0 '66 XLCH VM38 Conversion
0 CV Carb hesitation
Last Post: stevehendo
Last Post: ericfreeman
0 Xl???
0 so it's officially ended
0 Tuners
Last Post: doc martin
Last Post: XL Dane
0 Morning default to odometer
0 What jets do you use?
Last Post: Thack
Last Post: Nicktater
Last Post: Samedward
Last Post: tedcool
8 XLCH kicker giving me a major headache!
Last Post: Nightmare
0 old parts
Last Post: bill smith
Last Post: thefrenchowl
Last Post: 1200CustomHD
Last Post: OCRyder
Last Post: OCRyder
0 "S" model specific Q&A
Last Post: ftwflh
Old 11th August 2020
Report back the actual voltage numbers...
This Sportsterpedia section is on the Switches & Lights:
http://sportsterpedia.com/doku.php/techtalk:evo:elec03
You can check out the wiring for the brake switches:
http://sportsterpedia.com/doku.php/t...h_-_front_rear
The headlight:
http://sportsterpedia.com/doku.php/t...ec03#headlight
The Run/Turn/Brake module:
(see the 2007-2013 section)
Here are some threads on How-To Eliminate TSM - Or Replace TSSM with TSM
http://xlforum.net/forums/showthread.php?t=847440
http://xlforum.net/forums/showthread.php?t=573200
Good Luck - Report back actual meter readings and detailed explanations of what you did so we know what you saw...
Yes, we need numbers as we have two contradictory statements that don't add up.
Originally Posted by AntsBAC View Post
..It tends to sputter and cut fuel. I can work with it and ride it that way for a bit before it'll drain the battery...
...I’ve tested the battery and it’s good, and it’s reads well with the voltmeter when it’s running...
wedge's Avatar
wedge wedge is offline
That was taken on I-80 just outside Winnemucca. That was about the halfway point. The bike now resides with me in Sacramento. So if there's anyone local to me here I'm happy to provide pizza and beer.
I just did a second job up in Tracy. Never planned to travel that far for jobs, but good old customer and no way to say no. There is another one coming up, but I don't know the schedule yet. Nice countryside up there.
Highly-Dangerous's Avatar
Also in case you were wondering what the bike looks like, here's what she looked like the day I picked her up.
https://ibb.co/8DSSf2H
Looks a little different now. I cut and shaped the cam cover. Cut and shaped the controls where the brake reservoir would normally mount (sorry Roland Sands) and painted them texture black to match the cases.
