0 Idle / transfer ports Q
0 Photo bucket
0 Options for SE a/c cover
Last Post: lespaul6
0 WTB parts for a '96
Last Post: slamtry
Last Post: Roane
0 Vote for your favorite Babe Jump Babe.....
0 new air cleaner
Last Post: stikflote
0 Head work
Last Post: ericfreeman
0 Buying and installing starter solenoid for '74.
0 90" With an HSR45 Setup
Last Post: seajay
0 Will a late model head('07) fit a '92 Sportster?
Last Post: Boil1337
0 Glyptal?
Last Post: JonesL
0 Detachable Saddlebag Solution (pics, long thread)
Last Post: MrChris
0 External breathing systems
Last Post: Lone Rider
Last Post: 72 Ironhead XLH
0 To hone or not to hone... that is the question
Last Post: duffy
0 Broken bolt holes/ mounts, can they be fixed?
Last Post: TheSporster
Last Post: 1skullster1
Old 18th December 2019
cantolina's Avatar
cantolina cantolina is offline
Luvs me an artsy chick...
Sportster/Buell Model: 883>1200 XLH
Sportster/Buell Year: 97
cantolina has a brilliant futurecantolina has a brilliant futurecantolina has a brilliant futurecantolina has a brilliant futurecantolina has a brilliant futurecantolina has a brilliant futurecantolina has a brilliant futurecantolina has a brilliant futurecantolina has a brilliant futurecantolina has a brilliant futurecantolina has a brilliant future
Old question, and the answer is still the same.
"How fast can you afford to go?"
That's truly the point of the exercise.
After I did my stage 1 (883), I was pretty unimpressed, but had a great running bike.
After I did the 1200 conversion, I could almost drive her out from under me.
Anything more than 1200-1250, and you're doing head work.
Your choice.
~Chuck
"entia non sunt multiplicanda praeter necessitatem"
Occam's Razor...
in English: "entities must not be multiplied beyond necessity."
My definition: "The simplest answers are the most likely"
~NRHS machined 1200 conversion, shittin and gettin...
XLF Tuning Stickies
Charging system troubleshooting
SLW210's Avatar
SLW210 SLW210 is offline
Sportster/Buell Year #2: 2019
What exactly does this "Stage 1" consist of? All exhaust and intake upgrades are not created equal, might be room for improvement there, a good run and tune on the Dyno might provide you with where you're at now. Then maybe cams and head work.
Hard to really say since you refuse to mention what exactly you are wanting this bike to do. It took a while for you to mention you had an EFI 1200.
rejeanprimeau's Avatar
Stage 1= Exhaust and Air Cleaner and flash tune. Add about 10hp.
Stage 2 = Cams and tuner. Another 10hp.
Stage 3 = Heads. Another 10hp.
Then after market whatever.
