0 Opinions
Last Post: Racepres
0 Static timing
0 Which cams ?
0 Fuel Pump Problems
Last Post: Lowe175
0 Front end restoration
Last Post: Dosmie72
0 Hello New in the Forum
0 Accelerator nozzle and idle not right
Last Post: hexnut
0 Kicker shaft question
Last Post: Captain Johnny
0 Spitfire motorcycle 2 into 1 Blaster
Last Post: Bmyers
0 The salty debate thread.
Last Post: Uberstorm
Last Post: XL1275
14 How To: View HD Part #'s 1991-2010 - All Models - With Part #'s and Exploded Views!!
Last Post: Eddie65
Last Post: MikeBel
0 Kick starter resistance
Last Post: metal88
Last Post: Proteus
0 19" Tire w/23" Overall Diameter???
0 Smacked a deer last night
1200r, brake, master cylinder, xr1200, xr1200 brakes
Old 25th April 2010
Screw Loose Dan's Avatar
I think I like Sportsters
Sportster/Buell Year #2: 2016
Originally Posted by Rascal View Post
Excellent instructions and pics Dan, enjoyed your posts.
Originally Posted by bighit4u32 View Post
Another great write up dan, I pretty much used your previous one to do my dual brembo conversion. I will also be very interested to hear how these compare to the brembos. I hope they're not too much better or I might have to start surfing ebay again
Thanks guys!
Originally Posted by XLXR View Post
I found the XR brakes to be much more sensitive and require much less finger pressure than my Roadster brakes. Be careful about locking up the front tire.
You should try switching from my 883L with the Brembo/VROD setup to the stock 1200R setup...the 1200R isn't bad, but a bit vague in comparison. From my initial rides, the XR brakes are much more inline with the Brembo/VROD setup.
Screw Loose Dan
Current fleet:
2007 - 1200R (Orange bike)
2012 - XR1200X (XR)
Old 25th April 2010
biknut's Avatar
biknut biknut is offline
Sportster/Buell Year: 1988
What size is your master cylinder? 9/16, 11/16, or ???
Old 25th April 2010
D-Rock's Avatar
D-Rock D-Rock is offline
D-Rock is just really niceD-Rock is just really niceD-Rock is just really niceD-Rock is just really niceD-Rock is just really niceD-Rock is just really niceD-Rock is just really niceD-Rock is just really niceD-Rock is just really niceD-Rock is just really niceD-Rock is just really nice
Looks great Dan! I would be tripped the -I LUV XLF!--I LUV XLF!--I LUV XLF!--I LUV XLF!- out though with how close the calipers are to the wheel, but I guess your called screw loose Dan for a reason, huh.
Burn it!!! I mean tires of course...
[SIGPIC][/SIGPIC]
2008 XL1200R Black Pearl. Vance & Hines Sideshots, SE Heavy Breather, Power Commander IIIUSB, HD 1/4 Fairing, 13-1/2" Progressive 440 IAS Rear Shocks, Intiminators & Superbrace for Front Suspension, Mustang Vintage Solo Under the Tail Bone , Metzler ME880 shoes, Un-Molested Motor...
[URL="http://xlforum.net/forums/showthread.php?t=913536"]Dons Cycleware Saddlebags[/URL]
Old 25th April 2010
sportytrace's Avatar
OzChick
Sportster/Buell Year: 08
My understanding is the master cylinder from the XR1200 is 15.87mm bore... I guess that is around 10/16??? .... anyway, somewhat larger bore than the stock 1200R's 14mm.
Old 25th April 2010
evereyken's Avatar
evereyken evereyken is offline
Sportster/Buell Model: 883r convert to 1214 SOLD
Other Motorcycle Model: DL650AL2 VStrom
evereyken is just really niceevereyken is just really niceevereyken is just really niceevereyken is just really niceevereyken is just really niceevereyken is just really niceevereyken is just really niceevereyken is just really niceevereyken is just really niceevereyken is just really niceevereyken is just really nice
Outstanding! That 1200R is coming together very nicely. What's next?
