Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > BUELL MOTORCYCLE FORUM > Buell Motorcycle Top End
0 Need Tuning Advice 1275 Kit 560 Cams
0 old parts
0 Xl???
0 "S" model specific Q&A
0 Hello from LA area
0 Generator light q
Last Post: Doc308
Last Post: Gulf Coaster
0 so it's officially ended
Last Post: 1200CustomHD
Last Post: ericfreeman
0 New to me 55kh
Last Post: joes95bobber
0 Oil Bag?
Last Post: owlsplace
Last Post: rocketnorton
0 Rear sets?
Last Post: bordens
0 Mustang Seat FS
0 Round Air Cleaner Poll
0 Nup 1009 (Bearing)
Last Post: Racepres
0 S&S Super E Carb
Last Post: Full-Bore12
0 New oil tank
Old 28th May 2019
herostar herostar is offline
Sportster/Buell Model #2: XB9R
herostar is just really niceherostar is just really niceherostar is just really niceherostar is just really niceherostar is just really niceherostar is just really niceherostar is just really niceherostar is just really niceherostar is just really niceherostar is just really niceherostar is just really nice
Default Heads coming off - What else should I do? XB9R
Hello everyone!
I had two exhaust studs break off, one in each cylinder head, so I'm going to need to remove the heads to get the broken studs extracted/replaced at a machines shop.
My question for you all: What else should I be doing while the heads are off? I'm not looking to go deep porting/polishing or anything, but am curious if there are "normal" maintenance things I should take care of while everything is off the bike.
FYI this is for a 2003 XB9R
Thanks in advance for your help!
2007 XL1200R - Denver, CO
Old 28th May 2019
ParrotHead's Avatar
Other Motorcycle Year: 1974
I'd replace the base gaskets also
John Wayne - "The Shootist"
[URL="https://chrisridingadventures.wordpress.com/"]Check out my Blog[/URL] for my trip reports:
[URL="https://www.buzzsprout.com/129999/841095-episode-170-interview-with-chris-comly-of-chris-riding-adventures-blog"]Click here [/URL]to listen to my interview about my Sporty and riding on the Motorcycle Men Podcast
[URL="https://www.buzzsprout.com/129999/2188085-episode-221-interview-with-iron-butt-rally-veteran-chris-comly?fbclid=IwAR2AuBjIEvI8AoLtC7ZCZ4VC5Er_Guo8WfaRjh-15tRD9a5_rLYlp_jdJBg"]Click here [/URL]to listen to my interview about the Iron Butt Rally on the Motorcycle Men Podcast
[URL="https://horizon.bmwmoa.org/episode-93-chris-comly/"]
Click here[/URL] to listen to my interview on the Chasing the Horizon Podcast
[URL="http://sportsterpedia.com/doku.php/start"]Click here for the Sportsterpedia![/URL] for technical information & advice
Old 28th May 2019
seajay's Avatar
seajay seajay is offline
Sportster/Buell Year: 04
Any part of the studs sticking out from the heads? If yes, you might be able to remove them with a stud extractor.
Old 28th May 2019
60Gunner's Avatar
60Gunner 60Gunner is online now
Probably not necessary especially if you dont disturb the cylinders. If you do it means means pulling at least 1 wrist pin clip per and the wrist pins. Leave the pistons in the cylinders or you're doing rings.
I'd try getting the broken studs out without removing the heads first.
Old 28th May 2019
Highly-Dangerous's Avatar
X2
[B][COLOR="Red"]CLICK->>[/COLOR][URL="http://sportsterpedia.com/doku.php/start"]"Maintenance is as much art as it is science"[/URL][COLOR="red"]<<-CLICK[/COLOR][/B]
[IMG]http://xlforum.net/forums/attachment.php?attachmentid=20617&d=1576580635[/IMG]
Old 28th May 2019
Sprtstr1200s's Avatar
Sprtstr1200s Sprtstr1200s is offline
Sportster/Buell Model: Sportster XL1200s
Sprtstr1200s has a reputation beyond reputeSprtstr1200s has a reputation beyond reputeSprtstr1200s has a reputation beyond reputeSprtstr1200s has a reputation beyond reputeSprtstr1200s has a reputation beyond reputeSprtstr1200s has a reputation beyond reputeSprtstr1200s has a reputation beyond reputeSprtstr1200s has a reputation beyond reputeSprtstr1200s has a reputation beyond reputeSprtstr1200s has a reputation beyond reputeSprtstr1200s has a reputation beyond repute
Replace valve springs. Lap the valves see what seats look like.
Old 28th May 2019
I'll definitely be replacing gaskets.
The studs broke off just under flush with the heads, so no option to try and remove them without removing the head (trust me, been sitting on this for 5 weeks trying to work a solution that didn't involve pulling the heads...).
What's the reasoning behind replacing the valve springs and lapping the valves?
Bike has ~12k miles on it.
Old 28th May 2019
60Gunner's Avatar
You have good valve springs in those heads. He had weaker ones in his `99. I wouldn't mess with the valves either unless you're having an issue like leaky guide seals. In that case maybe test your springs since they're out anyway to do the seals. Lap the valves too since they're already out.
Old 28th May 2019
If you have equipment to check such things seat pressures, you find springs (exhaust) have weakened. Also lapping valves by hand can't hurt. Unfortunate you didn't leak down motor before disassembly.
Old 28th May 2019
Exclamation
I don't know what shape my springs are in. Haven't opened the motor yet.
