Last Post: ericfreeman
0 Xl???
0 so it's officially ended
0 Tuners
Last Post: doc martin
0 '66 XLCH VM38 Conversion
Last Post: ProLibertate
Last Post: XL Dane
Last Post: owlsplace
0 Morning default to odometer
0 What jets do you use?
Last Post: Thack
Last Post: Nicktater
Last Post: Samedward
Last Post: tedcool
8 XLCH kicker giving me a major headache!
Last Post: Nightmare
0 old parts
Last Post: bill smith
Last Post: thefrenchowl
Last Post: 1200CustomHD
Last Post: OCRyder
Last Post: OCRyder
0 "S" model specific Q&A
Last Post: ftwflh
Old 12th August 2020
sportsterdoc's Avatar
Valuable information, Mike.
Is this the model under discussion?
http://www.thisoldtractor.com/dr350_...1994_color.png
Have you checked the interlocks and other incoming signals that may prevent the firing of the ignition?
Sportster/Buell Year: 1991
Have you checked the interlocks and other incoming signals that may prevent the firing of the ignition.
1994 DR350SE "R" model is correct.
I've been using that diagram. But, we've discovered the wire colors are not the same for some systems. Front brake switch is not orange and black, etc.
John
Originally Posted by Iron Mike View Post
There is more to that DR ign kill as well. Side stand relays ect.
I agree. My buddy buys and sells dual sports, so I've deleted the clutch and sidestand lockouts on several of them. That's one of the first things I'm going to check when he brings it back over. It has to be something simple, since the bike was running great, then just died when he pulled over at the beach. Possibly the sidestand came into play?
He just bought a 2001 Yamaha WR426F, which needs some work, so at least he's keeping me busy this summer!
Hopefully this thread will keep some of us entertained while I search for the solution.
John
Old 13th August 2020
commando57 commando57 is online now
Sportster/Buell Year: 2016
Sportster/Buell Model #2: XL1200T
Sportster/Buell Year #2: 2017
Other Motorcycle Model: Z50A (Honda)
Other Motorcycle Year: 1969
commando57 is an unknown quantity at this point
The coil could be acting up when it gets hot.
That's possible, thank you. I'll see if I can check that out when he brings it back over.
John
