0 Air Filter Soaks With Gas
0 2 into 1 exhaust build
Last Post: paulc
0 '89 Sportster 1200 Chopper
Last Post: deuce460
Last Post: jammantoo
Last Post: deuce460
0 02 sensor query
Last Post: stephenw
Last Post: deuce460
0 Reflectors...Yeah, or Neh
Last Post: RAIDER0372
Last Post: Kbetts
0 1970 Ironhead Sportster XLCH delivered; customization begins
Last Post: Wilkinson949
0 Should I buy a Sportster??
Last Post: Diogenes415
0 900 dual carb front head
Last Post: chevelle
Last Post: Airarbiter
0 Engine stabilizers
5 Summer time heat
0 exhaust or cams?
Last Post: Gazotenekes
Last Post: wrkdWS6
  #31
Old 19th September 2018
Jollly Rogers Jollly Rogers is offline
Jollly Rogers has a reputation beyond reputeJollly Rogers has a reputation beyond reputeJollly Rogers has a reputation beyond reputeJollly Rogers has a reputation beyond reputeJollly Rogers has a reputation beyond reputeJollly Rogers has a reputation beyond reputeJollly Rogers has a reputation beyond reputeJollly Rogers has a reputation beyond reputeJollly Rogers has a reputation beyond reputeJollly Rogers has a reputation beyond reputeJollly Rogers has a reputation beyond repute
Originally Posted by ed_in_az View Post
Update:
Also, I lifted the front wheel and spin tested it. Eyeballing it for wobble it looks like about 1/8" deviation as it spins. I don't know how much it would take to produce the handling problems, but there it is.
Ask them to demonstrate any other bike in stock that has that much runout on the front tire. If they can’t find one to equal the runout on the tire they supplied you, smile and say “ Please try again with a replacement tire. This one is unsafe”!
ed_in_az's Avatar
ed_in_az ed_in_az is offline
ed_in_az has a reputation beyond reputeed_in_az has a reputation beyond reputeed_in_az has a reputation beyond reputeed_in_az has a reputation beyond reputeed_in_az has a reputation beyond reputeed_in_az has a reputation beyond reputeed_in_az has a reputation beyond reputeed_in_az has a reputation beyond reputeed_in_az has a reputation beyond reputeed_in_az has a reputation beyond reputeed_in_az has a reputation beyond repute
Originally Posted by Bone View Post
If you've got a local friend the quick and easy way to eliminate or confirm the wheel/tire as a culprit or contributor is to "substitute a known good part".
That is, swap the front wheel/tire from a Sportster riding buddy and go for a test ride. I mean it's pretty dead simple and quick to do and then you'll know.
I actually thought about trying to get them to re-mount my old worn out tire. But I don't think they keep old tires around after replacement. Unfortunately I don't know any other Sportster riders around me. I'm pretty sure a new tire/wheel off a showroom 2018 Iron would fit ...
Also, the tire is an official HD Dunlop 401.
2008 Nightster 1200 Convertible: Touring/Bobber SE Stage I
Old 22nd September 2018
ed_in_az's Avatar
So they tried to smooth things over, but regardless of my video of the spinning tire with 1/8" side to side movement ...
The steering bearings are good, the tire is good, the rim is good
The wheel bearings were bad (well they showed me a couple of bearings that were fairly tight)
The manager assured my he took it up to triple digits and it was fine. Seems improved.
I rode it home.
you don't want to give it too much of a shake at speed, just a nudge, and it's ok
I took it up to 90 and it tracked fine, not jiggly
I still want to check it on the lift and spin the wheel.
But next up is to put some miles on the new tires on one of my favorite twisties.
Old 12th November 2018
ed_in_az's Avatar
Update: since September the bike never felt quite right.
So last week I went to another dealer for a second opinion.
They couldn't guarantee replacing the steering head bearings would fix it ... but they did.
I cruised home at up to 85mph on the freeway. Shook the bars and it came right back to straight. Even in rough winds today the bike was rock steady.
Old 13th November 2018
Sportster/Buell Year: 1988
I lifted it and could look in and see the bearing! The dealer adjusted it and declared it AOK.
Glad you changed your dealer and are sorted now!
