Last Post: Bow only
0 Too HOT to ride?
3 Shaky Dave Recovery
Last Post: Serious Blac
0 Idle / transfer ports Q
Last Post: Billy1200
Last Post: c1skout
Last Post: CMCSSeabee
0 Glyptal?
0 Photo bucket
Last Post: duffy
0 TC88A update ?
Last Post: savagegarden
0 Long intake
0 External breathing systems
0 no spark
Last Post: harley in fl
0 Options for SE a/c cover
Last Post: Doc45
0 WTB parts for a '96
Last Post: slamtry
Old 16th April 2015
drinkmixer007 drinkmixer007 is offline
Sportster/Buell Model: 2005 xl1200c & 2006 blast
drinkmixer007 is an unknown quantity at this point
I have an 2005 sporty and want to covet to a side mount tail light without doing a huge amount of work. How can I go about this?
Old 16th April 2015
sportsterdoc's Avatar
Is your inquiry mechanical or electrical?
Old 16th April 2015
Default electrical
electrical
Old 16th April 2015
electrical
What do you want to different from stock?
Only tail /license plate on the side or brake, also?
Do you have a schematic?
Old 16th April 2015
Default Sportster
I'm looking to change to a side mount brake light/licence plate bracket
Old 16th April 2015
No schematic
Old 16th April 2015
maurino17's Avatar
maurino17 maurino17 is offline
Sportster/Buell Model: 2005 883R
maurino17 is a name known to allmaurino17 is a name known to allmaurino17 is a name known to allmaurino17 is a name known to allmaurino17 is a name known to allmaurino17 is a name known to allmaurino17 is a name known to allmaurino17 is a name known to allmaurino17 is a name known to allmaurino17 is a name known to allmaurino17 is a name known to all
Did you see the first page of this thread? Cosmo provided all of the wiring diagrams and options, and I posted pictures of the harness I made.
It take a little coordinating, and I did it the hard way with the same Harley connectors, because I removed and wanted to keep my stock harness which is still for sale on ebay, lol.
If you want to cut up the stock harness and solder shouldn't be too hard.
No schematic
Old 9th July 2015
05sportguy 05sportguy is offline
Sportster/Buell Model: 883
Other Motorcycle Model: 2002 Heritage Springer
05sportguy is an unknown quantity at this point
Default Trouble installing a 3rd brake light
I have an 05 Sportster. It came with a bobbed fiberglass rear fender. I just repainted the bike and am putting it back together. I had previously lowered it too much and wiped out all of the rear wiring. I am putting it back together but having trouble with the new single element third brake light I am installing. I seem to have power at the red/yellow whenever the key is on. Even when I disconnect the wires from the brake switch. What am I missing here?
Old 9th July 2015
accessory fuse feeds o/w to front and rear brake switches
r/y come from both switches and are joined to go to the brake light
What happens when you pull accessory fuse?
did you disconnect r/y from BOTH brake switches?
most likely front or rear brake switch is stuck on
Old 10th July 2015
Thanks for the info! I did not know there was two switches. I was thinking like a car with only one because all brakes work together..... but DUH..there would have to be two. I will check the front one tomorrow. That is most likely the culprit. Thanks again
