0 Cams, what are the specs?
Last Post: Bone
Last Post: jharback
0 New T Shirts
0 New from Pasco, Fl
5 Your worst car?
Last Post: jharback
0 hello and help
Last Post: jharback
0 New from Reno
Last Post: jharback
0 XR1200 caliper to 03 883R
Last Post: 93Sportytorres
0 New England 2018
Last Post: tvon
0 Proposed clutch spring improvement0
Last Post: Serious Blac
0 Ignition module screws, need size
0 Iree's jukbox joint
0 "S" model specific Q&A
0 Let's study the 77-85 oil pump, parts, and changes and when.
0 Small nail in tire?? plug or replace
Last Post: rider61
0 Possible Stator Issues?
Last Post: JBaker
0 To hone, or not to hone
Last Post: T_worth
0 Cut Wiring, no spark.
0 Boardtracker Project
Last Post: JonesL
0 THE Trainspotting Thread
0 DK's Definitive Ride Report - Some of the Best Scenic Roads Out West - Tons of Photo'
Last Post: RandyMac
DaddyJay, sixshooter (71), cartoad2001 (69), Dirty Ernie (63), bri1200c (55), pquirk (52), GOTWA (49), gremlinsteve (49), lbowles2 (47), Guess (39), rnaway22es, landon283 (30)
Kingrabbit's Avatar
Kingrabbit Kingrabbit is offline
Sportster/Buell Year: 1973
Other Motorcycle Model: Honda CB550
Other Motorcycle Year: 1974
Kingrabbit is an unknown quantity at this point
Default Pre lube the rockers?
Heya
73 xlh been sitting a few years. I am trying to pre lube the top end before attempting to start up. I read the Sticky by Gar which was helpful. But I am not sure how to squirt oil into the rocker boxes?
Thanks for advice, direction n comments.
Cheers
Donnie
Sportster/Buell Year: 1964
Sportster/Buell Year #2: 1971
Iron Mike is a splendid one to beholdIron Mike is a splendid one to beholdIron Mike is a splendid one to beholdIron Mike is a splendid one to beholdIron Mike is a splendid one to beholdIron Mike is a splendid one to beholdIron Mike is a splendid one to beholdIron Mike is a splendid one to beholdIron Mike is a splendid one to beholdIron Mike is a splendid one to beholdIron Mike is a splendid one to behold
He most likely was referring to removing cap on the right side of rocker shaft and squirting through shaft.
if you want to and do not have the pre-lube tool, look at the rocker box on the right and either frt or rear of each box, you will find a 1/8npt plug. remove a plug and attach a grease gun hose to it, does not need to be tight. have a clean gun and fill with your flavor of oil and pump to your heart's content. do the other and you are on your way.
http://www.2040-parts.com/_content/i...155820/001.jpg
notice the plugs
If it was run or assembled with lube it will be fine to just start it up.
As long as the oil pump is working...
removing the rocker arm end caps to do this may cause a leak there.risk vs.negligable reward.
Just start it.
Dave L's Avatar
Dave L Dave L is offline
Sportster/Buell Year: 1985
Sportster/Buell Year #2: 1985
Other Motorcycle Model: Kawasaki Vulcan 700
Other Motorcycle Year: 1985
Dave L has a brilliant futureDave L has a brilliant futureDave L has a brilliant futureDave L has a brilliant futureDave L has a brilliant futureDave L has a brilliant futureDave L has a brilliant futureDave L has a brilliant futureDave L has a brilliant futureDave L has a brilliant futureDave L has a brilliant future
Tatro had a non pumper. He put some oil in through the timing hole and had a rubber cap he put in place of the oil cap and used compressed air until he got oil out of the tube at the top feeding the rocker box on the rear cylinder. Me thinks he pinched off the return line to the tank. Just make sure your pumping oil though. He knew right away something was wrong when he fired it up initially. Mine sat for 5 yrs. On mine I looked for oil returning to the tank. I guess that still doesn't mean that the rockers were not getting oil. But I am pretty sure they must have been.
