0 Talk to me about Painting
Last Post: brixtonanima
0 Mikuni 42 on 883
Last Post: Bow only
0 Harley Vincent?
0 Marrying used speedometer
0 Who runs 70wt. oil
0 USA made Stainless hardware better than stock
0 DK Custom Products License Plate Relocations
0 Resto-Repair 84 ironhead
Last Post: rocketnorton
0 Help me identify this bike
Last Post: AKL1
Last Post: thecarnie
0 Fi to carb
0 Diagnostic code ?
0 Front head gasket leak
Last Post: Scuba10jdl
0 Passenger peg relocation with Rinehart Fast Tracks exhaust
Last Post: GorilladaHun
0 muffler balance pipe
0 Do people notice your bike?
0 Lifters+w cams
Last Post: Gazotenekes
Last Post: 83ironman
0 FNG from Oregon
garyschmidt (78), JicJac (70), alleybabe (62), Galewarning (56), wngdweeler (51), scooter (47), kariglam1 (45), HERDYAN (45), V-XL (43)
cable, clutch handle, transmission
Old 9th July 2018
cHarley04's Avatar
cHarley04 cHarley04 is offline
Sportster/Buell Model: XL1200C/1250
Sportster/Buell Year: 04
cHarley04 has a brilliant futurecHarley04 has a brilliant futurecHarley04 has a brilliant futurecHarley04 has a brilliant futurecHarley04 has a brilliant futurecHarley04 has a brilliant futurecHarley04 has a brilliant futurecHarley04 has a brilliant futurecHarley04 has a brilliant futurecHarley04 has a brilliant futurecHarley04 has a brilliant future
Originally Posted by Bone View Post
Doh..... Never mind. Note to self, when drunk posting check details first.
No need to blame it on drinkin, the OP didn't list which of the 4 bikes listed he was talking about.
Hammer 1250-Smash Heads-560 Cams -Hurricane Flow AC -Supertrapp Supermeg -TC88A
Old 9th July 2018
Bone's Avatar
Bone Bone is offline
Sportster/Buell Model: FLHP
Sportster/Buell Year: 2016
Sportster/Buell Model #2: Guzzi V7 Stone
Sportster/Buell Year #2: 2013
Other Motorcycle Model: 18 Guzzi V7D / 11 Duc 696
That's ok, on Tapatalk I can't even see the 4 bikes listed. I just ASSumed...and you know what that gets.
Not that I have a problem owning it either way, drinking or not lol.
Old 9th July 2018
You'll want to post this question in the Ironhead section - Those guys sometimes don't check other subsections to see what's being posted...
http://xlforum.net/forums/forumdisplay.php?f=7
2 Relax
Old 10th July 2018
Diogenes415's Avatar
Diogenes415 Diogenes415 is offline
Sportster/Buell Year #2: 2000
Other Motorcycle Model: XL883C
Diogenes415 has a reputation beyond reputeDiogenes415 has a reputation beyond reputeDiogenes415 has a reputation beyond reputeDiogenes415 has a reputation beyond reputeDiogenes415 has a reputation beyond reputeDiogenes415 has a reputation beyond reputeDiogenes415 has a reputation beyond reputeDiogenes415 has a reputation beyond reputeDiogenes415 has a reputation beyond reputeDiogenes415 has a reputation beyond reputeDiogenes415 has a reputation beyond repute
Hahaha... no harm, no foul.
Nope, it's a Sportster.
Old 10th July 2018
rejeanprimeau's Avatar
Exploded alternator magnets.
Old 10th July 2018
Ray1974 Ray1974 is offline
Sportster/Buell Model: Xlcr
Sportster/Buell Year: 1979
Sportster/Buell Model #2: Xls
Sportster/Buell Year #2: 1980
Other Motorcycle Model: Honda cb 919
Ray1974 is an unknown quantity at this point
Nope no alternator. Has a generator mounted on front or engine
Old 10th July 2018
wedge's Avatar
wedge wedge is online now
You just installed a new ramp.
Is this a stock ramp from the moco? After market? Did you get it as a unit including the proper balls for it? A while back a friend was playing with different balls. Total fail, and larger balls ride on the edge of the channel causing half travel and strange clutch problems. Strange in that the problems we saw were not constant.
Make sure the ramp is sitting at it's low point when you start the adjustment. I have seen a hung up ramp cause a bad adjustment before.
Personally, I would adjust back and forth, and see what a loose adjustment feels like, and how much back off from contact point seems to work best. If you leave more play at the ramp adjustment, then you need to take more out of the cable, and vice versa. Maybe something is positioned at the end of it's adjustment range instead of back at the beginning?
Oh, if the ramp is different than stock in that maybe it has a longer arm for easier operation, check that the travel has room without running out of cable.
Basically this sounds like a mechanical issue that should be visible as you inspect the entire assembly.
Old 10th July 2018
Complet drag specialty assembly .its a perfect match to the one i took out minus the bent back plate
