temperature
  #131
groovemeisterus's Avatar
groovemeisterus groovemeisterus is offline
Sportster/Buell Model: XL883-1200 Branch Build
groovemeisterus is a splendid one to beholdgroovemeisterus is a splendid one to beholdgroovemeisterus is a splendid one to beholdgroovemeisterus is a splendid one to beholdgroovemeisterus is a splendid one to beholdgroovemeisterus is a splendid one to beholdgroovemeisterus is a splendid one to beholdgroovemeisterus is a splendid one to beholdgroovemeisterus is a splendid one to beholdgroovemeisterus is a splendid one to beholdgroovemeisterus is a splendid one to behold
Understood.
I'm waiting to see the pump carnage.
Will post pictures of pump carnage when get all bottem end buttoned back up while waiting for heads and cylinders and pistons to return.
883 XL Y2K - BLACK,Ported Manifold,HSR 42mm Carb,Branch #5 Ported 883 Heads,Bob Woods W8S 0.590" Cams, SE -0.050" Perfect Fit Pushrods,SE 1200 Ignition Module ,Vance & Hines Straight Shot Exhaust,07 SE Air Cleaner,SE 40,000V Red Perf Coil,883 Jugs Precision Bored for Branch 30º Domed Pistons,& One Big Smile ;o), ~83TQ, ~83HP for now.
I hate what you're having to go thru.
But I'm glad to see you on the road to recovery.
Thanks for posting your experience so we can all benefit from it.
Master Bike Builder
Sportster/Buell Year: 1964
Sportster/Buell Year #2: 1971
A bit late, but you need a better puller than what you were using. A real two jaw probably would have worked just fine. Or a bearing separator/puller combo.
I didn’t want to buy expensive specialty tools that store might not take back and not work.
That was a good two jaw. It started bending and didn’t want to run the risk of end of shaft getting messed up.
There was no budging it at all since was twisted over timing key.
Thanks to everyone for feedback and ideas also
Seized Oil pump disassembly pictures... metal fragments and cracked round part and warn teeth and grooves
Holy son of a motherless goat.
split the cases!!!!!
You can BET some of that went into your engine.
That pump didn't lock up. It grinded to a halt.
You have a lot of damage in the return side and bad scoring on the feed side.
You are going to need a full body cavity cleaning.
The shavings from the teeth on feed side surely hit the oil filter.
The oil filter has a bypass built into it so in case it stops up, it opens unfiltered oil into your engine.
The pics inside the body show how something (presumably drive gear teeth) entered the return side thru the front cam port and got drug thru.
Metal in the feed cover came from the tank via the return side of the pump.
rocketmangb's Avatar
Split the cases
Thats some carnage there !
Thy Sportster Come
It Shall Be Done
On Earth as it is on Salt
2006 Sportster XL1250C
Hammer 600 Cams
Big Ass CP/Hammer Pistons
Jetted 27.5 slow,182.5 Main
97 Needle,Clip posistion 3
Patriot Defender Pipe
Napa 7148 oil filter
Max Power, 111.47
Max Torque, 84.39
Best 1/4 Speed to date 115.14
