Last Post: BWP 5p
0 Mikuni carb
0 wavers
Last Post: bill smith
0 900cc Cylinders
0 Cv carb jetting
Last Post: redironhead
0 Member "Wedge" Heads for 1275 Conversion
0 Remember these?
0 Nothing to See/Hear
Last Post: Tater66
0 Basket case
Last Post: Tipofthelake
0 tachometer on 2012 Custom
0 Help identifying brakes
Last Post: jharback
0 Boring intro
Last Post: jharback
0 New from Michigan
Last Post: jharback
0 Fuel Sputter & Much More
0 Rear lights
0 ultima install without VOES
Last Post: supermotolew
0 Coil Resistance Question
0 Rear wheel alignment
0 is a buell a harley
Last Post: MDT
0 Anyone using the V&H FUELPAK FP3 currently?
Last Post: SwissXL
0 Sissy bar with HD quick release bracket
Last Post: JohnAkaB
Desertfox (70), gd714 (60), insalltm (57), seagullplayer (55), ac_tx, jon686 (49), NineSixteen (45), dstroy12 (38)
NLXL's Avatar
NLXL NLXL is offline
Originally Posted by davesz1r View Post
Well, the last set of drag pipes I bought off ebay showed up in a box marked (made in Afghanistan). So it appears I may be supporting terrorism too.
There's a black van with blinded windows in front of your house right now...
Sportsterpedia
Objects in mirror are shaking less than they appear
Highly-Dangerous's Avatar
He has been Triangulated already...
NLXL's Avatar
Yup, MQ-9 Reaper on it's way...
FiftySixer's Avatar
FiftySixer FiftySixer is online now
Hollywood Pixelmagician
Sportster/Buell Model: Sportster XL883C / 1250
Sportster/Buell Model #2: 2001 XL 883C/ 1250 Hammer
FiftySixer has much to be proud ofFiftySixer has much to be proud ofFiftySixer has much to be proud ofFiftySixer has much to be proud ofFiftySixer has much to be proud ofFiftySixer has much to be proud ofFiftySixer has much to be proud ofFiftySixer has much to be proud ofFiftySixer has much to be proud ofFiftySixer has much to be proud ofFiftySixer has much to be proud of
Gentlemen,
I have a question about intake manifolds.
I just purchased a billet intake manifold from Hammer for my build. Ill be hanging a Mikuni 42mm in front of it.
Does mirror polishing the interior of the manifold tunnel to a chrome like shine add anything to the performance of the unit?
Is there any polishing to do on the carbs tunnel?
Thanks in advance guys,
Best regards,
FiftySixer
I Do Custom One Of A Kind Graphic Designs & Websites for bike parts! Check Out My Image Album
Black 2001 XL883 Custom, Hammer Performance 2004+ Big Fin 1250 kit with Flat top pistons, 2004+ XL 1200 Heads new built by Hammer,
Hammer 560/570 Cams, 42mm Mikuni HRS Easy kit, Twin Tech Single fire coil, Twin Tech Ignition, Hammer billet manifold,
S&S/Jims Roller Rockers, New Push Rods, Telescopic push rod tubes, Hammer 3" Air Cleaner & Filter,
Pingle High Flow petcock, 04+ oil pump & bronze gear/Supertrapp/Basani/Patriot 2 into 1.
rocketmangb's Avatar
There is some air flow issues with polishing the inside of the manifold,look up "boundary layer"
Thy Sportster Come
It Shall Be Done
On Earth as it is on Salt
2006 Sportster XL1250C
Hammer 600 Cams
Big Ass CP/Hammer Pistons
Jetted 27.5 slow,182.5 Main
97 Needle,Clip posistion 3
Patriot Defender Pipe
Napa 7148 oil filter
Max Power, 111.47
Max Torque, 84.39
Best 1/4 Speed to date 115.14
rhartlin's Avatar
rhartlin rhartlin is offline
rhartlin is a splendid one to beholdrhartlin is a splendid one to beholdrhartlin is a splendid one to beholdrhartlin is a splendid one to beholdrhartlin is a splendid one to beholdrhartlin is a splendid one to beholdrhartlin is a splendid one to beholdrhartlin is a splendid one to beholdrhartlin is a splendid one to beholdrhartlin is a splendid one to beholdrhartlin is a splendid one to behold
I know my experience with Chinese carb parts didn't leave me warm and fuzzy. Good luck with your test and look forward to seeing the results.
davesz1r's Avatar
davesz1r davesz1r is offline
Sportster/Buell Model: xlh 883 hugger
Other Motorcycle Model: kz1000 z1r
Other Motorcycle Year: 1978
davesz1r is a splendid one to beholddavesz1r is a splendid one to beholddavesz1r is a splendid one to beholddavesz1r is a splendid one to beholddavesz1r is a splendid one to beholddavesz1r is a splendid one to beholddavesz1r is a splendid one to beholddavesz1r is a splendid one to beholddavesz1r is a splendid one to beholddavesz1r is a splendid one to beholddavesz1r is a splendid one to behold
I have only managed to put 150 miles on a fresh hammer 1275 kit. But will install the chikuni after 500 miles. Been having health issues and going all over the county for tests because it appears my health insurance carrier doesn't have a globe. In fact I have to get a cat scan tomorrow which seems odd to me because I don't even have a cat, just three old dogs.
1275 cc 10.54:1 cr se heads .560 cams hsr42 dyna 2000p patriot defender 11.63@ 115 1/4
Thanks for the laugh!!!
Sportster/Buell Year: 1991
I'd contact Hammer for those questions. If anyone has data on those issues, they should. Especially the manifold. Good luck.
John
rejeanprimeau's Avatar
Read lotus effect. It apply to all fluids and gas.
