0 so it's officially ended
Last Post: seajay
Last Post: Nitro57xl
Last Post: Cablejudge
0 Sportster book
Last Post: LLOYD883
Last Post: LLOYD883
0 AGM battery for 76' XLH
Last Post: ChiliK
Last Post: Clevspeed
Last Post: Nicktater
0 What jets do you use?
Last Post: Thack
0 My 08' Nightster
Last Post: XL1275
Last Post: XL1275
0 front brake caliper interchange question
Last Post: Seek4aws
moe (76), demgdaj (70), Playtoe (65), shanneba, Charlie Allen (61), the cowboy way (61), P-Diddly (58), Utahsporty (57), evo-pete (56), stf420 (55), NevadaRob (53), Punisher (51), Razor_Reznor (46), Paycheck (43), jfs92579 (41)
Old 6th January 2018
rocketmangb's Avatar
Default Throw Back to my Bone Stock '06 Dyno
Thy Sportster Come
It Shall Be Done
On Earth as it is on Salt
2006 Sportster XL1250C
Hammer 600 Cams
Big Ass CP/Hammer Pistons
Jetted 27.5 slow,182.5 Main
97 Needle,Clip posistion 3
Patriot Defender Pipe
Napa 7148 oil filter
Max Power, 111.47
Max Torque, 84.39
Best 1/4 Speed to date 115.14
Heres after the shop installed the Side Shots,SE Air Cleaner and tuned it !
rejeanprimeau's Avatar
Incredible how much a bone stock is strangle by the moco. Over 25% more HP by just letting them breath better.
Yeah 14 hp is a bunch !
Bad thing is thats all the low hanging fruit !
Old 3rd April 2018
Vohnsen Vohnsen is offline
thats crazy... i am excited to see what i can get out from my bone stock 1200 in my dragbike..
will only have free air and an ultima ignition with some homemade pipes lol
https://www.youtube.com/nikolaiownz - Homemade dragbike with Stock XL1200 '98 engine.
Old 14th August 2019
shanneba shanneba is offline
Do you happen to have the AFR readings on the bone stock run?
2013 XL1200C
Enter your VIN OR
SportsterPedia.com
I got 69 on mine bone stock with cleaner and straight pipes.
Sendt fra min EML-L29 med Tapatalk
