10 DEEP DIVER's JOKE
0 KR style bolt on hard tail for 78 XLCH
Last Post: 45Brit
Last Post: webman94
0 2015 883 with S&S 1200 conversion kit
Last Post: sportyone
Last Post: rocketnorton
6 ironhead turn signals
Last Post: BigMek
0 93 883 Key switch and lighting
Last Post: bklyngeezer
0 Riding music
Last Post: XL1275
0 Significant exhaust pop at idle.
Last Post: firevf06
0 Cobra NH slipons
Last Post: Skeezix
0 clean spark plug
0 21 vs 22 vs 23 teeth sprocket
0 Carb fastening screw size?
0 05 carb rebuild no start
0 Accelerator nozzle and idle not right
0 The salty debate thread.
0 Hello New in the Forum
Old 23rd February 2010
Cosmo Kramer's Avatar
Sportster/Buell Model: 1200N
Default How-To: Rewire for the Removal of the Rear Fender Mounted Brake Light w/HD Module
Well this was brought up in a 07'+ section but I know it applies also to 04'+ sportsters at a minimum...so I wanted to post it in a better section. When the HD Brake/Run/Turn Light Module is installed it plugs inbetween the main harness and the wiring harness going back to the rear fender mounted brake light. Therefore, if you want to eliminate that fender mounted brake light you have to keep the circuit board/box and find a new home for it.
While I don't have this problem as I own an N....I came up with a wiring diagram. The first set of diagrams show the wiring when the stock wiring harness are reused along with the stock turn signal connectors. Please keep in mind that the rear turn signal connectors and pigtails only goes to where the rear fender mounted brake light is currently located...so they are fairly short and you'll need to zip tie the connectors to the rear fender support underneath. If you chop the fender...you'll want to look at Option #2.
Option #1 (Stock Rear Lighting Wire Harness and Turn Signal Connectors):
Material required:
Aux. Brake/Run/Turn Signal Module (HD Part #69463-06) ~ 1 Req'd: $59.95 ea.
Female Connector (HD Part #73106-96BK) ~ 1 Req'd: $1.75 ea.
Female Connector (HD Part #73102-96BK) ~ 3 Req'd: $0.95 ea.
Pins (HD Part #73190-96) ~ 10 Req'd: $0.49 ea.
New Wire Harness required for Option #1:
Note that I do not call out specific information on the license plate light....that is because there will have to be a new one as it was intergral in the rear mounted brake light.
Option #2 (New Wiring Harness from HD Brake/Run/Turn Module - Recommended):
Female Connector (HD Part #73152-96BK) ~ 3 Req'd: $0.85 ea.
Pins (HD Part #73190-96) ~ 6 Req'd: $0.49 ea.
Pins (HD Part #73191-96) ~ 6 Req'd: $0.50 ea.
New Wire Harness required for Option #2:
Note that the prices I show are retail...and there is some discount I saw on Chicago HD and Zanotti's website if you look up the part #'s listed above.
Cosmo
Erik's Avatar
Erik Erik is offline
Sportster/Buell Model: SOLD 883/1200 Sportster
Sportster/Buell Model #2: -
Sportster/Buell Year #2: -
Other Motorcycle Model: KTM 990 SMT
Other Motorcycle Year: 2009
Erik is a splendid one to beholdErik is a splendid one to beholdErik is a splendid one to beholdErik is a splendid one to beholdErik is a splendid one to beholdErik is a splendid one to beholdErik is a splendid one to beholdErik is a splendid one to beholdErik is a splendid one to beholdErik is a splendid one to beholdErik is a splendid one to behold
That is excellent stuff, Cosmo. I ain't using it but it is what this place is about so have some rep !!
Erik
(A Dutch Rider)
nightsterfreak's Avatar
nightsterfreak nightsterfreak is offline
Sportster/Buell Model: Nightster 1200N
nightsterfreak is on a distinguished roadnightsterfreak is on a distinguished roadnightsterfreak is on a distinguished roadnightsterfreak is on a distinguished roadnightsterfreak is on a distinguished road
Dude, how do you know all this stuff? Cosmo you are the man!...LOL
The Rev
"Ride Forth Victoriously"- Psalms 45:4
2009 Nightster 1200N
.....I have the service manuals....
On a good day I know nothing!
Thanks Erik!...I agree.....it is what this place is all about!
LOL...Your a good guy Cosmo...and hey I got those black rocker tops today, when I get off work they are going on!!!!
DIESEL's Avatar
DIESEL DIESEL is offline
I bought the nightster module. Hardwired it. Had to use dual element signals. Worked like a charm.
vettelover84's Avatar
vettelover84 vettelover84 is offline
Sportster/Buell Model: XL883CX
Other Motorcycle Model: Yamaha YZ250F
Other Motorcycle Year: 2008
vettelover84 has much to be proud ofvettelover84 has much to be proud ofvettelover84 has much to be proud ofvettelover84 has much to be proud ofvettelover84 has much to be proud ofvettelover84 has much to be proud ofvettelover84 has much to be proud ofvettelover84 has much to be proud ofvettelover84 has much to be proud ofvettelover84 has much to be proud ofvettelover84 has much to be proud of
This is what I need to do... For now I am usingg the module..
08 Sportster XL883X- A few very minor mods... RIP- BryanEOD
MonkeyMouse's Avatar
MonkeyMouse MonkeyMouse is offline
Sportster/Buell Model: XL883L
MonkeyMouse is a jewel in the roughMonkeyMouse is a jewel in the roughMonkeyMouse is a jewel in the roughMonkeyMouse is a jewel in the roughMonkeyMouse is a jewel in the roughMonkeyMouse is a jewel in the roughMonkeyMouse is a jewel in the roughMonkeyMouse is a jewel in the roughMonkeyMouse is a jewel in the roughMonkeyMouse is a jewel in the roughMonkeyMouse is a jewel in the rough
Very nice dude, this will help alot of people. Would make a good sticky, this question seems to pop up alot.
--Trevor
2007 XL883L- Pearl black or nighty tins, V&H short or side shots depends on my mood lol, Drag bars, fwd. controls, mini speedo, wire tuck, coil and ignition moved, solo saddle, other stuff moved/removed.
Old 24th February 2010
Diesel, when you said you used the dual element signals with the nightster module...do you mean that you bought the nightster turn signal "guts" (for lack of a better term) too? As you know, the stock non-Nighster/Iron turn signals are 2-wire (simply power and ground) lights while the Nightster/Iron I believe are 3 or 4 wire....can't remember which. Curious how you did this.
I was going to recommend this however the price I saw for the Nightster module alone was around $75-90...and then you still need the guts for the Nightster style turn signals from what I saw. The price of the HD Module is around $50-60....so price wise it is a little more cost effective.
DIESEL's Avatar
They have three wires each, if memory serves me correctly. I got some take off's from the fronts of another sporty at a swap meet. to use the nightster module (under the seat--wiring thing) you need to use dual element.
