Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > FORUM FUNCTIONS > Introduce Yourself
0 Cycle Electric 5000 initial charge time?
0 Kick starter resistance
0 tapped adjust
Last Post: ericfreeman
Last Post: XL1275
0 Question for Jorgen, Aaron, ???
0 The salty debate thread.
0 Kicker shaft question
Last Post: Captain Johnny
0 1200S race bike miss at 3500-400
Last Post: Proteus
0 Fuel Pump Problems
Last Post: Lowe175
0 Which cams ?
Last Post: ThrottleBody
0 New Jagg oil cooler adapter for 2004+ Sportsters
Last Post: Randy_rots
0 Matrix brakes
Last Post: tonystylec
6 ironhead turn signals
Last Post: 19ironhead75
0 Mustang Seat FS
0 Static timing
Last Post: ftwflh
0 how to check cam postion sensor
Last Post: ftwflh
0 Hello New in the Forum
Last Post: Dosmie72
yeller1200, IronMick (78), painter (71), motobob883 (68), rickxx (66), MRCLEEN (48), Wetcheez (47), hello_shoes (40)
Old 12th August 2019
Folkie's Avatar
Folkie Folkie is offline
Brass Nut
Sportster/Buell Year: 2015
Welcome to the Forum from the UK!
Folkie
South East England Riders
rokytnji's Avatar
rokytnji rokytnji is offline
Sportster/Buell Year #2: 1983
Other Motorcycle Year: 1990
Never heard of a motor blowing up because of a leaky ball check valve or weak spring.
Howdy and Welcome.
Traveled to
Daniel, welcome to the forum family from a swamp in Michigan.
daniel91 daniel91 is offline
Sportster/Buell Year: 1972
daniel91 has much to be proud ofdaniel91 has much to be proud ofdaniel91 has much to be proud ofdaniel91 has much to be proud ofdaniel91 has much to be proud ofdaniel91 has much to be proud ofdaniel91 has much to be proud ofdaniel91 has much to be proud ofdaniel91 has much to be proud ofdaniel91 has much to be proud ofdaniel91 has much to be proud of
Thanks for the comments. I will try to share new videos and photos.
Rokytnji This is my first harley. I feel bad when I can't explain something.The engine after repair works without problems for 2000km.
juzyHD's Avatar
juzyHD juzyHD is offline
Master Bike Builder
Sportster/Buell Year: 1986
Welcome from Slovenia!
Maxeffort's Avatar
Momentary Specialist
Sportster/Buell Model: XL1200
Greeting from Massachusetts!
You did it the hard way, but you know every bit of the motorcycle and it's all yours. Congratulations, nice going!
rokytnji's Avatar
All of us had to start from some where. I just got a earlier start is all.
Major motor failure I have seen relating to: but neither related to primary AND Tranny abuse by the owner.
Intake leaks at freeway speeds for long distance. Exhaust leaks not fixed.
No carb support. Owner has no clue on how to reassemble A motorcycle and
it flys apart aftwards < Think cam gear timing, oil pump passages blocked with silicone, stuff of that sort>.
Things you may never have a clue on why things flew apart. I've seen these motors < older ones > take some horrendous re-assembly and get one to a destination to fix things right. Hundreds of miles away. Pretty sure InsaneShane owns the breakage trophy on this site. Good thing he is wrench also.
Take it slow. Fix stuff right when ya can. Adapt and overcome if ya can't.
Some of the best fixes are not conventional sometimes.
Above shot shows a abandoned hardtail and the customer don't want spend money.
300 bucks later it would hold fresh oil < new hoses and worm clamps where needed > . Start. Run. Idle. Shift. Barely stop. Barely turn a corner. Slow air leakage. But. Ridable home on the freeway for 300 bucks.
Old 13th August 2019
Highly-Dangerous's Avatar
Welcome from Spain!
[B][COLOR="Red"]CLICK->>[/COLOR][URL="http://sportsterpedia.com/doku.php/start"]"Maintenance is as much art as it is science"[/URL][COLOR="red"]<<-CLICK[/COLOR][/B]
[IMG]http://xlforum.net/forums/attachment.php?attachmentid=20617&d=1576580635[/IMG]
In the engine I replaced:
new pistons and rings, cylinders reboring up from .040 to .050
new connecting rods and flywheel thrust washers
new main bearings, conversion to a new type of bearing, two separate taper bearings and needle bearing with inner race
lapping valves and little porting of head
new gaskets and seals
painting cylinders and heads, engine case glass bead blasting
repair generator, replaced starter solenoid
I didn't have time to polish cam and clutch covers
