0 supply oil line seeping
Last Post: dodgetrucken
5 Your worst car?
5 73 Timing w/Strobe & 77 air/fuel screw
Last Post: 4th of July
0 Winter riding clothes
0 Fact or fiction?
Last Post: 619Sporty
0 question for our machinists
0 A.I.M. Clutch set up
5 Crankcase Oil Drain Plug
0 What engine oil do you use?
Last Post: cmwrisinger
0 Cheap 7200B bearing = NO!
0 Leakdown test
0 Codes again !!!!!
Last Post: 93trident
0 New 88 sportster project
MonkeyMadness's Avatar
MonkeyMadness MonkeyMadness is offline
Sportster/Buell Model: XLCR "Blacky"
Sportster/Buell Model #2: XLH Bobber "SmokyBitch"
Sportster/Buell Year #2: 1976
Other Motorcycle Model: Sold 883R / 1425
MonkeyMadness is a name known to allMonkeyMadness is a name known to allMonkeyMadness is a name known to allMonkeyMadness is a name known to allMonkeyMadness is a name known to allMonkeyMadness is a name known to allMonkeyMadness is a name known to allMonkeyMadness is a name known to allMonkeyMadness is a name known to allMonkeyMadness is a name known to allMonkeyMadness is a name known to all
Default Question about CV carb on iron head.
Hello,
I have one question i can't seem to anwser or figure out with my carb setup.
I have a 76 xlh with a 40mm cv carb 170main jet and 45 slow jet. With a screened velocity stack.
While riding or on the side stand at part throttle or above i can feel gas being spit out on my leg. And i can see fuel on my vStack. I've played with the jetting to no avail. I can't seem to get it to stop. I have no leaks and the bike runs really good and strong.
Am I missing something? Or is this normal for CV without an air cleaner?
Thanks
Where's my pants? Tell your mom to stop calling me, I'm not your Dad!
doodah man's Avatar
Running drag pipes? They make a phenomenon known as reversion even worse, which results in fuel going the wrong way out of the carb.
Yes 40" 1.75" drag pipes
doodah man's Avatar
A good 2:1 exhaust is the best cure, but for us cheap bastardos who can’t afford that there is always lollipops
http://www.nightrider.com/biketech/exhaust.htm
Here’s an old post speaking directly to the fuel expulsion...
http://xlforum.net/forums/showpost.p...4&postcount=21
Will this help with my issue? This is surprising.
I will make this thumb screw mod today!
I would be happy to do a 2-1 on it. Thoughts on the sportyparts 2-1
https://sportyparts.com/products/iro...=6602335715367
doodah man's Avatar
I think that sporty parts exhaust would be a good replacement, but for that price I imagine you could make it yourself for a lot less, or have an exhaust shop make it for you. Either way. But, just to keep the gas off of your leg, yes the lollipops will definitely work.
I think that sporty parts exhaust would be a good replacement, but for that price I imagine you could make it yourself for a lot less, or have an exhaust shop make it for you. Either way. It just to keep the gas off of your leg, yes the lollipops will definitely work.
Perfect thank you!
Thumb screws installed and test ride ridden. Worked like a charm. Thank you kind sir!
doodah man's Avatar
Awesome!!! Did you have to re-tune the carb any?