SOLD on 4/3/12 - '06 883R with NRHS 1214 conversion using Wiseco 9.5:1 pistons, w cams, TC88A ICM, RevTech FXDX AC, 45/180 jetting, IMS 2.5 turns, Bub/Rinehart 2 into 1, 1200s bars, Progressive front springs w/10wt BelRay, Superbrace, 1200s rear shocks, tach kit, Flyscreen, Jagg oil cooler
Now riding a 2012 Suzuki DL650AL2 "WeeStrom"
Old 25th April 2010
Ralphthe3rd's Avatar
Ralphthe3rd Ralphthe3rd is offline
Sportster/Buell Model: 883R
Sportster/Buell Model #2: Buell P3
Other Motorcycle Model: Ninja650R traded for 883R
Ralphthe3rd is a splendid one to beholdRalphthe3rd is a splendid one to beholdRalphthe3rd is a splendid one to beholdRalphthe3rd is a splendid one to beholdRalphthe3rd is a splendid one to beholdRalphthe3rd is a splendid one to beholdRalphthe3rd is a splendid one to beholdRalphthe3rd is a splendid one to beholdRalphthe3rd is a splendid one to beholdRalphthe3rd is a splendid one to beholdRalphthe3rd is a splendid one to behold
Dan, as always, nice write up and cool conversion. I love what you've done to your 1200R
BTW- change of subject. But how many miles are on your 883L now ? And have you changed out your rear fork(thats what the factory calls it) bearings yet ? The manual says they should be changed at 30,000 miles ? I'm almost at 30k miles myself !
~Ralph (gonna try not being so Feisty)
*Former- AMA N.E. District 2 Flattracker #15u '74-'84
Old 25th April 2010
khaskins's Avatar
khaskins khaskins is offline
Other Motorcycle Year: 1970
Kind of off topic question. I'd like to do a single Brembo on the front of my 883L. How must of an improvement will it be? I already have a braided line and better than stock brake pads. I'd really like better brakes without going dual disk up front.
2006 883L
AN Big Sucker Stage 1
Vance & Hines Side Shots
Joker Machine Speedo Mount
Speedway Instrument MicroTach
Mid Controls
Progressive Fork Springs
Knock-off SE Fork Brace
Chopped Rear Fender
Custom Taillight
Outlaw Name Generator
Old 25th April 2010
pigfoot's Avatar
pigfoot pigfoot is offline
Sportster/Buell Model: XL883L
pigfoot is on a distinguished roadpigfoot is on a distinguished roadpigfoot is on a distinguished roadpigfoot is on a distinguished road
Awasome!!!
Thanks for your sharing!
Mod.:Radii Slip-on, TTS Remap, SE spark plug wires, Velocity Stack w/itg sock filter, 170/60R17 on Rear, VRod Brembo caliper & 883R MC.
Sorry for my bad English.
Old 25th April 2010
Trace is (pretty much) right... The XR master cylinder is 5/8". The stock dual setup for 2007+ is 1/2". I *think* that the 2004-2006 dual brakes (maybe others?) have a 14 mm bore.
I'd recommend having a read of my Brembo thread where I started with the single Brembo setup.
Bottom line is, you will have a significant improvement, especially if you get the correct master cylinder. You could do the same single setup with the XR, but I have no idea which master cylinder is going to work properly.
Old 25th April 2010
silver1's Avatar
silver1 silver1 is offline
silver1 has a spectacular aura aboutsilver1 has a spectacular aura aboutsilver1 has a spectacular aura aboutsilver1 has a spectacular aura aboutsilver1 has a spectacular aura aboutsilver1 has a spectacular aura aboutsilver1 has a spectacular aura aboutsilver1 has a spectacular aura aboutsilver1 has a spectacular aura aboutsilver1 has a spectacular aura aboutsilver1 has a spectacular aura about
Very cool, have never even seen a 1200 R before, did you paint it like that or is it factory?
Have had a softspot for Sporty's over forty years now, am considering a new XR model for my first Harley, maybe.
