Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > SPORTSTER MOTORCYCLE FORUM > Sportster Motorcycle Era Specific and Model Specific > XR Sportster Motorcycle Talk - XR750, XR1000, XR1200 > XR-1200
XR-1200 This area is strictly for XR-1200 discussion only
0 2002 Sporty backfire through carb
0 3.5" straight riser
Last Post: whetrick1
0 2015 sportster charging
0 Problem with tuning Fp3 tables
0 Getting Hammered
10 dragpips to muffler pipes
Last Post: smilinbrad
0 Which Battery?
0 Leineweber camshaft
Last Post: slojoe631
0 question for our machinists
0 WTB drag pipes for 2001 sporty
Last Post: Kejobe
0 Wire Tuck with No Tank Lift and No Rewire
Last Post: TheBreeze
0 A Day in the Life...
0 piston rings
Last Post: Nitro57xl
0 more stumble on cold start
Last Post: smm1200
0 Powerraythor conversion
Last Post: saddlebagrail
0 Fat Ironhead?
mdgtmstng (66), robc (54), 09 sporty (51), bimmer10 (49), DougZ (46), mtntrout, JTedd9 (44), blueoval78 (41), Everett (39)
  #171
Old 6 Days Ago
Davo_137's Avatar
Davo_137 Davo_137 is offline
Haha he will jump through hoops of fire for kfc.
I could probably take some meat off that front face in the lathe on the 70t. What did your friend use to reshape the holes?
Old 4 Days Ago
jkinkade jkinkade is offline
ha ha have not meet a dog that did not like KFC.
I'm not sure what he used but scribed out the pattern of the holes. they looked like something performance machine had made.
there would be a lot of ways you could do it. like if you had a mill it would be easy. but could even, scribe the pattern ( he did it sort of like a mag wheel ) then with a small drill bit & maybe a bench drill & good base mount to hold, go along the scuba line drilling small holes. the finish off with a file and radius the edges. I think he even machined the sides off like Buell ( you don't really need them and get a lot of weight off. tat is rotating weight. good luck
2003 XL 88"
Old 3 Days Ago
Davo_137's Avatar
Should be able to get the pulley in the lathe sometime today if everything goes to plan.
I’m thinking of making some soft jaws to hold the pulley by its teeth in the lathe. Will see what happens.
Old 3 Days Ago
Davo_137's Avatar
I wasn’t happy.
When I spun the pulley on the lathe I could see it had a buckle in it. With the outer face hard up against the chuck the hub was out of shape almost 1mm. Funny thing is I couldn’t feel any wobble when I was riding the bike with it on the other day. So I went ahead and machined it anyway, thinking the hassle of sending it back to the USA isn’t worth the drama and I could probably take out a lot of the wobble by squaring up the hub to the outer surface the belt runs on. That’s the problem with buying secondhand parts I guess, you get a bad deal sometimes.
Anyway after machining the pulley it looked pretty good, not perfect but very close to it. You can see in the picture below the soft jaws I made.
Next picture shows how far out it was after the first cut.
The finished product.
And I also took some meat off the outside of the hub. Strangely enough the distance between the inside and outside of the hub was exactly the same all the way around after taking the outside meat off.
If I couldn’t feel a wobble before I definitely won’t feel anything now. I hope haha.
Old 3 Days Ago
good you found the wobble, be interesting what you notice when you use it.
Old 3 Days Ago
Davo_137's Avatar
Yeah. I think it’s going to be ok. It did look heaps better after a tweak on the lathe.
Old 2 Days Ago
Davo_137's Avatar
I informed the seller of my dilemma with his wobbly pulley and he has told me to keep the pulley and he will refund me the full amount I payed for it. Awesome, so I’m only down the cost of shipping. Which makes me happy.
Old 1 Day Ago
Davo_137's Avatar
Got it back together today. Belt is running near perfect on the front pulley/sprocket.
No adjustment left for a bigger back pulley with the stock belt. Rear pulley looks good spinning the back wheel by hand and I can’t feel any wobbles or anything when riding the bike.
I got a quad lock for my iPhone mounted it on my handlebars and checked the speedo using a gps app, speedo is showing 5kph faster than the gps. So 105kph on the speedo is actually 100kph.
On to the next project now.
I have a spare seat I want to send down south and have it customised. The bloke I’ve been talking to says he can make it a lot more comfortable using memory foam and gel inserts. I also want the diamond cross stitch type pattern on top with smooth sides. All I have to do is measure up want I want, put it on paper and send it all to him.
Something else I want to do is cut up the crashbar. I think it sticks out the sides to far, I want to trim an inch or two off each side. I don’t think it’s made from anything special so I should be able to weld it back up with my little stick welder. Wifey has other jobs for me first, her green house took some damage in a storm the other day. So that will probably take a day or two to fix up.
