Last Post: motorend
0 Highest mileage logged on IH engine?
Last Post: owlsplace
0 head and cylinder painting
Last Post: Whitewalls
0 Need to part with my '59
Last Post: Doc308
0 Lowbrow XLR pipes
Last Post: simonster123
Last Post: Calcustom
Last Post: Woody9225
0 Erratic clutch + dragging noise
Last Post: Quebec3
0 Axle mount license plate bracket question
Last Post: WVDevil
Last Post: A Seabee
0 Primary/gearbox chirp
Last Post: XLPIZZA
0 Could this be true?
Last Post: firewallsrus
0 Metzeler Cruisetec
0 1991 frame/engine original ground locations
Last Post: Jer
0 Kickstarter return spring
4 Hello from Chicago
Last Post: jzink0883
0 7 Dead and more wounded
Last Post: tvon
Last Post: WVDevil
0 Efi and carbs
0 Stage 3 BLACK Breather Bolts
0 DK Custom Products new discrete breather system...
View Poll Results: Can/could you see behind you with stock mirrors?
Yes, the stock mirrors are fine. 502 37.13%
No, I can't/couldn't see a thing behind me! 850 62.87%
Voters: 1352. You may not vote on this poll
  #541
Old 3rd January 2019
Folkie Folkie is offline
Originally Posted by Desertfox View Post
I guess it is just one of those idiosyncratic things you deal with when you own a Harley Davidson. There are tons of better designs for rear view mirrors on the market but they stick with a very dated design. WTF wants to keep a Phillips (a tiny one) screwdriver handy in case your rear view mirrors shake loose? Of course mine is an old solid mount so vibration is an issue.
Mine don't have any such screws, and the mirrors have never shook loose. The mirrors are the same as they were on my '05 and my '13, and on the BTs I had. They did update the design.
No, they came out with a new design, and that was over 15 years ago! The new (!) mirrors are retrofittable to older bikes back to 1982.
I always carry tools in case things shake loose, but have only ever really needed them on my Honda trаil bіke. Go figure!
Jarlaxle Jarlaxle is offline
Sportster/Buell Model: XL883L bagster
Jarlaxle has a brilliant futureJarlaxle has a brilliant futureJarlaxle has a brilliant futureJarlaxle has a brilliant futureJarlaxle has a brilliant futureJarlaxle has a brilliant futureJarlaxle has a brilliant futureJarlaxle has a brilliant futureJarlaxle has a brilliant futureJarlaxle has a brilliant futureJarlaxle has a brilliant future
Haven't had them vibrate loose...Mine are just too narrow.
Loud pipes lose rights.
Old 15th January 2019
60Gunner's Avatar
60Gunner 60Gunner is offline
Opinion Affairs Expert
Never had an issue with mine and carrying tools is just a smart thing to do. That's what fork bags are for. Hell, I can change the jets in the carb on the side of the road in 5 minutes.
I carry an assortment of tools so I'm prepared to tighten/fix as much as possible on the fly.
Honestly, I can't understand why anyone WOULDN'T want to carry a screwdriver or find it an inconvenience.
05 1200/1250C/Hammer 570 Cams
TC88A Black Panther by Xena DCPR8E/Taylor Pro 8mm
HSR 42 25 pilot 2 turns 97 needle middle groove 170 main
Dragtron II AC K&N filter/VR1 20W50/SpectroSTL 75W140
Old 18th January 2019
Bama Lee XLC's Avatar
Bama Lee XLC Bama Lee XLC is offline
Bama Lee XLC has a reputation beyond reputeBama Lee XLC has a reputation beyond reputeBama Lee XLC has a reputation beyond reputeBama Lee XLC has a reputation beyond reputeBama Lee XLC has a reputation beyond reputeBama Lee XLC has a reputation beyond reputeBama Lee XLC has a reputation beyond reputeBama Lee XLC has a reputation beyond reputeBama Lee XLC has a reputation beyond reputeBama Lee XLC has a reputation beyond reputeBama Lee XLC has a reputation beyond repute
just ordered 2 sets of 2" stem extensions for mine..........can't see anything but my shoulders and "flipped" is even worse.
if this doesn't solve it, i'll bite the bullet and buy long stem adjustables
'02 XL1200C Customed out by previous owner.
Old 23rd January 2019
added 5" worth of stems to mine and now I can see behind me !!
Old 13th May 2019
firewallsrus firewallsrus is offline
Sportster/Buell Year: 2018
firewallsrus is an unknown quantity at this point
I swapped sides for the mirrors on my Iron1200 and hung them upside down. The view behind me is greatly improved now since my shoulders are wider than my waist. When you do this, you will likely have to swing the front turn signals out of the way on their pivots, but this is simple to do.
Old 14th May 2019
b0fh's Avatar
b0fh b0fh is offline
Sportster/Buell Model: XL883R
Sportster/Buell Year #2: 2017
can u actually see stuff or just a blur with those stems?????
Old 17th May 2019
Like finding the right riding position, the handlebars make a HUGE DIFFERENCE in the issue of what you can see from your mirrors... All those tight, narrow bars are going to place the mirrors directly in front of your body...
My buckhorn bars are just about shoulder width and my body is visible in about 1/4 of the mirror with the other 3/4 showing the road directly behind me and then out to the side...
The stock mirrors on my 2005 Sporty were totally useless because I could only see my arms and shoulders. I replaced them with V-Twin 34-0296 Mirror Set Long-Stem, Wide Lens which not only gave me an excellent view but also were true view - not "objects may be closer..." view. There is also a Phillips screw in the back of each so that I could tighten them when they came loose and are great. They are excellent.
