Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > BUELL MOTORCYCLE FORUM > Buell Motorcycle General Discussion and Problems
0 New front tire 80/90-21?
Last Post: Spokes
0 First run
Last Post: mickey t
0 cylinder screw torque specs.
0 ironhead xlh 82 oil problem
Last Post: Traxx
0 How old are you?
Last Post: Joe_jeep
0 Larger Roadster tank for 79-81 Sportster
Last Post: 72 Ironhead XLH
0 Dynojet Power Vision 2
Last Post: Joe_jeep
0 more flow = dirty air?
Last Post: Joe_jeep
0 Do people notice your bike?
0 Copper vs Iridium Spark Plugs
0 Clutch cable oil leak
Last Post: Lone Rider
0 Battery issue?
0 Power Loss At Sustained High RPMs
Last Post: Bigshankhank
0 Trouble codes
0 Bigger valves
0 Asgardian Prep for Labor Day weekend in the Keys
0 Starter under load
0 Leaking Head Gasket, Loose head bolts
Last Post: Bored now
0 H4 headlight
Last Post: dodgetrucken
0 1st offering to forum then open market
Last Post: Yakcm2
0 Oil Cooler and oil filter
Last Post: norski
0 A MG midget driver tried to kill me today.
Under-Dog (62), bibber (58), doug883 (53), Rigid (43), Nicco (39)
Old 18th June 2019
gusm2's Avatar
gusm2 gusm2 is offline
Sportster/Buell Model: Cyclone M2
Other Motorcycle Model: Suzuki SV650
Other Motorcycle Year: 01
gusm2 is an unknown quantity at this point
Default Which cams ?
Maybe someone can help, I'm trying to decide which cams would be a replacement for my M2,it's a 99 thunderstorm engine, standard apart from wiseco pistons ,also there seems to be quite a difference in prices, I'm looking for a big more top end power
11.185@117.95
Old 18th June 2019
seajay's Avatar
seajay seajay is offline
Sportster/Buell Year: 04
Contact http://www.hammerperf.com/xlvalvetrain.shtml
04/07 1275 BFH heads .590 cams S&S 1.725 rockers S&S premium lifters BDL+15% clutch TC88A HSR-45 S&S 3" ac LSR 2-1
Old 18th June 2019
aswracing's Avatar
A Million Facts & Figures
Sportster/Buell Model: XL883
Sportster/Buell Year #2: 1999
1999-2002 International M2's came with the SE .497 cams right from the factory (same as used in the X1 and S3). Part number 25648-91, 4th down in the table below:
These cams are well matched to the motor. The .497 lift is about the limit for the stock valvetrain hardware, the overlap/TDC lifts already pushes the piston-to-valve and valve-to-valve about as far as you should push it, and the 48 degree intake close timing is a good match for the stock 10:1 compression ratio.
Bottom line, the cams are well matched to the rest of the stock motor, and so long as the rest of the motor remains stock, there are no cam miracles that will make it run better. It's already an excellent set of cams for that motor.
Click Here to Contact Me
Old 19th June 2019
gusm2's Avatar
Thank you for your help
Old 25th June 2019
Cumofo's Avatar
Cumofo Cumofo is offline
Sportster/Buell Model: XLH1200C
Cumofo is an unknown quantity at this point
Take my example of what not to do. I went and got the N6 from Andrews cuz I thought it would give me more power but I lost so much lower end and it was ridiculously not fun to ride the bike so I ended up going with the 536 has which are the same stock as the high output there you go! I also went to the weisco pop ups in a desperate attempt to restore some cranking pressure, which dropped into the 165-169 lbs range.
Sportster/Buell Year: 96
Other Motorcycle Year: 99
256* @ .053” is a lot of cam. I didn’t know stock bikes had cams like that.
... but I build performance automotive engines and that would be on the edge of street-able.
Sleepy Labeef rides again!
