0 Keith Black 10:1
Last Post: Boudwood
Last Post: SoonerSport
0 Hello from Northampton, England!
0 65 CH barn find/survivor
Last Post: 60weight
0 S&S Cycle Hooligan 2-2 Exhaust
Last Post: Screw Loose Dan
5 Stupid points and timing questions.
0 Chrome or Dark Custom
Last Post: RussW
0 mode of failure
Last Post: Crash7557
0 Proposed clutch spring improvement0
Last Post: Serious Blac
0 Spokes or Mags
Last Post: Whylee
0 is a buell a harley
Last Post: Bone
0 Weekend at Jester's
Last Post: Bwf347
0 Small nail in tire?? plug or replace
Last Post: rider61
Last Post: Bone
0 New T Shirts
0 Gravydog crashed again.
6 Is Your SPORTSTER...
0 WTB Front Engine Mounts for 2001 1200XLS
Last Post: Agave
0 Clutch gone out of adjustment seems like a lot
Last Post: jordan1200
0 rattling after installing oil cooler.
Last Post: Grumpy-Biker
PlanB, Cuco6924 (72), 1200sporty (61), iron68 (47), LifesHarlequin (34), mattosm (33)
Old 18th August 2018
Subscribing Biker
Originally Posted by Nrg2brn View Post
hello, Ive got a 2017 sportster, and with 4k miles on it, the oil is black and thickening. Im not going to think about that too much, but I am going to change it. I saw a drain plug on the lowest point of the motor, but apparantly, im supposed to use a hose?
I did find and drain the oil with the hose, but its not at the lowest point..seems to only have drained the tank.
wouldnt I want to remove that plug on the very bottom and get all that out from the bottom??
thanks in advance. Ill just let it drip until I know what to do for sure.
dave
"I saw a drain plug on the lowest point of the motor,"
I am wondering, too, if this is the Primary Case drain or if you're talking about a factory sump plug drain that is tapered and NOT supposed to be removed, as it is almost impossible to get to re-seal. Understanding how a dry sump engine oils the engine helps a lot. They always have a small amount of dirty oil left in them when you change oil. If you're not satisfied with this check out this Scavenger tool from Rogue Choppers https://www.google.com/url?sa=t&rct=...gj562ZjdaiZ8hN
