0 Any experience with REBUILT title?
0 Boardtracker Project
0 Clearance between clutch faces 1974 transmission
0 75 IH Oil leaking into starter from primary side/ bendix
0 Improving Fuel Mileage
0 Motorcycle airbag jeans
5 Tire Pressure?
0 XL1200 03 changing from 29tooth to 27
Last Post: sleighcrane
0 Smoke and top end job
0 Colorado Trike
Last Post: Andy56
0 New from France
Last Post: 84bobber
Last Post: Antoine44
0 Sundowner seat positioning
0 Mid West Meet & Greet
0 v twin Crankshaft Bushing Plate Pilot and Reamer
Last Post: thecarfarmer
Last Post: Jaime1840
Last Post: rider61
0 Should I apolgise to Harley Davidson ?
0 Secret Australian Business
Old 26th November 2020
Napawineguy Napawineguy is offline
Napawineguy is an unknown quantity at this point
No have not changed them, but did replace the little filter once. I asked the dealership for them once because I thought I lost one, and they couldn't get them for me. I could check ebay and see if I can find them there.
decman decman is offline
Post no Avatars!
Sportster/Buell Year #2: 1988
Other Motorcycle Model: FXDXT
What do you mean "the gaskets are split when I pull the cover off?"
that doesn't sound right.
As John said those o-rings can be a pain. Also double check you don't have
two installed instead of just the one.
I assume you have the OEM one piece push rod tube. The two piece ones can
cause sddition issues.
Old 27th November 2020
After talking to the dealer, they have me putting about 2 1/2 quarts of oil in. As far as the split gasket, when I pull the top of the rocker box off the gasket will be broke apart in one spot.
denguy denguy is offline
denguy has a reputation beyond reputedenguy has a reputation beyond reputedenguy has a reputation beyond reputedenguy has a reputation beyond reputedenguy has a reputation beyond reputedenguy has a reputation beyond reputedenguy has a reputation beyond reputedenguy has a reputation beyond reputedenguy has a reputation beyond reputedenguy has a reputation beyond reputedenguy has a reputation beyond repute
Check the rocker cover with a straight edge. Mine were warped and I trued them up with a mill file.
Do your rocker boxes have the slots noted in this pic?
If so, they are prone to leaks.
There is a service bulletin regarding them for 04-06 models.
More here: http://www.sportsterpedia.com/doku.p..._design_change
