Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > BUELL MOTORCYCLE FORUM > Buell Motorcycle Suspension, Frame, Forks, Fuel Tank, Oil Tank, Fenders
0 2015 883 with S&S 1200 conversion kit
Last Post: CCC
0 Riding music
Last Post: sprink
0 Cobra NH slipons
Last Post: SLW210
6 ironhead turn signals
10 DEEP DIVER's JOKE
0 KR style bolt on hard tail for 78 XLCH
Last Post: 45Brit
Last Post: webman94
Last Post: sportyone
Last Post: rocketnorton
0 93 883 Key switch and lighting
Last Post: bklyngeezer
0 Significant exhaust pop at idle.
Last Post: firevf06
0 clean spark plug
0 21 vs 22 vs 23 teeth sprocket
0 Carb fastening screw size?
0 05 carb rebuild no start
0 Accelerator nozzle and idle not right
0 The salty debate thread.
0 Hello New in the Forum
Old 14th April 2015
teamcurtis teamcurtis is offline
Sportster/Buell Model: Sportster C 883 (1200con)
Other Motorcycle Model: Ducati Monster 796
teamcurtis is a splendid one to beholdteamcurtis is a splendid one to beholdteamcurtis is a splendid one to beholdteamcurtis is a splendid one to beholdteamcurtis is a splendid one to beholdteamcurtis is a splendid one to beholdteamcurtis is a splendid one to beholdteamcurtis is a splendid one to beholdteamcurtis is a splendid one to beholdteamcurtis is a splendid one to beholdteamcurtis is a splendid one to behold
Default Cutting a curve or radius - HOW??
I'm about to chop my rear fender.
The main tool i have at my disposal is a cut off wheel. In a few practice swipes making a straight cut is quite simple and doesn't mar the paint much. But it if i try to make any type of arch the cut gets really ugly.
Question is how do i cut along the curve of the fender? I don't want a straight bob look, i want to create a smoother natural curve.
Old 14th April 2015
Airbozo's Avatar
Airbozo Airbozo is offline
Sportster/Buell Model #2: S3T Thunderbolt
Sportster/Buell Year #2: 2000
Other Motorcycle Model: XB12R
Other Motorcycle Year: 2009
Airbozo has a reputation beyond reputeAirbozo has a reputation beyond reputeAirbozo has a reputation beyond reputeAirbozo has a reputation beyond reputeAirbozo has a reputation beyond reputeAirbozo has a reputation beyond reputeAirbozo has a reputation beyond reputeAirbozo has a reputation beyond reputeAirbozo has a reputation beyond reputeAirbozo has a reputation beyond reputeAirbozo has a reputation beyond repute
If you have access to a jig saw, that would be easier.
I have the same issue with my cutoff wheel, but with practice I got a little better. Still not great though and it would require much filing and sanding to make it look even OK.
"...Dumb all over, A little ugly on the side... "...Frank Zappa...
Old 14th April 2015
i have a basic low end handheld jigsaw.
that will cut metal this thick? worth a shot i suppose. Ive left alot of the fender in place as i practice before i make the final cut
Old 14th April 2015
Ireeman's Avatar
Ireeman Ireeman is offline
Asgardian
Sportster/Buell Model: 883r
Other Motorcycle Year: abov
Don't cut it as radius. Make as many angle cuts as needed to achieve the radius.
Hog off as much waste as possible and cut a angle, then another and so on. Eventually you will get what you want, the rest can be blended easily with a file or sander.
Old 14th April 2015
Ranchero50's Avatar
Ranchero50 Ranchero50 is offline
Sportster/Buell Model: 1200 Street Brawler
Ranchero50 has a reputation beyond reputeRanchero50 has a reputation beyond reputeRanchero50 has a reputation beyond reputeRanchero50 has a reputation beyond reputeRanchero50 has a reputation beyond reputeRanchero50 has a reputation beyond reputeRanchero50 has a reputation beyond reputeRanchero50 has a reputation beyond reputeRanchero50 has a reputation beyond reputeRanchero50 has a reputation beyond reputeRanchero50 has a reputation beyond repute
Ditto. Put masking tape on the fender, heat it up with a heat gun to help keep the paint from chipping. Grind short angle and then blend them together. Oh yeah, make a template for one side and flip it over for the other side so they match.
