Last Post: SoonerSport
0 Hello from Northampton, England!
0 Keith Black 10:1
Last Post: 1HD4CJM1X4K
0 65 CH barn find/survivor
Last Post: 60weight
0 S&S Cycle Hooligan 2-2 Exhaust
Last Post: Screw Loose Dan
5 Stupid points and timing questions.
0 Chrome or Dark Custom
Last Post: RussW
0 mode of failure
Last Post: Crash7557
0 Proposed clutch spring improvement0
Last Post: Serious Blac
0 Spokes or Mags
Last Post: Whylee
0 is a buell a harley
Last Post: Bone
0 Weekend at Jester's
Last Post: Bwf347
0 Small nail in tire?? plug or replace
Last Post: rider61
Last Post: Bone
0 New T Shirts
0 Gravydog crashed again.
6 Is Your SPORTSTER...
0 WTB Front Engine Mounts for 2001 1200XLS
Last Post: Agave
0 Clutch gone out of adjustment seems like a lot
Last Post: jordan1200
0 rattling after installing oil cooler.
Last Post: Grumpy-Biker
PlanB, Cuco6924 (72), 1200sporty (61), iron68 (47), LifesHarlequin (34), mattosm (33)
Old 18th August 2018
Smerch's Avatar
Smerch Smerch is offline
Sportster/Buell Year: 1979
Other Motorcycle Model: Heritage Softail
Smerch is a name known to allSmerch is a name known to allSmerch is a name known to allSmerch is a name known to allSmerch is a name known to allSmerch is a name known to allSmerch is a name known to allSmerch is a name known to allSmerch is a name known to allSmerch is a name known to allSmerch is a name known to all
You need to be doing plug readings to see where it is going lean. It sounds like it's the pilot jet, because that jet not only feeds the idle screw, but it also feeds the 5 little ports just after that idle screw port in the throat of the carb. OR... It could be that you are getting to the needle at that point, and the needle may need to be raised one notch (washer), or the needle may not have the right taper at the tip end, and CV Performance carries the cure for that.
The OP has a butterfly carb, not a CV. Or did I miss something?
sltm1 sltm1 is offline
Sportster/Buell Model: Roadster XLS 1000
sltm1 has much to be proud ofsltm1 has much to be proud ofsltm1 has much to be proud ofsltm1 has much to be proud ofsltm1 has much to be proud ofsltm1 has much to be proud ofsltm1 has much to be proud ofsltm1 has much to be proud ofsltm1 has much to be proud ofsltm1 has much to be proud ofsltm1 has much to be proud of
No, you're right, but I still want to know if I can down tune the accelerator pump ????????
60Gunner's Avatar
60Gunner 60Gunner is offline
Where are you getting the idea you're getting too much fuel? I think the consensus is just the opposite but you need to read plugs to know where you're what. A shot in the dark approach just doesn't work here and could compound the issue you're having. So will the lollipops most likely.
05 1200C w/custom timing map 'VooDoo'
Dragtron II/K&N filter/Cycle Shack pipes/HP+baffles
45/175/N65C shimmed .040/ICM 1-3/4 turns
doodah man's Avatar
i don't know about pump shot adjustability on your keihin, but you could remove the pump rod, measure it, and get another rod of similar diameter and cut just a little shorter. that will push on the diaphragm a little less and reduce the pump shot. hopefully someone will come along with a better answer than that, but it is an option.
Ya'll have given me a bunch to chew on, I'm going to do some experimenting a bit at a time, no A/C in the shop so my work time is limited, I'll let you know when I either fix it or f--k it up. First thing is to run it till it's at operating temp and check the plugs again......
Old 20th August 2018
wedge's Avatar
wedge wedge is online now
Not sure. He said Keihin, so I assumed. But, whatever carb it is, there should be some "off idle" circuit, and this seems to be a problem in that range.
Diogenes415's Avatar
...Sticking anything inside a drag pipe is like trying to fart around a cork...
That's just too simplistic of a way to view what's happening inside an exhaust. Until I have the time to weld up a good 2-1 exhaust, I made the 2" drag pipes that came with my bike work with lollipops. They were effective in cancelling out the harmonic reversion that caused the bike to run too rich in the rpm range I use most where drag pipe sag was obviously negatively affecting the performance.
Nope, it's a Sportster.
83XLX's Avatar
83XLX 83XLX is offline
Sportster/Buell Model: XLX-61
Sportster/Buell Year: 1983
Other Motorcycle Year: 1969
Do a few plug chops and see what they look like. If it's lean, see what jets are in it now. If they're stock, I'd bump up both the jets one step, adjust the idle jet screw accordingly, and see what that does.
wedge's Avatar
Please read this before you start.
http://xlforum.net/forums/showthread.php?t=920271
This will help you get straight to the problem instead of just throwing things at it until it gets better.
