0 so it's officially ended
0 New to me 55kh
Last Post: 45Brit
0 S&S Super E Carb
0 AGM battery for 76' XLH
Last Post: JonesL
Last Post: BigMek
Last Post: BigMek
Last Post: 1200CustomHD
Last Post: bklyngeezer
Last Post: LLOYD883
Last Post: hexnut
0 What cams are these
Last Post: keithnh
0 Iron head swingarm 6 Inch Stretch
Last Post: Uberstorm
Last Post: rocketnorton
0 Restoring stainless exhaust back to new?
Last Post: beard.tailor
0 My 08' Nightster
0 Nup 1009 (Bearing)
Last Post: retread08
Last Post: JacksBrother
Last Post: Clevspeed
Last Post: ReddTigger
Last Post: Cablejudge
View Poll Results: What jets do you typically use? Choose all that apply.
#42 slow 80 10.38%
#45 slow 491 63.68%
#48 slow 128 16.60%
#165 main 32 4.15%
#170 main 111 14.40%
#175 main 160 20.75%
#180 main 229 29.70%
#185 main 95 12.32%
#190 main 63 8.17%
Yes my needle is shimmed 148 19.20%
No my needle is not shimmed 241 31.26%
Other, explain. 82 10.64%
Multiple Choice Poll. Voters: 771. You may not vote on this poll
  #231
Old 31st May 2017
gpydeski gpydeski is offline
Sportster/Buell Year: 1970
gpydeski is a splendid one to beholdgpydeski is a splendid one to beholdgpydeski is a splendid one to beholdgpydeski is a splendid one to beholdgpydeski is a splendid one to beholdgpydeski is a splendid one to beholdgpydeski is a splendid one to beholdgpydeski is a splendid one to beholdgpydeski is a splendid one to beholdgpydeski is a splendid one to beholdgpydeski is a splendid one to behold
My 45/180 is on my 1200 Shovel with two into one with a great sounding aftermarket muffler. I have a question though. What are the purpose of the shims under the needle?
Old 31st May 2017
Folkie's Avatar
Folkie Folkie is offline
Brass Nut
Sportster/Buell Year: 2015
Putting a shim under the needle raises the needle, and, in effect, changes its length. Once the needle starts to rise, it brings the taper in sooner, and at any particular point while the taper is in play, it make the mixture richer. As you can no doubt imagine, the changes are very small. This is very much about fine tuning.
Folkie
South East England Riders
Old 18th August 2017
iamandrewx's Avatar
iamandrewx iamandrewx is offline
Sportster/Buell Model: Sportster XL1200c
iamandrewx is an unknown quantity at this point
'06 1200
no name slip-on drags
stock AC w/ HD filter
CVP kit
extended screws
45 pilot, 180 main
having trouble with maintaining even throttle, engine power. seems like it was to burb, hiccup, chug, missfire in gears 1-3 @ speeds of 0-35mph.
first time tuning a carb and i just can't figure it out. i understand the basics and have read all the links.... not sure what i am experiencing and don't know what to exactly call it to find help resolving.
'06 HD Sportster 1200c //
Old 19th August 2017
CVPerformance CVPerformance is offline
Sportster/Buell Model: XLH 883>1200
Sportster/Buell Year: 1988
Other Motorcycle Model: FXE
Other Motorcycle Year: 1976
CVPerformance is a splendid one to beholdCVPerformance is a splendid one to beholdCVPerformance is a splendid one to beholdCVPerformance is a splendid one to beholdCVPerformance is a splendid one to beholdCVPerformance is a splendid one to beholdCVPerformance is a splendid one to beholdCVPerformance is a splendid one to beholdCVPerformance is a splendid one to beholdCVPerformance is a splendid one to beholdCVPerformance is a splendid one to behold
Your jetting sounds fine and the conditions described are more likely the result of a vacuum leak (most common) or perhaps the need to adjust your mixture screw. If you have the CVP kit that comes with the EZ-Just then the below link talks about adjusting that mixture to find the sweet spot in the transition between idle and mid range.
Mixture Screw Adjustment
It cannot be emphasized enough that vacuum leaks can really throw things off. Having said that, here are some of the other common problems encountered before or after rebuilding a CV carburetor:
https://cv-performance.com/harley-cv-carburetor-tuning-issues
Old 31st August 2017
frankjc's Avatar
frankjc frankjc is offline
Sportster/Buell Model: 883
frankjc will become famous soon enoughfrankjc will become famous soon enoughfrankjc will become famous soon enoughfrankjc will become famous soon enoughfrankjc will become famous soon enoughfrankjc will become famous soon enough
42, and 160, screw ~3 turns out. I am not sure, but I may be a little lean, once in a while i get a slight cough at the carb. Normal?
88 sportster 883, 2001 motor, S&S shorty E carb, drag pipes.
drgonzo21's Avatar
drgonzo21 drgonzo21 is offline
drgonzo21 has much to be proud ofdrgonzo21 has much to be proud ofdrgonzo21 has much to be proud ofdrgonzo21 has much to be proud ofdrgonzo21 has much to be proud ofdrgonzo21 has much to be proud ofdrgonzo21 has much to be proud ofdrgonzo21 has much to be proud ofdrgonzo21 has much to be proud ofdrgonzo21 has much to be proud ofdrgonzo21 has much to be proud of
2002 1200S
Kerker 2 into 1
Air Hammer Impact
200 MJ
46 PJ
NOKK Needle
No shims
2.5 turns out- mixture screw
Old 1st September 2017
Don Burton's Avatar
I wouldn't try to drown out a "once in a while slight cough at the carb" with too much fuel if your mixture is otherwise correct and your bike runs well. Your jetting/settings don't sound far off for an 883 with a decent exhaust rather than drag oipes.
Folkie's Avatar
Brass Nut
+1
Nice to hear from you again Dan.
frankjc's Avatar
I think I am going to leave as it is for now, thank you.
Skuzeee's Avatar
Skuzeee Skuzeee is offline
Sportster/Buell Model: Xl1200c
Skuzeee has disabled reputation
When I bought my bike, a 97 1200, it had drag pipes, stock air set up and stock jetting 42/170. I switched the pilot jet to a 45, which made it run better but it still had a decel pop.
I just put on Samson 2 into1 pipes and it ran horrible, no power, popped like crazy, so this morning I switched back to a 42 slow. The decel pop is still there, but huge improvement in performance.
