0 tapped adjust
Last Post: ericfreeman
Last Post: XL1275
0 Question for Jorgen, Aaron, ???
0 The salty debate thread.
0 Kicker shaft question
Last Post: Captain Johnny
0 1200S race bike miss at 3500-400
Last Post: Proteus
0 Fuel Pump Problems
Last Post: Lowe175
0 Kick starter resistance
0 Which cams ?
0 Cycle Electric 5000 initial charge time?
Last Post: USAFpj
Last Post: ThrottleBody
0 New Jagg oil cooler adapter for 2004+ Sportsters
Last Post: Randy_rots
0 Matrix brakes
Last Post: tonystylec
6 ironhead turn signals
Last Post: 19ironhead75
0 Mustang Seat FS
0 Static timing
Last Post: ftwflh
0 how to check cam postion sensor
Last Post: ftwflh
0 Hello New in the Forum
Last Post: Dosmie72
yeller1200, IronMick (78), painter (71), motobob883 (68), rickxx (66), MRCLEEN (48), Wetcheez (47), hello_shoes (40)
adjustment, head light, headlight, headlight bucket
Old 15th June 2016
Oldrump1 Oldrump1 is offline
Sportster/Buell Model: fxr xl1200 5sp
Sportster/Buell Year: 95
Oldrump1 has much to be proud ofOldrump1 has much to be proud ofOldrump1 has much to be proud ofOldrump1 has much to be proud ofOldrump1 has much to be proud ofOldrump1 has much to be proud ofOldrump1 has much to be proud ofOldrump1 has much to be proud ofOldrump1 has much to be proud ofOldrump1 has much to be proud ofOldrump1 has much to be proud of
Default my spell check on overload
God help me. I'm not a academic A hole but passing on confusing or misleading info bites my buns. Just trying to help.
Bustart you are one hell of a machinist. I bow to your skill.
Crocus cloth is an abrasive sheet similar to sand paper or emery cloth but covered with a layer of very fine loose iron oxide particles rather than with bound grains of abrasive. It is intended for final metal and gemstone finishing and is available in various grades (particle sizes).
Gene
:cucumber I don't wanna pickle, just wanna ride my motorsickle:banana :smoke
Gene
Old 15th June 2016
mzavala2424's Avatar
mzavala2424 mzavala2424 is offline
Sportster/Buell Year: 1989
mzavala2424 has much to be proud ofmzavala2424 has much to be proud ofmzavala2424 has much to be proud ofmzavala2424 has much to be proud ofmzavala2424 has much to be proud ofmzavala2424 has much to be proud ofmzavala2424 has much to be proud ofmzavala2424 has much to be proud ofmzavala2424 has much to be proud ofmzavala2424 has much to be proud ofmzavala2424 has much to be proud of
Thanks Gene, I was having trouble finding info on that. It sounds like that or some emery cloth might be a good thing to try. I'm thinking it might be best to put it between the cup on the headlight bucket and the eyebrow to give it more bite.
Old 15th June 2016
I have no issues here! it is what it is. there are diffs but there are similarities and often used interchangeably and yes it does come in rolls and other forms as well.
https://www.lawsonproducts.com/lawso...-Roll/90564.lp
Old 15th June 2016
mikeLI_77's Avatar
I would just stuff a star washer between the cup and headlight and tighten it down. The little teeth it has around the edge should hold it no problem. Plus it's washers are usually soft enough that when you tighten them down they will bend and take the shape of the cup.
2002 XL1200C (originally)
Dyno Sheet
96.21 HP/88.70 TQ
States I Have rode through
Old 15th June 2016
Kawa110 Kawa110 is offline
Kawa110 has a brilliant futureKawa110 has a brilliant futureKawa110 has a brilliant futureKawa110 has a brilliant futureKawa110 has a brilliant futureKawa110 has a brilliant futureKawa110 has a brilliant futureKawa110 has a brilliant futureKawa110 has a brilliant futureKawa110 has a brilliant futureKawa110 has a brilliant future
I believe I remember my nut had little divetes around the flat side in crown to make it tapered when I tightned it down, the first time I though I was cross threading and pulled it apart, all checked out so I put back together. May have wrong nut or need new hardware....
Old 15th June 2016
I might be wrong, but I know it all felt tapered when going together....
Old 15th June 2016
Hey Kawa1100 I dont think the original nut on mine was anything special all the parts diagrams I've looked at just list it as a 1/2-13 nut and the Colony Hardware replacement kit comes with just a standard nut, lock-washer and beveled washer. It might be that newer EVO's use a different nut than the 4 speeds.
Thanks MikeLI_77, that was my next idea was to use a star washer, I just need to find one big enough. Glad I'm not the only one who thinks between the cup and mount is the place to fix.
Old 22nd June 2016
Just giving an update for anyone who had this problem.
For now I have a big rubber washer between the headlight bucket and the eyebrow and it is holdign well so far. I also found a large star washer that I will keep on hand in case the rubber washer ends up failing. It seems like the rubber is giving it just enough bite to hold the light in place though.
Old 26th June 2016
Alexintenn Alexintenn is offline
Sportster/Buell Model: 883 Sporster
Sportster/Buell Year: 1987
Alexintenn is a name known to allAlexintenn is a name known to allAlexintenn is a name known to allAlexintenn is a name known to allAlexintenn is a name known to allAlexintenn is a name known to allAlexintenn is a name known to allAlexintenn is a name known to allAlexintenn is a name known to allAlexintenn is a name known to allAlexintenn is a name known to all
Add some Goop to the rubber washer. Similar to silicone sealer except a bit easier to peel off when you want to.
Old 26th June 2016
My 87 does not have the button on the headlight cover. How does it adjust?
