Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > BUELL MOTORCYCLE FORUM > Buell Motorcycle Electrical and Ignition
0 S&S Super E Carb
0 AGM battery for 76' XLH
Last Post: JonesL
Last Post: BigMek
Last Post: BigMek
Last Post: 1200CustomHD
0 New to me 55kh
Last Post: Nitro57xl
0 so it's officially ended
Last Post: bklyngeezer
Last Post: LLOYD883
Last Post: hexnut
0 What cams are these
Last Post: keithnh
0 Iron head swingarm 6 Inch Stretch
Last Post: Uberstorm
Last Post: rocketnorton
0 Restoring stainless exhaust back to new?
Last Post: beard.tailor
0 My 08' Nightster
0 Nup 1009 (Bearing)
Last Post: retread08
Last Post: JacksBrother
Last Post: Clevspeed
Last Post: ReddTigger
Last Post: Cablejudge
Old 6th June 2016
markfrank markfrank is offline
markfrank is an unknown quantity at this point
Default simple wiring - need help!
Hello All,
Please see the attachment, should I run wires from keys witch to fuse box to power wires? I am confuse on how I need to tie the power wires (Lights, Brake Switch, Coil/Ign, regulator and starter) to the battery/keyswitch for power.
I am using lowbrow water proof switch.
Thank you!
Mark[IMG][/IMG]
Old 6th June 2016
Old 6th June 2016
You should really have a Factory Service Manual with schematics to rewire the bike... However, see this post:
http://xlforum.net/forums/s...46&postcount=5
It shows the relationship of the connections...
1) Notice that the Battery/Starter are on one side of the main fuse and the Alternator/regulator are on the other side... This is intended to protect the battery from catastrophic failure if the alternator/regulator should short to ground...
2) The keyswitch feeds ALL of the individual Fused Circuits - The accessory circuit typically is separately fed to allow the 4-way flashers to function without the rest of the lights being active - If you don't need that function, the Accessory circuit can be fed in parallel with the rest of the fused circuits...
3) Typically, the ignition fuse feeds the Run/Stop Switch, which then feeds (or kills) power to the Ignition Control Module and the Coil... In your case, it looks like it would simply have a hot circuit whenever the keyswitch was on...
__o~~o__
IXL2Relax
