Snippets
24th November 2020
Posts: 2,993 Sportster/Buell Model: KHK Sportster/Buell Year: 1954 Sportster/Buell Model #2: IronHead XLH Sportster/Buell Year #2: 1978 Other Motorcycle Model: XLRTT Other Motorcycle Year: 1966
HD female rod on the back is better to act as a reservoir to keep the oil next to the rollers for longer, but there's no mechanical disadvantage or reasons why the forked rod can't be mounted on the front.
Both assemblies have been seen in the past, although fork at rear seems more prevalent...
Design of the HD fork seems better suited to be on the rear anyway, so I would split the crank to rearrange...
Patrick
Flat Head Forever
24th November 2020
Posts: 55 Sportster/Buell Model: 883 low Sportster/Buell Year: 2006
Originally Posted by needspeed
Yes your right. No wonder your confused. You have what should be the rear (female) rod in the front cylinder. Turns out you DO know your rod genders.
 that sucks, I guess I will have to take apart the crank.
24th November 2020
Patrick
Hey Patrick,
Thanks a lot for the info. Im thinking that if there is no mechanical disadvantage why change it? If its not going to damage the engine, I wouldn´t mess with it.
