0 Round Air Cleaner Poll
Last Post: Proteus
Last Post: Roane
0 Back rest compatability
Last Post: ReddTigger
Last Post: burely
0 2.18 Gearing Ratio For 5 Spd 1200??
0 Rocker cover torx
Last Post: oldboy
Last Post: wrkdWS6
0 Flush gas cap question
Last Post: orvitarius
0 Finding an accessory power source
Last Post: brixtonanima
0 Alarm Time Out?
0 The huge difference 4 degrees of Advance makes ...NOT
0 spark plug wire ohms
0 Getting ready to try firing it up after a year long rebuid
Last Post: Smerch
0 Stacking the Alto Carbonite clutch !
0 Sportster Throwout bearing
0 my recent ebay purchase
Last Post: Blowupster
0 Finally Got the Kinks Out
Last Post: JackPrice53
3 Shaky Dave Recovery
0 Swingarm bearings - boy I'm glad I looked at them
0 Head bolts and conversion
0 1972 XLH question
Last Post: 1Scooter
Last Post: marksfatboy
0 FS: Forward Controls (2004 - 2013 Sportster)
Last Post: wrkdWS6
dies, ecm, ecu, ignition
Old 18th November 2012
Texrebel Texrebel is offline
Sportster/Buell Model: 1200xlc
Texrebel is an unknown quantity at this point
Angry 2003 1200xlc dies while riding and won't start till it sits
I have a 2003 sportster xlc and it will intermittently just shut off while riding and won't restart for about a hour. I have power and the starter works fine I have a brand new battery, new coil, wires, and a new tilt sensor. It may do this twice in one week or I have it go as long as a year before it would do it again. I have troubleshooted this for a long time and can't figure it out. After the bike sits for a while it will fire up and run like nothing is wrong. I have also checked the plugs when it dies and I am getting no spark when this happens. Please help if you have any info thanks
rocketmangb's Avatar
Welcome Aboard Tex !
Sounds like the ignition module in the nose cone
Thy Sportster Come
It Shall Be Done
On Earth as it is on Salt
2006 Sportster XL1250C
Hammer 600 Cams
Big Ass CP/Hammer Pistons
Jetted 27.5 slow,182.5 Main
97 Needle,Clip posistion 3
Patriot Defender Pipe
Napa 7148 oil filter
Max Power, 111.47
Max Torque, 84.39
Best 1/4 Speed to date 115.14
Where is that located is it the black box under the seat on the rear fender
I think its under what used to be the point cover on the right side of the engine.
That round cover with 2 rivets and the "5" on it
Thanks a lot appreciate the info
For giggles
next time is acts up flood that area with cool water and draw the heat out
if it starts right up you found the problem !
Will do thanks
dwl25 dwl25 is offline
Sportster/Buell Model: xl 883c
dwl25 is just really nicedwl25 is just really nicedwl25 is just really nicedwl25 is just really nicedwl25 is just really nicedwl25 is just really nicedwl25 is just really nicedwl25 is just really nicedwl25 is just really nicedwl25 is just really nicedwl25 is just really nice
That is classic ignition module failure. There is no facory replacement. It is an obsolete part. Daytona twin tec, Dyna and Ultima(rebadged Dyna, $130 cheaper and my favorite) are readily available. If the bank angle sensor is something you can't live without you have to get the Daytona as the others eliminate it.
Hope this helps.
Dave, Galveston, Texas (formerly Lake Perry, Kansas)
Old 19th November 2012
Dwl25 thanks for the info is there a web site I can go to find these at
ROGER4314's Avatar
ROGER4314 ROGER4314 is offline
Other Motorcycle Model: Have owned about 30 bikes
ROGER4314 is a glorious beacon of lightROGER4314 is a glorious beacon of lightROGER4314 is a glorious beacon of lightROGER4314 is a glorious beacon of lightROGER4314 is a glorious beacon of lightROGER4314 is a glorious beacon of lightROGER4314 is a glorious beacon of lightROGER4314 is a glorious beacon of lightROGER4314 is a glorious beacon of lightROGER4314 is a glorious beacon of lightROGER4314 is a glorious beacon of light
The guys are probably right about the module problem. I had a Honda that had a temperature sensitive fault in the ignition coil. It would quit then let me have a 15 minute push. After 15 minutes, it fired right up.
Flash
You gotta die of something....it may as well be something that you like!