NOTE: Any saw needs at least 1/5 teeth engaged on the material it's cutting or you will strip the teeth and definitely get a crappy cut. I'd suggest a finer (18T) toothed 10" sawzall blade laid flat vs. a jig saw any day.
The build thread... http://xlforum.net/forums/showthread.php?t=1821880
Old 14th April 2015
AB,Frank's Avatar
AB,Frank AB,Frank is offline
serial Canuckian
Sportster/Buell Model: XL1250C
AB,Frank has a reputation beyond reputeAB,Frank has a reputation beyond reputeAB,Frank has a reputation beyond reputeAB,Frank has a reputation beyond reputeAB,Frank has a reputation beyond reputeAB,Frank has a reputation beyond reputeAB,Frank has a reputation beyond reputeAB,Frank has a reputation beyond reputeAB,Frank has a reputation beyond reputeAB,Frank has a reputation beyond reputeAB,Frank has a reputation beyond repute
Like others have said,use masking tape for your cut,trace your cut on the tape,heat the painted surface and I use a Zip blade for such a job....I usually get them from my local welding supply outlet....remember..the smaller the cutting wheel,the easier it is too cut a radius...
The next thing is to use low speed on your grinder of choice,it keeps the heat down and gives you better control...try it out on a piece of scrap metal of the same or close too thickness first
Have fun!!
In three words I can sum up everything I've learned about life: it goes on.
Old 14th April 2015
alright i have a few techniques to try between cutting alot of angles to acheive a curve and using jig saw.
Im cutting away a good bit of metal so the plan was to do a few practice cuts on the bottom end of the fender before the final attempt anyway.
Ill go look for some smaller cut off wheels, and metal jigsaw blades
keep the tips coming
Old 14th April 2015
PuddlePirate's Avatar
PuddlePirate PuddlePirate is offline
Sportster/Buell Model: 883 Hugger/Buell XB12
Sportster/Buell Model #2: Electra Glide
Sportster/Buell Year #2: 2002
PuddlePirate is just really nicePuddlePirate is just really nicePuddlePirate is just really nicePuddlePirate is just really nicePuddlePirate is just really nicePuddlePirate is just really nicePuddlePirate is just really nicePuddlePirate is just really nicePuddlePirate is just really nicePuddlePirate is just really nicePuddlePirate is just really nice
I recently re-chopped my rear fender to something that sounds similar to what you want. I cut the major lines with a cutting wheel on an angle grinder, then used a flap disc on the same grinder to form the curves. The fine grit wheel did a pretty decent job at forming the profile I wanted, just exercise patience and make sure to go slow.
Your limits are self-imposed by what you let your mind believe
Old 14th April 2015
Ireeman's Avatar
Asgardian
You could rent a sheet metal nibbler, they can achieve under 1 inch radii easily.
Old 14th April 2015
tich's Avatar
tich tich is offline
Sportster/Buell Model: 883r -1200
Other Motorcycle Model: 850 Yamaha TRX
Other Motorcycle Year: 98
tich has a reputation beyond reputetich has a reputation beyond reputetich has a reputation beyond reputetich has a reputation beyond reputetich has a reputation beyond reputetich has a reputation beyond reputetich has a reputation beyond reputetich has a reputation beyond reputetich has a reputation beyond reputetich has a reputation beyond reputetich has a reputation beyond repute
use an angle grinder. Small one.
put masking tape on and the put masking tape much lower. use that to practice on.
Keeep the disc at 90 degrees to the metal and stay to the out side of the curve.
As Ireeman said feel free to do as many straight cuts as you like. the grinder will soon take the small corners off to the line you drew. the flat of the disk will smooth it down if your gentle.
Dont forget to practice as a confident cut makes it easy. And that wont be your first cut.
