0 tapped adjust
Last Post: ericfreeman
Last Post: XL1275
0 Question for Jorgen, Aaron, ???
0 The salty debate thread.
0 Kicker shaft question
Last Post: Captain Johnny
0 1200S race bike miss at 3500-400
Last Post: Proteus
0 Fuel Pump Problems
Last Post: Lowe175
0 Kick starter resistance
0 Which cams ?
0 Cycle Electric 5000 initial charge time?
Last Post: USAFpj
Last Post: ThrottleBody
0 New Jagg oil cooler adapter for 2004+ Sportsters
Last Post: Randy_rots
0 Matrix brakes
Last Post: tonystylec
6 ironhead turn signals
Last Post: 19ironhead75
0 Mustang Seat FS
0 Static timing
Last Post: ftwflh
0 how to check cam postion sensor
Last Post: ftwflh
0 Hello New in the Forum
Last Post: Dosmie72
yeller1200, IronMick (78), painter (71), motobob883 (68), rickxx (66), MRCLEEN (48), Wetcheez (47), hello_shoes (40)
basket, clutch, grooves, sportster
  #31
Old 10th October 2016
ioan74's Avatar
ioan74 ioan74 is offline
Sportster/Buell Model: 883R
ioan74 is a name known to allioan74 is a name known to allioan74 is a name known to allioan74 is a name known to allioan74 is a name known to allioan74 is a name known to allioan74 is a name known to allioan74 is a name known to allioan74 is a name known to allioan74 is a name known to allioan74 is a name known to all
It is a standard socket. The Factory Service Manual has the torque values so go by that. I used an 8 ft long piece of pipe on my breaker bar to break the nuts loose. There is a thread somewhere on using a 4 inch brass hinge between the teeth of the clutch and rotor to keep the primary from turning if not using an impact wrench. Also, one is left threads so be sure you are turning the correct way.
Also, I think the basket comes with the bearing however you may want to confirm before you purchase
With long I mean like this: http://c.shld.net/rpx/i/s/i/spin/image/spin_prod_226124701?hei=245&
wid=245&op_sharpen=1&qlt=85
, because the shaft protrudes a little, by 1/2" or so.
These things are difficult to get here. I'll try with a normal one first, and hope my impact wrench can do it. Because 8ft pipes are kind of discouraging ;-)
ParrotHead's Avatar
Other Motorcycle Year: 1974
I do not have an impact wrench or air compressor
I am positive I do not have a long (deep as we call them) socket. However, the standard chrome socket may not hold up to an impact wrench so be careful.
John Wayne - "The Shootist"
[URL="https://chrisridingadventures.wordpress.com/"]Check out my Blog[/URL] for my trip reports:
[URL="https://www.buzzsprout.com/129999/841095-episode-170-interview-with-chris-comly-of-chris-riding-adventures-blog"]Click here [/URL]to listen to my interview about my Sporty and riding on the Motorcycle Men Podcast
[URL="https://www.buzzsprout.com/129999/2188085-episode-221-interview-with-iron-butt-rally-veteran-chris-comly?fbclid=IwAR2AuBjIEvI8AoLtC7ZCZ4VC5Er_Guo8WfaRjh-15tRD9a5_rLYlp_jdJBg"]Click here [/URL]to listen to my interview about the Iron Butt Rally on the Motorcycle Men Podcast
[URL="https://horizon.bmwmoa.org/episode-93-chris-comly/"]
Click here[/URL] to listen to my interview on the Chasing the Horizon Podcast
[URL="http://sportsterpedia.com/doku.php/start"]Click here for the Sportsterpedia![/URL] for technical information & advice
Old 11th October 2016
Sometimes you can get by with a short socket just don't seat it fully on the breaker bar, oh, and my pipe is only 6ft. Long.
O.R. John's Avatar
O.R. John O.R. John is offline
Sportster/Buell Model #2: Street 500
Sportster/Buell Year #2: 2016
O.R. John has a reputation beyond reputeO.R. John has a reputation beyond reputeO.R. John has a reputation beyond reputeO.R. John has a reputation beyond reputeO.R. John has a reputation beyond reputeO.R. John has a reputation beyond reputeO.R. John has a reputation beyond reputeO.R. John has a reputation beyond reputeO.R. John has a reputation beyond reputeO.R. John has a reputation beyond reputeO.R. John has a reputation beyond repute
Jeez!
Every great and commanding movement in the annals of the world is the triumph of enthusiasm. ~ Ralph Waldo Emerson
ParrotHead's Avatar
..., oh, and my pipe is only 6ft. Long.
It's true then that things do shrink with age?
Old 20th October 2016
ioan74's Avatar
Well, to close the subject too, just discovered the real faulty clutch cause.
Cracked clutch hub, the base of the shoulder the frictions press against.
I am told not to use original, but better aftermarket. Need to locate this part from Barnett or others...
ParrotHead's Avatar
Cracked clutch basket.
Ouch!
O.R. John's Avatar
Wow! Of all of the things that could have been wrong with your clutch, I am surprised that it was this!
